Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Aug 4, 2016 at 10:11 PM
    #1541
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    What did you conclude from this. My axle does the same thing...maybe worse. That maybe why the rear seal keeps going out.
  2. Aug 7, 2016 at 7:34 PM
    #1542
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Sub. Great meeting you this weekend. I need to take care of my gears and come join you guys down south for a weekend.
    Edit: Love your @SCSPerformance Ray's !
    [​IMG]1-4 by Marc Mayer, on Flickr
  3. Aug 7, 2016 at 8:04 PM
    #1543
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    The new ones did the same thing to a lesser extent, but have been holding up great.
    I wouldn't bother changing axle seals and not do the bearing though. Often times the oil going through the bearing kills it, or a bad bearing is what causes the seal to leak. I.E. the seal isn't the main problem.
    Sweet shot of me wrenching on my pile! :D
    Lots of fun was had, glad we could meet up!
    [​IMG]IMG_0732 by brettbjorgum, on Flickr
    NYCO, TBuzz, Silver02Taco and 5 others like this.
  4. Aug 8, 2016 at 6:11 AM
    #1544
    cynicalrider
    cynicalrider #NFG
    Jersey
    Awesome photo!
  5. Aug 10, 2016 at 11:13 AM
    #1545
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Hey Brett do you have anything protecting your rear diff? I was looking at BAMFs but holy hell that price is expensive, not to mention it'll take up ground clearance and the bottom of the housing is already pretty stout. Just looking for options
  6. Aug 10, 2016 at 11:33 AM
    #1546
    Squeaky Penguin
    Brett
    I think they're a typical TW fanboy item. Take the lowest point on your truck and loose some more ground clearance.
    Bottom of the diffs are really stout, the only weakness I've found is the drain plug. I dragged the bottom so much I was starting to hit the plug. I've since welded a little piece of 1/2" solid bar to the bottom, and welded up around the ring. Another bunch of years grinding those down and I'll do it again.
    Now the back cover on the other hand is pretty thin, but I haven't had an issue. If you're concerned about backing it into a rock, get one of the weld on back covers from any one of the many vendors that sell them for like $50.
    dakotasyota likes this.
  7. Aug 10, 2016 at 12:05 PM
    #1547
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Haven't hit it yet but I'm sure I will eventually.
    Yeah that's what I was thinking, just only know of All-Pro and I think TG does one. Cool thanks
  8. Aug 10, 2016 at 1:30 PM
    #1548
    SconnieHailer
    Marc
    I bought mine because I drug my third across a rock and cracked the seal between the third and housing. Re sealed it and its been fine since but it's been nice knowing that won't happen again.
    jubei and Gramps like this.
  9. Aug 10, 2016 at 1:37 PM
    #1549
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    I like the factor of it's armored so I don't have to worry about it. The BAMF design does protect the pinion and actuator as well. But I believe these are 2nd gen problems that we have.
    Brett isn't the first gen housing thicker on the bottom then a second gen?
    jubei likes this.
  10. Aug 10, 2016 at 1:43 PM
    #1550
    SconnieHailer
    Marc
    Haha "second gen problems" don't admit it in Brett's thread man!
    Just pick better lines and you won't need it :p
    BYJOSHCOOK likes this.
  11. Aug 10, 2016 at 1:55 PM
    #1551
    Gramps
    Gramps
    07 TRD DC 4x4
    It's all good. Better for me to say it first before he brings it up. :D
    SconnieHailer[QUOTED] likes this.
  12. Aug 10, 2016 at 3:50 PM
    #1552
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I love cracking rocks with mine. Never have to worry about it ever.
    SconnieHailer likes this.
  13. Aug 10, 2016 at 5:18 PM
    #1553
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I'm with Brett, unnecessary item. In all the years, an armored diff cover is about all you need, mainly for Dana axles as the stamped cover is really thin. The bottom's are pretty darn thick on all the makes out there.
  14. Aug 11, 2016 at 10:51 PM
    #1554
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I did the same, but my bolts had come loose. I still don't think I will get a diff diaper. I had my stock third ground down to bare metal with no issues lol. I need to go retorque mine again cuz I have some dust stuck to the bottom of the diff at a glance and that concerns me. First time back on the trails with the resealed diff... I swear to god if it's leaking again...
  15. Aug 12, 2016 at 6:12 AM
    #1555
    SconnieHailer
    Marc
    Those bolts are only 18 ftlbs... I used fipg on mine as well as the paper gasket.
    dakotasyota[QUOTED] likes this.
  16. Aug 12, 2016 at 7:47 AM
    #1556
    Gramps
    Gramps
    07 TRD DC 4x4
    I am getting old so this is one way for me to get used to diapers. :D
    dakotasyota[QUOTED] and jubei like this.
  17. Aug 12, 2016 at 8:03 AM
    #1557
    SconnieHailer
    Marc
    I'm gonna make a Huggies logo to put on mine. Thanks for the idea :D
    jubei and Gramps[QUOTED] like this.
  18. Aug 19, 2016 at 5:25 AM
    #1558
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Mr. Brett,
    I may have missed it, how did you get the tubing horizontal between the frame rails in the back for the new upper shock mount?
    I can see no way other than to cut the tubing short and then fill in the gap with plate.
    Or remove the bed and spread the frame?
    Obviously a BFH is used at some point...
    Also, what size and gauge of tubing did you use?
  19. Aug 19, 2016 at 7:15 AM
    #1559
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    :popcorn:
    I think there were several botched attempts and a rayray involved :rofl:
    Deathbysnusnu[QUOTED] likes this.
  20. Aug 19, 2016 at 10:08 AM
    #1560
    Squeaky Penguin
    Brett
    That was the mid skid. Ray had the welder a little too hot when welding on the frame mounts.....
    The rest of the skid took a bit of tinkering as well.
    Pictures are worth a thousand words right?
    Step one is get a friend, it would be very difficult to do by yourself. Had a lot of help from James getting this crossmember in.
    Tubing came from Ray, so I'm not certain on what size it is but I think its 1.75"x1/8" wall HREW. The tubing was welded to some 3/16" plate donated from my old transmission skid, and then the plate was welded to the frame top and bottom. It was a little tight, so only light tapping to get it where I wanted it, but no BFH work. Had to cut off the factory drivers side shock mount. Removing the bed was not necessary for this project, but welding the top of the plate was a little tricky.
