Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Apr 4, 2016 at 8:25 AM
    #1241
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    There are lot of people, or rather, was, on ttora who did.
    Granted this has to do more with people running bigger tires.
  2. Apr 4, 2016 at 9:00 AM
    #1242
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    No leaks under the 3rd this morning and didn't break 100 degrees on my drive into work.
    Also, got a couple OEM U-Joints on order. Figured I might as well get a spare.
  3. Apr 4, 2016 at 1:29 PM
    #1243
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    What's a good way to tell if your U-joint is bad? Besides squeaking...
  4. Apr 4, 2016 at 5:39 PM
    #1244
    Squeaky Penguin
    Brett
    Can't say I've heard of a U-Joint squeaking. On mine, you can feel/see some rotational play in the joint. I've also seen it where it causes a vibe. Speaking of which, I'm hoping this fixes a high-frequency vibe that seems to have been increasing. Best way to check it would probably involve pulling the driveshaft and rotating and twisting all the joints to see if they're tight.
    Missed this one last night too. Pictures of awesome 4runners on Poughkeepsie wall are gladly welcomed in this build. The left line there looked like it was reserved for bigger rigs. Curious to see how you made it up.
  5. Apr 4, 2016 at 6:11 PM
    #1245
    TBuzz
    TBuzz Well-Known Member
    Colorado
    00' 4runner, No Longer Stock
    Bumpers, Sliders, 33's, ADS f&r, budbuilt, home built belly and bumper, s/c, urd,4.88, arb's
    I know of 3 front diff spider gears failing. Two times on the same obstacle and again on another shaped the same. All 3 times it happened the front ends were bouncing both tires in the air and when they came down in unison,,crunch crunch. So I never ever bounce my front anymore as I was one of those people to leartn the hard way. If I was locked it'd never needed bouncing to make the obstacle.
  6. Apr 4, 2016 at 6:39 PM
    #1246
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    That's how I blew up my rear :oops:
  7. Apr 4, 2016 at 6:44 PM
    #1247
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Thought that was taco bell? :notsure:
    CO MTN Steve likes this.
  8. Apr 4, 2016 at 6:45 PM
    #1248
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    One end of the drive shaft is laying on the ground
  9. Apr 4, 2016 at 6:57 PM
    #1249
    TBuzz
    Colorado
    I may have opened mouth too much there as I only have pictures of in progress shots. They don't actually show completion. I had a bystander try and capture the moment for me. This is the direction up the left that works for my rig.
    And here going up the right I had to get out and access my situation so took a stuck pic. But you can see how muddy it was.
    Way tougher stuff than Poughkeepsie just an hour and a half south. It's like driving on 60 grit sand paper.
    Do you have a cheat sheet of one liners written on your forearm just waiting to unload in people?
    Lol
  10. Apr 4, 2016 at 7:43 PM
    #1250
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    What exactly did you do for your "form-a-gasket"? I have a small leak from my rear as well. I need to try and pinpoint it, but not too excited to pull it again.
  11. Apr 4, 2016 at 8:06 PM
    #1251
    Squeaky Penguin
    Brett
    I'm no expert on the matter so I would suggest consulting someone else. But here's what I did:
    First attempt was using whatever I had laying around. In this case it was some-brand-other-than-toyota-that-won't-be-mentioned-on-this-site-abond. I used a thin layer and smoothed it out with my finger before installing it. Pulling it yesterday suggested i didn't have enough.
    Second, seemingly successful attempt, involved a new tube of ultra black RTV. I would have liked to use Toyota FIPG but I can't get that locally. Applied a much more liberal bead, installed the third, snugged the bolts, torqued and hour later, and then let it dry for several hours before adding oil. So far so good.
    My install kit came with a paper gasket but it didn't fit. I think it was for a non e-locker. :notsure:
  12. Apr 4, 2016 at 8:11 PM
    #1252
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    2014 TDR Off Road
    Enough to make it a lot of fun!
    I am betting he used was a Mitsubishi gasket. Just a guess because that is what is the only thing that he has a his house, that would be close.
  13. Apr 4, 2016 at 8:27 PM
    #1253
    Squeaky Penguin
    Brett
    If it was mitsubond it probably would've worked better. Pulled out the old Montero the other day. Engine's showing it's age, now with milkly coolant and excessive exhaust smoke. Needs a new V6, this time with a turbo. Or a V8. Time to learn about engine swaps.....
  14. Apr 4, 2016 at 8:44 PM
    #1254
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Did you try flipping the gasket? It looks like it would be symmetrical but it's not. When I tried putting mine in first I didn't think it fit but I flipped it around and it worked. No leaks yet.
  15. Apr 4, 2016 at 8:45 PM
    #1255
    Night Eagle
    Leo
    2014 TDR Off Road
    I just figured you had one sitting around so you tried it.
    Man that sucks. For what little power it had, it was a fun car. I say we throw either a chevy 350 or a LS1 in there.
  16. Apr 5, 2016 at 8:10 AM
    #1256
    alee891
    Austin
    Black Hills
    Tacomaless
    I'll have to double check the gasket when I pull it. It seemed to fit just fine upon initial install. I'm just bummed to see a slight leak after all of the work toward regearing thus far!
  17. Apr 5, 2016 at 8:30 AM
    #1257
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Looking at the tools used to clean your gasket surface, you might have a scratch/gouge that could be causing a leak. Or any piece of the old gasket left behind can cause a leak also because it creates an uneven surface.
  18. Apr 5, 2016 at 8:59 AM
    #1258
    alee891
    Austin
    Black Hills
    Tacomaless
    That is very possible. I'll have to take it apart this week and see what I can find. I may have to steal Brett's RTV method to fill any imperfections that may have developed from the "cleaning" process when we we initially removed the rear.
    ...getting reeeeaaaaal tired of that gear oil smell as of late.:bananadead:
  19. Apr 5, 2016 at 11:26 AM
    #1259
    Squeaky Penguin
    Brett
    I rotated it every which way and it didn't work. None of the holes were spaced wide enough for the elocker studs.
    It was Hondabond. Really, it was my error in technique and not the material used.
    Oh, and no GM engine is going in my Mitsu. Wonder if I can get a 1UZ in there. Really, that trucks not worth a whole lot, so I need to decide what I want to do to do.
    Yep, certainly wasn't excited to pull the 3rd two days after I put it in, but wanted to get it done right.
    I spent a lot of time with a razor blade cleaning both surfaces carefully. Although in hindsight, I wonder if it's best to pull the studs, so you can easily clean everything and get a nice, flat surface.
    Yeah, me too. I have a slight leak out of the front diff where the driver side CV goes in. Both my CVS are trash, but I have new CVJs waiting for me.
  20. Apr 5, 2016 at 11:30 AM
    #1260
    Night Eagle
    Leo
    2014 TDR Off Road
    For a V8 you can't go wrong with a gm motor. The 350 is one of the most proven V8s out there.
    Or do you.:spy:
