Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Jul 28, 2016 at 9:13 AM
    #1521
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Hey, I resemble that statement!
    Hows the clearance with the new wheels? Did you leave the spacers?
  2. Jul 28, 2016 at 9:37 AM
    #1522
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I pulled the spacers off. Need to pull the coilover and cycle to know for sure, but right now I have just a slight bit of frame rub at ride height.
    What took me the longest time to wrap my head around was the combo of 1" wider wheel with 3/4" less BS. So I'm really not 3/4" worse than I was. Might benefit from some 1/2" or 3/4" spacers, but I think I'm fine for now. Will probably continue rubbing the resi at full lock/full stuff as it is though.
  3. Jul 28, 2016 at 9:41 AM
    #1523
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I can install a longer hose to move the resi. We can go as long as you want to get it away from the tire.
  4. Jul 28, 2016 at 9:46 AM
    #1524
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Yeah, that just pushed you in a 1/4". Mine did the same with 1/2" wider wheel and 1/2" less backspace.
  5. Jul 28, 2016 at 10:02 AM
    #1525
    Squeaky Penguin
    Brett
    What spacers are you running with the Ray 10s to clear 35s?
    And the problem is I need a place to put the resis. Don't see an easy spot to move them too. With a shorter hose and some 90 degree fittings I could try @4Running Daily s setup.
    SilverGhost likes this.
  6. Jul 28, 2016 at 10:15 AM
    #1526
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    NO spacers, I got the wheels to get rid of my 1.25" I had. It gets into the frame hard at full lock, I'll pocket the frame when I have some time this winter.
    That can be done, I have the hose and fittings.
    edit: Another option might be to mount it horizontal on the upper coil over mount and just have the hose loop out and around the arm, but that depends on how high your truck bumps out and if the arm will contact the resi or hose.
  7. Jul 29, 2016 at 12:54 PM
    #1527
    TBuzz
    TBuzz Well-Known Member
    Colorado
    00' 4runner, No Longer Stock
    Bumpers, Sliders, 33's, ADS f&r, budbuilt, home built belly and bumper, s/c, urd,4.88, arb's
    The truck looks very sweet all cleaned up! Did you do it all the detail by hand or a DA?
    When u recently said that you lowered the truck, how man threads you have showing now. You see in 4runnugdaily has only a few. I have 21 and am pulling it apart now to adjust it down.
    Thanks
    Edit..lowered 10 threads which equated to one inch.
  8. Jul 31, 2016 at 6:28 PM
    #1528
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Looks good but I think you got the coil over on the wrong side. The elbow for the resi should be facing the front of the truck not the back. What does the other side look like?
    Wait a munite... Is the fender green in the pic? Is this pic of your truck?
  9. Jul 31, 2016 at 6:47 PM
    #1529
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I don't think it's his rig
    SilverGhost[QUOTED] likes this.
  10. Aug 1, 2016 at 8:05 AM
    #1530
    Squeaky Penguin
    Brett
    Just a quick wax by hand. I clay bared it early in the year, but only care enough to do that once a year.
    Just counted 13 threads passenger and 14 driver. Sitting somewhere between 22.5-22.75" center of hub to fender. Think they came with about 8 or 9 showing. Might crank them a few more turns, but I don't care about lift height and am happy with how they are performing.
    Have you seen @Delta00 's setup? His came with a lot of preload:
    Not sure why ADS is sending them out so different.
    Yep, that's not mine. I've got the elbows and resis going to the front, but struggling to come up with a resi mounting solution to keep it from rubbing.
    Oh, and a couple pictures from this weekend's fun:
    [​IMG]IMG_0643 by brettbjorgum, on Flickr
    [​IMG]IMG_0717 by brettbjorgum, on Flickr
  11. Aug 1, 2016 at 8:31 AM
    #1531
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    TARS!!! I need to get out more. Do you ever find it's a struggle between wheeling or riding the dirtbike?? Now that I've thrown the sport bike into the mix there's not enough time to enjoy all my hobbies!
  12. Aug 1, 2016 at 9:21 AM
    #1532
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    I bet ADS is still trying to figure out what location works best for most trucks. Also might depend on who you buy from, ADS direct might have one setup and MCM or DSM another.
  13. Aug 1, 2016 at 10:02 AM
    #1533
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    If I wanted to adjust the pre load would I have to get another alignment? Maybe take it down about an inch...
  14. Aug 1, 2016 at 10:39 AM
    #1534
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Possibly your drums are way out of round, I would think you would feel that. Have you ever had them resurfaced? Jake's truck has a very bent backing plate causing shoe misalignment causing his brakes to stick, might look there also.
  15. Aug 1, 2016 at 10:42 AM
    #1535
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Because you need extended lowers. ;) just saying :D
  16. Aug 1, 2016 at 10:54 AM
    #1536
    Squeaky Penguin
    Brett
    No. I'd like to measure the diameter but don't think I have the proper tool. There's clearly a lip on the edge where they haven't worn.
    I still think it has something to do with the e-brake clicker wheel adjuster. I loosen it up, and can feel it tighten up as I use my e-brake. Just this last time I screwed the stop bolt way in so the bellcrank is further away from the backing plate, with the thought that would give it less throw, but not sure if that will accomplish anything.
    Also seems odd it started when I did the axle seals. More likely it has something to do with the shoes and new hardware I just put in than the drums that I didn't touch.
    But what good are extended lowers going to do me without extended uppers? :p
  17. Aug 1, 2016 at 3:24 PM
    #1537
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Booooooooooo BL :puke: looks good as is!
  18. Aug 1, 2016 at 4:32 PM
    #1538
    TBuzz
    Colorado
    Yes absolutely especially if you lower it that much. I did lower mine 10 threads, leaving 11 and 12 showing. It lowered the front a full inch. It now sits at 23" to my flares. Rides much better and the cv's are sitting more proper as well.
    Regarding alignment, I didn't get one b4 I drove it up the hills last Saturday. Scary as s,,, on the highway. It's got about 3degrees negative camber each side and I'm guessing 1 degree caster.
    dakotasyota and Delta00[QUOTED] like this.
  19. Aug 1, 2016 at 5:33 PM
    #1539
    dakotasyota
    Dakota
    Ellensburg, WA
    lol fuck that!
  20. Aug 1, 2016 at 9:53 PM
    #1540
    BrennMan
    BrennMan Well-Known Member
    01 TRD Access Cab (current) 07 PreRunner TRD (sold)
    5100s, Weather Tech, Wet Okole, 1.25" spidertrax, pop-lock, Bestopper
    I was driving through Steamboat today and spotted your truck. It looks just as great on the road as it does here. I knew I had seen it but couldn't place it (here/expeditionportal/etc).
    I'm from LA and just passing through, small world.
    Sweet rig!
    Squeaky Penguin[OP] likes this.
