Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Feb 13, 2017 at 1:34 PM
    #1821
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Brett when you did your rear brakes, i remember you saying OEM pads only. Did you do OEM drums too?
  2. Feb 13, 2017 at 2:08 PM
    #1822
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You might be getting me confused with Old Brett, as he runs OEM shoes. I had issues this past year and never tracked down exactly what it was. Putting a lot of the blame towards the Wagner shoes and hardware kit as that was the only real change after doing the rear axle seals.
    I just installed NAPA shoes, drums, and hardware a couple weekends ago in hopes of fixing my problem. Only driven the truck a couple miles since then though, so no feedback yet. Before they got soaked in gear oil, I had NAPA premium shoes for like 60K miles and they were working great.
  3. Feb 13, 2017 at 2:23 PM
    #1823
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well i won't mine buying OEM shoes. But i wouldn't mine not having to run OEM drums. Would make rear brakes a $400 project.
    What say you old man Brett? @Star-Lord
  4. Feb 13, 2017 at 3:46 PM
    #1824
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I've always run parts store brakes on the rear of my 4Runner and Tacoma without any issues fwiw
  5. Feb 13, 2017 at 5:05 PM
    #1825
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    OEM shoes for sure, I've had much better luck with them.
    Are you needing to replace the drums too? I asked about that at the dealer here, and they said they have yet to sell a set. They seem to last a long time.
    I tried a set of O'REILLY shoes at first, they didn't grab well with the e-brake.
    When I did the bpv upgrade, I went and changed the shoes to OEM. The difference is huge, there is much more pad on the surface compared to the aftermarket. E-brake works great now. I need to pull the drums, it's been almost a year, and see what kind of wear I have.
  6. Feb 13, 2017 at 5:14 PM
    #1826
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm pretty sure my driver side drum is fucked up. have a bad vibe and sound from that side.
    I'll order some OEM pads and pull the drums and if i need a new drum just get a Napa one it sounds like.
    Thanks Brett(s)
    Deathbysnusnu[QUOTED] likes this.
  7. Feb 15, 2017 at 5:06 PM
    #1827
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Brett is it possible you could provide some photos of the table you installed on your bumper at the end of last year? I recall seeing a couple photos during the initial install, but I'd like to see it with a little more detail if available.
  8. Feb 15, 2017 at 6:50 PM
    #1828
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Just curious while we on the subject. Is general consensus to replace or resurface drums every time like rotors?
  9. Feb 15, 2017 at 7:03 PM
    #1829
    Squeaky Penguin
    Brett
    I'll try to remember to grab some tomorrow morning. It's just 3 little hinges welded to some light gauge steel. A wingnut to hold it closed, and some cable to hold it open.
    They probably should be turned when shoes are replaced. Which isn't all that often if everything's working correctly. My old drums had a lip on the inside that made taking them on and off a pain. Didn't measure if they had enough material on them to resurface.
    alee891[QUOTED] likes this.
  10. Feb 15, 2017 at 10:18 PM
    #1830
    dakotasyota
    Dakota
    Ellensburg, WA
    Gotcha. Do they get high risk of warping after that like discs do? Or not so much since they do so little braking?
  11. Feb 16, 2017 at 9:43 AM
    #1831
    dbcorvairracer
    dbcorvairracer Well-Known Member
    1999 Supercharged Taco
    TRD Supercharger, 7th Injector, Light bar, Recaro heated seats
    One thing to think about when turning drums depending on how worn the drum is and how much is taken off during turning is the arc of the shoe vs. the arc of the drum. You can get into a situation where for some period of time you are only braking on a small area of the shoe which I believe typically ends being the trailing edge of the shoe the way that things shift with the drum pulling in the forward direction of travel. I have not turned a set of drums in quite a while but the NAPA auto parts I used would also arc the shoes. they would basically grind some material from the shoe, mostly at the center and tapering towards the leading and trailing edges to match the arc of the shoe to the new arc of the drum. This was probably more important when doing drums on vehicles with 4 wheel drum braking systems as you really need everything working perfectly and evenly so the car doesn't pull or dart one direction or the other under braking.
    Just something to think about. Great build by the way!
    dakotasyota and Holy schmidt like this.
  12. Feb 20, 2017 at 2:44 AM
    #1832
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I was turned on to your thread from looking into replacing a leaky axle seal and a bad bearing in my truck. It's got the axle from your model / year truck and I noticed that you replaced the bearing and axle seal sometime last year. Have you had any issues from it since then? I like your truck - it's quite similar to how I would like mine to be when it's all set up :)
  13. Feb 20, 2017 at 8:08 AM
    #1833
    Squeaky Penguin
    Brett
    Less braking, more metal. I think it would be hard to warp them.
    That makes sense, never heard of anyone doing it though.
    They've been holding out perfectly. Not a drop of oil past the seals.
    @alee891 I might remember to take a picture of my table one of these days.
    alee891 and dakotasyota[QUOTED] like this.
  14. Feb 20, 2017 at 8:19 AM
    #1834
    alee891
    Austin
    Black Hills
    Tacomaless
    I'm in no rush. Just want to see what I can set my beer on this spring :)
  15. Feb 25, 2017 at 7:03 PM
    #1835
    Squeaky Penguin
    Brett
    @alee891 here's all it is:
    [​IMG]IMAG0177 by brettbjorgum, on Flickr
    Anyways, getting closer to wheeling season got me motivated to start working on this pile. Got some frame boxing plates on the way, and want to redo the rear shocks, so I got the truck pulled in the garage and bed off. Thanks @Night Eagle for the help!
    Just don't let Leo close to your rig with a sawzall:
    [​IMG]IMAG0178 by brettbjorgum, on Flickr
    My shock crossmemeber prevented us from getting the factory spare tire crossmember out, so it got cut out.
    Anyways, got it up on jackstands, and drooped out the leaf pack for interest sake. Pulled the keeper bolts out to see what that did to droop too. Will be cycling and measuring for shocks shortly.
    [​IMG]IMAG0180 by brettbjorgum, on Flickr
  16. Feb 25, 2017 at 7:12 PM
    #1836
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    2014 TDR Off Road
    Enough to make it a lot of fun!
    Just a disclaimer Brett handed me the sazawl and said do you want to cut the cross member and I said yes.
    Deathbysnusnu and Dalandser like this.
  17. Feb 25, 2017 at 8:31 PM
    #1837
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    :popcorn:
  18. Feb 26, 2017 at 6:02 PM
    #1838
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Leo your doing it all wrong. Your suppose to cut down right behind the cab :D
  19. Feb 27, 2017 at 8:36 AM
    #1839
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    What are you thinking for shocks?
  20. Feb 27, 2017 at 8:46 AM
    #1840
    alee891
    Austin
    Black Hills
    Tacomaless
    Just doing mountain people things...
