Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Oct 13, 2015 at 5:39 PM
    #821
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I had to hammer the socket on.
  2. Oct 13, 2015 at 9:47 PM
    #822
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Makes sense I've only hit my diff once, it's not something you have to worry about so much in sand which is what my truck sees most
  3. Oct 14, 2015 at 6:27 AM
    #823
    cynicalrider
    cynicalrider #NFG
    Jersey
    Clearly you need a diff diaper. :rolleyes::p
  4. Oct 14, 2015 at 10:15 AM
    #824
    Squeaky Penguin
    Brett
    Rare that I go on a trip and don't hit my diff. Not much left of the original ring, I see why I keep loosening the plug:
    I don't drink the TW Kool-Aid....
  5. Oct 14, 2015 at 10:33 AM
    #825
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    taller tires?
    i wonder if there is a mod to relocate the drain plug. it would require machining of course.
  6. Oct 14, 2015 at 12:01 PM
    #826
    cynicalrider
    cynicalrider #NFG
    Jersey
    :rofl::rofl:
    There is. It was definitely a LT guy who did it. I almost wanna say @jberry813 but not sure.
  7. Oct 14, 2015 at 4:23 PM
    #827
    Squeaky Penguin
    Brett
    Next step up from my 295s would be going 35s, although I like the idea of the KO2s in 34x10.50. Just have a hard time justifying going to 35s. First on the mod list for spring is a set of 4.88s and a front locker, wouldn't do 35s without the gears, but would still have to tub, modify/ditch the fender flares, get wider wheels, etc. Hardly seems worth it to gain less than an inch of clearance at the diff.
    That's got to be even more work than above!
    dakotasyota likes this.
  8. Oct 14, 2015 at 7:50 PM
    #828
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Your pretty handy with working with steel. Maybe you should consider mocking up a diff skid and making one. Your taco seems to be at a good hight with the tires and lift you have.
    odomandr likes this.
  9. Oct 15, 2015 at 5:02 AM
    #829
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Have you considered just building a drain plug skid and welding it to the housing?
  10. Oct 15, 2015 at 5:18 AM
    #830
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Weld a big as nut to it. What in id to the front. Way better
  11. Oct 15, 2015 at 5:23 AM
    #831
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I think the idea behind that ring is to be a drain plug skid.
    Problem is he's ground down the ring and is now grinding on the drain plug.
    My plug is actually recessed below the level of the ring but I haven't been dragging my ass.
    I think a new drain plug and a new ring around it will be good to go for another couple years.
  12. Oct 15, 2015 at 5:26 AM
    #832
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also if their is even the slightest interest of doing 35s. Get 5.29s. So worth it. I think my truck would still be a bit of a dog with 4.88s.
    The 34x10.5 KOs are still a 33 I've read. They are just a slightly tall 33. But still see like a good size. Has to be a 17" rim though..
  13. Oct 15, 2015 at 6:50 AM
    #833
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    If you have a welder it's not very difficult at all to just delete the drain plug by cutting it out and plating over it to avoid any hassles from it. Then you can drain the axle by tack welding a lower third member stud to the nut and just pull it out. Not as fast but it works.
  14. Oct 15, 2015 at 7:17 AM
    #834
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    ^^^not a bad idea.
  15. Oct 15, 2015 at 10:42 AM
    #835
    Squeaky Penguin
    Brett
    I'm sure I could make some kind of skid, just still don't see the purpose. Lower ground clearance, fills up with mud and shit, don't want it hanging down there.
    As the other Brett says below, the ring is a sort of skid. Just need to build it back up with some welds.
    I have no idea what you're trying to say! Have a nut that fits around the current ring? That would be huge!
    This is the route I'll probably be taking. Took several years of wheeling to get down to the plug. Just weld it back up and check it every so often.
    That's a tough call to make. From what I understand now, 4.88s would be slighly over-geared with my current tires, so 35s would be right around stock I would think. 5.29s on anything smaller than 35s would be painful I would imagine. Guess I need to decide where I want to go and commit, we'll see how much money I can pour in this thing after I graduate in December.
    Seems like a good idea! If I smash down the welded up ring quickly, I may consider this.
    SilverGhost[QUOTED] likes this.
  16. Oct 15, 2015 at 11:20 AM
    #836
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    You said you wanted to be overgeared!!
  17. Oct 15, 2015 at 11:38 AM
    #837
    Squeaky Penguin
    Brett
    I do. As in 4.88s and stick with 33ish, or possibly 5.29s and 35s. 5.29s and 33s are right out.
    My point was you could get away with 4.88s with 33 or 35s, and even with 35s would still be at a better crawl ratio than my current 295s on 4.10s.
    dakotasyota[QUOTED] likes this.
  18. Oct 15, 2015 at 12:04 PM
    #838
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    using 5th gear as a final drive at .80 . speeds and rpm are approximate.
    4.10 with 29" tire at 75mph will be 2850 rpm---Basically stock for this purpose.
    4.10 with 33" tire at 75mph will be 2505 rpm
    4.10 with 35" tire at 75mph will be 2362 rpm---this will suck ass.
    now we skip the 29" tire
    4.88 with 33" tire at 75mph will be 2981 rpm---this is what I am running currently. :)
    4.88 with 35" tire at 75mph will be 2811 rpm--not bad but room for improvement.
    only 39 rpm under stock. Added tire weight will be felt for sure, I'd go lower.
    5.29 with 33" tire at 75mph will be 3232 rpm---screaming down the highway
    5.29 with 35" tire at 75mph will be 3047 rpm---decent, usable gear ratio with 35"
    you need to mentally factor in rolling resistance, tire weight, wind shear, hills, RV's in the way, etc...
    I'd go 5.29 if heading for 35's. This should work good for 37's too.
    or go 4.88 with a crawl box.
    http://www.ringpinion.com/Calculators/Calc_RPM.aspx
    Squeaky Penguin[OP] likes this.
  19. Oct 15, 2015 at 12:17 PM
    #839
    Squeaky Penguin
    Brett
    Clearly the only reasonable answer is 37s, 5.29s, a new DD, a crawlbox with the 4.7 low, a front locker, and a dozen spare CVs for the trail.
    Then I would have to take after the rest of TW and rename this a 'broke college student build' and ask for donations and sponsors... :rolleyes:
  20. Oct 15, 2015 at 12:42 PM
    #840
    cynicalrider
    cynicalrider #NFG
    Jersey
    FWIW I don't consider 3200 screaming at all. Yes it's a slightly higher RPM but I have cruised at 3400 RPM for long periods of time with no issues. Granted it was higher than 75 mph but not by much.
