Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Dec 11, 2015 at 9:41 AM
    #961
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Can't imagine my sliders are air tight, that just seems entirely too complicated.
    Airing up faster is not the main goal here, but while building a setup to run an air locker, I might as well build one to have other benefits as well.
  2. Dec 11, 2015 at 9:48 AM
    #962
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'm saying since the tank will be emoth between tires the compressor will run non stop for you to do your tires vs getting a break inbetween. Not saying it will make it worse. But it's possible.
    The 90psi for a locker is the downer. Why I said fuck it and ran separate co2 for mine.
  3. Dec 11, 2015 at 9:49 AM
    #963
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    to drill and thread a hole? This is complicated after swapping out the LCA bushings???
    :cookiemonster:
    Don't use the bent up trashed part, use the part under the body lip. If it leaks, weld it shut.
  4. Dec 11, 2015 at 9:56 AM
    #964
    Squeaky Penguin
    Brett
    My compressor has no cutoff switch now, and it runs constantly when airing up tires. I think the 33% duty cycle says like 20 minutes on 40 minutes off.
    OK, I'll help you swap LCA bushings and you can build my sliders into air tanks. What I was concerned about is making sure they're perfectly air tight. I guess on the main 2x2 structure, the only welds are the end caps, so it wouldn't be too complicated to track down leaks. But on top of that, how much air would they actually hold? Would also need to get some NPT taps I would imagine. A viair tank costs like $60 and has all the ports I would need.
  5. Dec 11, 2015 at 10:03 AM
    #965
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Wait what? Turning sliders into air tanks???
  6. Dec 11, 2015 at 12:59 PM
    #966
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    well, with my limited math, I figure one of those 2x2's at 60" length is roughly 80 cubic inches, I am most certainly off with this. That is roughly over a third of a gallon of volume.
    And air compresses so you can pack it in there.
    Was just an idea.
    ACE carries the tap and fittings, run you under $20.00.
  7. Dec 11, 2015 at 2:14 PM
    #967
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    What about at 12,126 feet? fucker.
  8. Dec 11, 2015 at 2:23 PM
    #968
    TBuzz
    TBuzz Well-Known Member
    Colorado
    00' 4runner, No Longer Stock
    Bumpers, Sliders, 33's, ADS f&r, budbuilt, home built belly and bumper, s/c, urd,4.88, arb's
    I heard the work Moab and found my way in here. Congratulations on graduating and believe it when the old guys say "every year goes by quicker" or "I'm going bald but my shoulders are getting hairy".
    I have to ask why would he air up at the top of a pass?
  9. Dec 11, 2015 at 2:24 PM
    #969
    Squeaky Penguin
    Brett
    OK. I'm going to attempt to improve upon your math, being you are indeed way off.
    • Slider body is 2x2", 1/8" wall (I think that's what Jerry uses), and 80"
    • 1.875x1.875x80 = 300 cubic inches
    • .004329 cubic inches to a gallon
    • 300x.004329 = 1.2987 gallons
    I did the math for the Viair tank using these figures, and it appears that they measure out volume at atmospheric pressure. Might be worth a try. :notsure: Worst case scenario I just plug the hole in the slider. I would be a little concerned about having the locker solenoid down there though, would be rather exposed.
    Valid point. Not enough air to compress at high elevations. Maybe at sea level I would be faster than you :cookiemonster:
    Also, If I would have aired up quicker there I wouldn't have caught my loose diff drain plug....
  10. Dec 11, 2015 at 2:27 PM
    #970
    Squeaky Penguin
    Brett
    LOL. Thanks bud! Luckily, I have a healthy head of hair. And yes, Moab sounds very temping where there's not much wheeling left around here.
    And on our last trip, James and I aired up at the top of Cottonwood pass, where it transitions to pavement. The compressor took probably about 3x longer than normal up there. But you're right, not very often you're airing up at the top of a pass.
  11. Dec 11, 2015 at 3:34 PM
    #971
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Excellent, was a test to see if you had actually earned that degree.:thumbsup:
    As far as the solenoid, mount it somewhere else.
    MatthewMay1 and 303tacoma like this.
  12. Jan 2, 2016 at 12:43 PM
    #972
    Squeaky Penguin
    Brett
    Headed to Moab for New Year's
    [​IMG]IMG_0153 by brettbjorgum, on Flickr
    [​IMG]IMG_0145 by brettbjorgum, on Flickr
    [​IMG]IMG_0108 by brettbjorgum, on Flickr
    Trip report here:
    https://www.tacomaworld.com/threads/a-snowy-new-years-in-moab-12-29-15-1-01-16.408494/#post-11485844
    And a few minor build thread updates: Got a new, proper Hi-Lift for Christmas so the garage sale hi-lift of death has been retired. Also, swapped the lighting to all old-school Halogen thanks to some Hella 500 black magics from @sean266 and some Piaa 510 Ions from @09blacktaco. Not as many lumens as the LED setup, but good reflectors make for much more useful light output.
  13. Jan 2, 2016 at 5:27 PM
    #973
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Where'd the shell go??
  14. Jan 2, 2016 at 8:41 PM
    #974
    dakotasyota
    Dakota
    Ellensburg, WA
    You did Kane Creek in the snow?? Crazy bastard!
  15. Jan 2, 2016 at 9:35 PM
    #975
    Squeaky Penguin
    Brett
    It's sitting in the garage. Took it off to haul a motorcycle and its been too cold to put it back on. Honestly, the truck looks better without it, but it's so practical I couldn't live without it. Being I wasn't camping and didn't need much gear, I didn't miss it this trip.
    I've been called worse, but if you read the report we turned around at the climb out due to time, poor conditions, and not knowing if we would be able to make it up and out.
  16. Jan 2, 2016 at 9:46 PM
    #976
    dakotasyota
    Dakota
    Ellensburg, WA
    I'm gonna read it! Couldn't load it on the road on my phone
  17. Jan 4, 2016 at 4:59 PM
    #977
    Squeaky Penguin
    Brett
    Pile of parts for spring work is starting.
    Picked up a set of spindles so I can get my TC spindle gussets all set without dismantling the truck. Also I have a set of Tundra calipers on the way, so I'll cut up the dust shields to fit those. Will also be adding wheelers brake lines, but am undecided on pads and rotors for now. Not going to be getting to this for a couple months probably, but I'll have a set of spindles and some EBC sport rotors for cheap available when I do. Going to pick up some axles from CVJ as well and that should freshen up the front end nicely.
    Also, getting beat up chasing James has me putting proper suspension higher up on the list, still falls behind regearing though. For that, I've more or less settled on 4.88s and sticking with the same size tires. Far too many negatives for going 35s for my purposes. In fact, I'm a little concerned about potential clearance issues with the 295s when adding UCAs and moving the top of the spindle back as is. We'll cross that bridge when we get there.
  18. Jan 4, 2016 at 5:00 PM
    #978
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Dang, that whole spindle assembly looks brand new!
  19. Jan 4, 2016 at 7:24 PM
    #979
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    I'm in the market for a shell, I'm excited for sleeping in t this summer, do u have a platform set up??
  20. Jan 4, 2016 at 7:41 PM
    #980
    Squeaky Penguin
    Brett
    They're off of @bayareataco 's rig. Should be perfect candidates for spindle gussets.
    No, but I do sleep back there all the time, and have considered a sleeping platform. When I'm on a longer trip, besides camping gear all that's in the back is my toolbox full of truck stuff (spare parts, fluids, various ratchet straps, larger tools, etc.). Normally, I just turn it sideways and sleep between it and the wheelwell, but that doesn't leave a lot of room. It's nice to remove it, but that does take an extra set of hands as it's quite heavy. I've always wanted a way to store all that junk and create a better place to sleep at the same time.
