Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Jan 7, 2017 at 5:34 PM
    #1781
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Not the ball slipping. It's the brackets rotating in the central circular portion.
    Mine came with the rubber thingy too.
  2. Jan 7, 2017 at 5:37 PM
    #1782
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  3. Jan 7, 2017 at 6:03 PM
    #1783
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Nice! What are you running for navigation?
  4. Jan 7, 2017 at 7:05 PM
    #1784
    Squeaky Penguin
    Brett
    It came with something like that, but I haven't tried it yet. I don't think it will prevent what I'm talking about though. Might be better if my tablet happens to be a little smaller. Once you compress the two sides quite a bit, the spring pressure is pushing on tablet, but not each other like in a static position. So it can now rotate the whole width of the open slot.
    I was reading about it, and it's just how it works, and there's some easy things to try to prevent it. Or, maybe it won't present an issue at all in application.
    Haven't gotten there yet. Need to do some more research on android apps for that.
  5. Jan 7, 2017 at 7:14 PM
    #1785
    Gramps
    Gramps
    07 TRD DC 4x4
    Yeah it's worth the research. HEMA is getting there but they still need some revisions for the US market. They are the #1 app in AUSTRALIA but needs another update for the US. I do like it's potential.
  6. Jan 7, 2017 at 7:16 PM
    #1786
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah I think I understand. Weird. Hopefully not an issue.
    I'm using BCN. Works well.
  7. Jan 7, 2017 at 7:34 PM
    #1787
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Link please.
  8. Jan 7, 2017 at 7:40 PM
    #1788
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
  9. Jan 7, 2017 at 7:45 PM
    #1789
    TBuzz
    TBuzz Well-Known Member
    Colorado
    00' 4runner, No Longer Stock
    Bumpers, Sliders, 33's, ADS f&r, budbuilt, home built belly and bumper, s/c, urd,4.88, arb's
    I haven't stepped up to nav in the truck yet. But I use Gaia on my phone when we are out hiking to little blue dots, works well for me and can be used in airplane mode.
  10. Jan 7, 2017 at 7:56 PM
    #1790
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    I used GPX viewer when I had an android phone. Still lost in the iPhone game...
  11. Jan 7, 2017 at 8:10 PM
    #1791
    Blackdawg
    Monte
    Wyoming/St. Louis
    You can run leadnav. Best offroad nav tool there is.
    But because you're an apple worshiper you get to pay to play for that haha
    alee891[QUOTED] likes this.
  12. Jan 8, 2017 at 6:38 AM
    #1792
    alee891
    Austin
    Black Hills
    Tacomaless
  13. Jan 8, 2017 at 10:30 AM
    #1793
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol Leadnav is pricey. $20 up front I think plus yearly map subscriptions I think now idk.
  14. Jan 8, 2017 at 10:42 AM
    #1794
    alee891
    Austin
    Black Hills
    Tacomaless
    I checked it out and like the looks of it. I'm going to wait to pull the trigger on an app that provides large downloadable files until I get a tablet. I don't need to be carrying that around on my phone all the time.
    Also, sorry for clogging up your thread, Brett. Good info nonetheless.
    Blackdawg[QUOTED] likes this.
  15. Jan 17, 2017 at 8:22 PM
    #1795
    Jacob032
    Jacob032 Well-Known Member
    Jacob
    I love your build! What tire size are you currently running?
  16. Jan 18, 2017 at 5:13 AM
    #1796
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    295/75/16
    Squeaky Penguin[OP] likes this.
  17. Jan 18, 2017 at 6:57 AM
    #1797
    Jacob032
    Jacob
    How much trimming is required to run that tire setup with no rubbing?
  18. Jan 18, 2017 at 7:58 AM
    #1798
    Squeaky Penguin
    Brett
    A lot. Everything short of tubbing really.
    I've cut off a majority of the wheel liner, most of the pinch weld, bottom edge of the fender and flare, and the little tab thing at the front of the fender. I've also taken a 5lb sledge and beat the firewall back about as far as it will go, as well as a few spots in the top/front of the wheel well that were rubbing. Washer fluid reservoir relocation is necessary too. I also had to cut the fender and flare on the front edge of the rear wheel wells.
    dakotasyota likes this.
  19. Jan 28, 2017 at 5:54 AM
    #1799
    Jacob032
    Jacob
    How big of a pain in the ass is it to run a camper shell and a tire swing out? I am looking to build on on my rear bumper. Any ideas or assistance would really be appreciated. Pictures or links would be amazing! Thanks
  20. Jan 28, 2017 at 8:50 AM
    #1800
    Squeaky Penguin
    Brett
    What are you concerned about being a pain in the ass? Not really any different with a topper than without.
    I didn't make my rear bumper, but I have messed with it quite a bit. There's lots of people much more knowledgeable than me than swingouts. One thing I will mention, is start with a hinge and work your way out. I had a typical trailer spindle setup and it broke. Now running an 1.25" grade 8 bolt as my pivot with bronze bushings pressed into a piece of DOM tubing. Problem here is my bushings are shot after a year and half or so. Only $10, but a bit of hassle. Some of the other fab shops on here have had success with single sheer spindles, not sure where they're sourced from.
    One thing I would strongly consider, and might do at some point to mine, is make it a dual swingout. Adds cost and complexity, but less stress on the pivots. When I'm loaded up with my heavy spare tire, and 10 gallons of gas, it really sags and pulls that whole side of the bumper/frame/truck down with it when open.
