Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Mar 28, 2016 at 4:23 PM
    #1201
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    I think I will pass on that this time. At least if we are at bfe.
  2. Mar 29, 2016 at 6:59 AM
    #1202
    cynicalrider
    cynicalrider #NFG
    Jersey
    Just ordered this. Looking forward to trying it out.
    Congrats dude! Regeared and locked F/R is where it's at! Hope to be doing it soon as well.
    SilverGhost[QUOTED] likes this.
  3. Apr 1, 2016 at 7:36 PM
    #1203
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Got the rear diff in today after work and drove it around the block. Swap went quite smoothly. Front tomorrow followed by breaking them in.
    SilverGhost likes this.
  4. Apr 1, 2016 at 7:43 PM
    #1204
    Night Eagle
    Leo
    2014 TDR Off Road
    I would hope it was easy. Expecially after we did James' in moab. But let us know how the front goes.
  5. Apr 1, 2016 at 8:12 PM
    #1205
    Squeaky Penguin
    Brett
    The E-Locker added a few minor complications. Also, I need to join James in some crossfit before I try that again. Laying on the ground lifting that diff up and onto the studs took took all my strength. Hoping I can get the front in there.
  6. Apr 1, 2016 at 8:18 PM
    #1206
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I'd recommend having an extra hand for the front. I didn't have any problem getting it out by myself but finagling it back in was tough. Fortunately I had a buddy nearby to help.
  7. Apr 1, 2016 at 8:30 PM
    #1207
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    It helps to place a floor jack under the transmission on the bellhousing and jack it up a little. Allows more room for the pinion flange to clear.
  8. Apr 1, 2016 at 8:33 PM
    #1208
    Night Eagle
    Leo
    2014 TDR Off Road
    Ya they aren't light at all. Inoted of crossfit you could come work with me for a while. :D
  9. Apr 1, 2016 at 9:31 PM
    #1209
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    How life changing was it to be regeared? I loved it the second I pulled out if the garage
  10. Apr 1, 2016 at 9:51 PM
    #1210
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    I had to get creative with the front. Held the diff up with my knees as I maneuvered it in with my arms. I assumed I looked like an idiot to everyone else in my apartment complex...
  11. Apr 1, 2016 at 9:53 PM
    #1211
    Blackdawg
    Monte
    Wyoming/St. Louis
    I used a jack....was pretty easy..
  12. Apr 2, 2016 at 4:49 PM
    #1212
    Squeaky Penguin
    Brett
    Back together and two break in drives down. The rear diff gets surprisingly hot in just a 20 minute drive. Got a second set of hands on the front diff, there's no way I could have done that by myself, but surprisingly, getting it back in was easier than getting it out. Jacking up on the bell housing helped a lot.
    While I've only gone fairly easy on it, I'm somewhat surprised it doesn't feel lower geared than it is. Still running my 265/75s and even then it's not that low. Real test will be on the bigger tires seeing how it holds gears in the mountains, and in 4L on the trail. Can't wait to test it all out.
    Have a few lingering issues though, main one being a little weep from the rear third member. Guess my form-a-gasket technique needs a little work. Not excited to pull that again, but at least it was way easier than the front.
    thefatkid, Reh5108 and SilverGhost like this.
  13. Apr 2, 2016 at 6:21 PM
    #1213
    Reh5108
    Idaho
    I was expecting more of a difference too. It does hold gear better and I can now use 5th again. Can't wait to get it on a trail and test them though.
  14. Apr 2, 2016 at 6:30 PM
    #1214
    Blackdawg
    Monte
    Wyoming/St. Louis
    You'll notice more on the hwy and 4lo then anything for sure. I can pull hills in 5th now. It's great. Granted I'm a tad more over geared than you.
    The heat is normal especially for the first few drives. Hopefully not over 200°. A laser temp gun is good to have to check your gears for the next 5k
  15. Apr 2, 2016 at 6:38 PM
    #1215
    Blackdawg
    Monte
    Wyoming/St. Louis
    4.88s and 33s with the manual is only a slight over gear from stock. So not a drastic change. But it still should make drivin it much better.
    Reh5108[QUOTED] likes this.
  16. Apr 3, 2016 at 7:55 AM
    #1216
    thefatkid
    Brian
    Colorado
    2004 thingy
    Mine have been running in the 170° range. I'm at 200 miles now. Trying to keep highway run short and checking temps. Your gears looked better then mine and your gear sets looked like they came out of a different machine/run.
    Squeaky Penguin[OP] likes this.
  17. Apr 3, 2016 at 8:07 AM
    #1217
    Squeaky Penguin
    Brett
    Haven't measured it but I don't think it's getting that hot. Can just barely hold my hand against it after a drive.
    What do you, or anyone else know about u-joints? Noticed just a touch of rotational play in my rear-most u-joint yesterday. Is that a stick with OEM item? Obviously want to get that replaced before it breaks in the middle of nowhere.
  18. Apr 3, 2016 at 8:14 AM
    #1218
    thefatkid
    Brian
    Colorado
    2004 thingy
    I found that OEM lasts longer and doesn't break as easy aftermarket. I don't run anything else. I carry a OEM as spare also.
  19. Apr 3, 2016 at 8:27 AM
    #1219
    Squeaky Penguin
    Brett
    That answers that. :thumbsup:
    Which one do you carry as a spare? I thought there were different u joints along the driveshaft.
  20. Apr 3, 2016 at 8:30 AM
    #1220
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    After the 3 heat cycles of braking in how long are you guys running the front diff for?
