Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Feb 5, 2016 at 11:23 AM
    #1021
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Crawlorado
    Thanks! Need to work on the swingout to get a couple scepter cans on it and a camp table. Then we'll see how my big ass bolt of a hinge holds up.
    PcBuilder14[QUOTED] likes this.
  2. Feb 5, 2016 at 11:26 AM
    #1022
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Are you replacing the Rotopax with the scepter cans? If so, why?
  3. Feb 5, 2016 at 11:32 AM
    #1023
    Squeaky Penguin
    Brett
    I lost the rotopax last year in Moab when the center bolt broke. Never buying them again. The 1/4 or 3/8 or whatever size the main bolt is not up to what I need.
  4. Feb 5, 2016 at 12:09 PM
    #1024
    spacecat
    spacecat Well-Known Member
    Lauren
    So Cal
    03 White 3.4L V6
    Beautiful truck and build OP!
  5. Feb 5, 2016 at 12:19 PM
    #1025
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    :rofl:
    come on now.... in the interest of fairness, don't you think that you should mention the fact that you had previously nearly ripped them off on the whale's tail and the rod was all kinds of bent up?
    odomandr and Deathbysnusnu like this.
  6. Feb 5, 2016 at 12:42 PM
    #1026
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    A gas can mount should always double as a rear departure angle skid, come on man, get with the program. :D
  7. Feb 5, 2016 at 1:08 PM
    #1027
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Thanks for the valuable info! Quite a bit to chew on still. I'd like to avoid Colfax if possible, so different wheels may be best.
    I'd love to head north and wheel with you guys some time. Seems like a fun crew you have going up there.
  8. Feb 5, 2016 at 1:52 PM
    #1028
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I found this at LowRange Offroad. Not certain yet if it will fit the rear diff drain.
  9. Feb 5, 2016 at 3:31 PM
    #1029
    Squeaky Penguin
    Brett
    Thanks. :thumbsup: If you saw it up close you might change your mind on the beautiful part though.
    And who was suppose to be spotting me up that line?
    Regardless, the rod was slightly bent, yes. But still, not a very large diameter bolt. With one pack I think it's sufficient, but when you double them up with the extension it's too much weight. Also keep in mind the section of bolt that bent was the outer part for the 2nd pack, and it broke off at the base on the first section of threaded rod.
    When I get done with a proper gas can mount it will be. :cool:
    Or I'll build it high enough that I should never hit it.
    On the other side of that story, a narrower wheel has several advantages, especially off road. Just letting you know you could run into troubles trying to get them mounted. And we're wheeling all summer and come from all over the state. Keep up on the upcoming events thread when wheeling season hits.
    Look the same as the All Pro one that @jberry813 told me he runs. I've got a brand new OEM one sitting in my glove box that I'll swap on the next time, and work on welding up around that ring as well. If I still have problems after that, I will probably pick up one of these allen head ones.
  10. Feb 15, 2016 at 11:15 AM
    #1030
    Squeaky Penguin
    Brett
    @alee891
    Snorkel is on the left, short piece of rubber was cut from the tube that comes with the snorkel. Far right is the stock elbow that connects to the airbox and was rotated upwards. The remaining tube is the stock hard plastic tube that was unbolted and cut shorter.
    The elbow and tube are both bolted on and might still be there even with your CAI.
    alee891 likes this.
  11. Feb 15, 2016 at 12:12 PM
    #1031
    alee891
    Austin
    Black Hills
    Tacomaless
    Thank you! Elbow and tube are still there, now I just need to get my hands on an airbox.
  12. Feb 16, 2016 at 6:31 PM
    #1032
    Squeaky Penguin
    Brett
    Red adds horsepower right?
    Powerstop calipers, Wheelers brake lines, Hawk LTS pads, and Centric premium rotors will be installed whenever I get around to doing all the front end work. Hopefully my mishmash of parts works well.
  13. Feb 16, 2016 at 6:32 PM
    #1033
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    tundra upgrade?
  14. Feb 16, 2016 at 6:32 PM
    #1034
    Squeaky Penguin
    Brett
    Yessir. 13WL
    Bennett707[QUOTED] likes this.
  15. Feb 16, 2016 at 7:12 PM
    #1035
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Nice! Love mine
  16. Feb 17, 2016 at 5:47 PM
    #1036
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    OK stop being lazy and get all those parts in. :argue:
  17. Feb 17, 2016 at 6:00 PM
    #1037
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    2014 TDR Off Road
    Enough to make it a lot of fun!
    You haven't hung out with him enough yet ray. Brett will probably procrastinate until the weekend before his first wheeling trip of the year. :rofl:
  18. Feb 17, 2016 at 6:23 PM
    #1038
    Squeaky Penguin
    Brett
    :gossip: There's more parts I'll be getting first.
    Going to tear my entire front suspension apart and replace it all at once. Plus it's cold up here and I need access to a welder.
    This is also true, but at the same time working on trucks is a lot more fun than school work, and I'm excited to get all the parts installed and be able to enjoy them.
  19. Feb 17, 2016 at 6:28 PM
    #1039
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    It's warm down here and look a welder. How about them apples.
  20. Feb 17, 2016 at 6:29 PM
    #1040
    Night Eagle
    Leo
    2014 TDR Off Road
    Let me know when you are ready to put stuff together. Let me know. I am more then willing to help.
