Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Mar 13, 2016 at 9:18 AM
    #1161
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    This is new to me. So you put your truck in 5th and crank it over and it tightens it down close to spec?
  2. Mar 13, 2016 at 1:25 PM
    #1162
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Not quite, he put it in fifth to hold the crank, then torqued it with a wrench.
    SilverGhost[QUOTED] likes this.
  3. Mar 13, 2016 at 3:58 PM
    #1163
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    this is why we can't have nice things...
    ebbs15 and SilverGhost[QUOTED] like this.
  4. Mar 13, 2016 at 6:58 PM
    #1164
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Glad you guys got that sorted out. I was a bit preoccupied shoveling my truck out from roads I shouldn't have been on.
    Floating on top of settled snow at like 8psi. Look at the sign :eek:
    Surprising floated pretty well....
    .... enough so to get me further back and into worse situations. Got stuck here, made it to the dirt, turned around, and got stuck again:
    Made it back out though, only after getting stuck a few more times.
    Engine is running perfect after the timing belt/water pump work. Did see temps hit like 203 on the highway though, not sure what that's about :notsure:
  5. Mar 13, 2016 at 7:01 PM
    #1165
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Did they not use to? I think mine will run about 220 pretty regularly.
  6. Mar 13, 2016 at 7:06 PM
    #1166
    Squeaky Penguin
    Brett
    I don't consider that too warm per se, but it was rare it would get above 200. Liked to hover at 194. Just somewhat surprised to see that especially after cleaning so much mud out of the radiator.
  7. Mar 13, 2016 at 7:07 PM
    #1167
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    2014 TDR Off Road
    Enough to make it a lot of fun!
    Don't feel bad about getting stuck. I took the 18 island road last Monday and got really stuck. I made it all the way to the parking lot and then just sank. The top layer was all ice and then wet snow.
  8. Mar 13, 2016 at 7:12 PM
    #1168
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    The new motor runs in the same range. I do watch my temps like a hawk. It just because it's still a new motor to me and I'm a tad nervous. I'm pretty sure it's normal temps tho.
  9. Mar 14, 2016 at 9:41 PM
    #1169
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Do the first gens have an actual temperature gauge? I think mine just has the un-scaled idiot gauge (H/C).
  10. Mar 14, 2016 at 9:49 PM
    #1170
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    If you have an ultragauge or scangauge it has an engine temp readout.
    Mine has never gotten above 197 from what I've seen. And that was in the middle of July in New Mexico.
  11. Mar 14, 2016 at 10:20 PM
    #1171
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I have a bluetooth OBDII and Torque Android app. Would that tell me the temperature or do I need a different sender in the engine block?
  12. Mar 15, 2016 at 12:21 AM
    #1172
    BigFishAllDay
    BigFishAllDay And then?
    Nick
    ABQ, NM, USA
    I have too many Toyotas...
    Everything... and a bag of Cheetos.
    You are my Tacoma hero.
    Seriously. That picture next to the sign is nuts. I don't press the like button on principle, but I like that picture.
  13. Mar 15, 2016 at 3:35 AM
    #1173
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    That's what I use. Well the iPhone version. It gives me the coolant temps.
  14. Mar 15, 2016 at 7:48 AM
    #1174
    Squeaky Penguin
    Brett
    Did you get to shovel out too? I learned that not following my old tracks and going really slow helped me stay on top of the firm layer.
    This. I have an ultragauge I'm reading off. Not sure where that pulls temperature off of though? And yeah, the factory temperature gauge doesn't seem that useful. Mine stays dead center inbetween about 170 to as hot as I've ever gotten it.
    I won't like your post in support of your principles, but thanks man! :p Nuts would be an accurate description. I was putting along just hoping I didn't suddenly sink to the frame. Probably not the smartest thing to do, but hey, fun was had.
    Hoping you decide to bring the much cleaner version of my truck to Moab. I'd love to see it.
  15. Mar 15, 2016 at 9:09 AM
    #1175
    Night Eagle
    Leo
    2014 TDR Off Road
    Ya I got to do a lot of shoveling. I got across the cattle guard and I just sank. I was also trying to come-a-long my way out. It helped me for a while but I ended up havin to call my cousin. I was going to be there a while if I hadn't.
    DoubleCab362 likes this.
  16. Mar 15, 2016 at 5:09 PM
    #1176
    BigFishAllDay
    Nick
    ABQ, NM, USA
    I tried to do that same thing one time in my '97 4Runner, but was so inexperienced at the time I didn't even air down. I sunk it right to the frame and spent hours shoveling snow with a little folding shovel before some help came along. At the time I was thinking we would have to spend the night out there.
    You go on some fun adventures, for sure.
    teamhypoxia likes this.
  17. Mar 15, 2016 at 8:33 PM
    #1177
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I "liked" this post because of your principles.
    I don't like the foolishbook, but I have an even stronger aversion to principles.
    ......also, it was a good opportunity to crap on @homealone's build thread which is sort of a hobby of mine.
    Deathbysnusnu likes this.
  18. Mar 16, 2016 at 10:51 AM
    #1178
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
  19. Mar 16, 2016 at 11:26 AM
    #1179
    Squeaky Penguin
    Brett
    3 and 5/8" although 3 and 3/4" would probably work too.
  20. Mar 16, 2016 at 12:08 PM
    #1180
    alee891
    Austin
    Black Hills
    Tacomaless
    Thanks!:thumbsup:
