Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Feb 27, 2017 at 9:12 AM
    #1841
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    That popcorn is going to be fairly stale by the time I finish this up.
    But I like my frame and bed the way they are.
    2.5x?? resis. ADS if the lead time fits my needs, otherwise King. Got the leafs off yesterday, might be able to cycle tonight.
  2. Feb 27, 2017 at 9:33 AM
    #1842
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I'm rethinking how I'm going to eventually mount my rear shocks. Like a dumbass, I bought shocks first in a rush, instead of breaking down the Expos and cycling just the main leaf to get actual numbers.
    I really want to get the most out of my MT rear, so I'm thinking seriously about going thru the bed if I have to, and/or outside the frame. If push comes to shove, I'll buy new shocks that make the most of the leaf pack I have.
  3. Feb 27, 2017 at 12:03 PM
    #1843
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Brett, are you still running the Rack Dr. or did you replace it with OEM? Mine has developed a clunk, indicating it wants to get thrown in the trash. Have any input on CVJ, or just bite the bullet and call up Toyota?
  4. Feb 27, 2017 at 12:13 PM
    #1844
    Squeaky Penguin
    Brett
    Curious to see what the Expo's cycle. Don't think I've read of anyone else doing that.
    Given some preliminary measuring, I'm afraid the springs will give less travel than I had hoped. Will find out for sure tonight. Don't see how any SOA pack on stock mounts would require going through the bed. Outboard is fine if you have room, I don't.
    Yes, and there's play in the ITREs and it leaks. Haven't read anything about CVJ reman racks, but I have been very happy with my CVs.
    If you shop around you can get a new OEM rack for around $500, I think that's what I'm going to do.
    jubei[QUOTED] likes this.
  5. Feb 27, 2017 at 12:29 PM
    #1845
    alee891
    Austin
    Black Hills
    Tacomaless
    I'm looking around right now - waiting for a little more input on CVJ if I can get it, otherwise I'll likely be going the OEM route.
  6. Feb 27, 2017 at 2:31 PM
    #1846
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    no way you'll have room with 35s to do shocks outboard the frame. not without a wider axle.
    the more i get into these trucks and the more mine age...the more i like OEM parts. Most things i think should be replaced OEM if you can afford it. Somethings don't but most i feel can and should be. The OEM parts have lasted this long..
    Gramps likes this.
  7. Feb 27, 2017 at 3:33 PM
    #1847
    alee891
    Austin
    Black Hills
    Tacomaless
    Judging from the cost of CVJ, the difference is ~$150 as compared to OEM - not a factor in this case. I'm waiting for an update on CVJ before I make my decision, but I'll definitely take your advice and run with it.
  8. Feb 27, 2017 at 5:51 PM
    #1848
    cjspencer9
    cjspencer9 Well-Known Member
    Chad
    carlsbad
    2017 White DCSB 4x4 OFFROAD
    TRD pro Grille Import equipment decal Front suspension: Total chaos mid travel suspension with king coils Rear suspension: Total chaos spring under axle with extended hoop and king 10" bypass with reservoir. Synergy wheel spacers VTX terra wheels in bronze. Bfg KO2 285 75 16 All pro Pack rack CVT pioneer tent baja design squadron sport fogs (amber) Pelfeybilt rock sliders front runner slimline II roof rack
    How do you like the AP bumper?
  9. Feb 27, 2017 at 5:51 PM
    #1849
    cjspencer9
    Chad
    carlsbad
    Snorkel work well?
  10. Feb 27, 2017 at 8:49 PM
    #1850
    Squeaky Penguin
    Brett
    Not the best looking bumper, but it's held up really well. Lots of winching and smashing into rocks.
    No complaints. Price was right.
  11. Feb 27, 2017 at 8:59 PM
    #1851
    Squeaky Penguin
    Brett
    Just finished working on this pile. First off, think I needed new shackle to frame bushings?
    [​IMG]IMAG0181 by brettbjorgum, on Flickr
    Second off, Ray is the man!
    [​IMG]IMAG0183 by brettbjorgum, on Flickr
    And down to the brass tacks:
    [​IMG]IMAG0185 by brettbjorgum, on Flickr
    [​IMG]IMAG0186 by brettbjorgum, on Flickr
    Absolute full droop. Shackles are about to invert, way more travel than could be obtained in use.
    [​IMG]IMAG0187 by brettbjorgum, on Flickr
    On the bump stop, these were setup to work with my last half-ass shock setup, not the springs. Springs are way the hell negative, and bumps would compress an inch or so more in use. Couldn't compress them without lifting the truck.
    [​IMG]IMAG0188 by brettbjorgum, on Flickr
    [​IMG]IMAG0189 by brettbjorgum, on Flickr
    And just for fun:
    [​IMG]IMAG0190 by brettbjorgum, on Flickr
    So, looking at less than 10" of usable travel. Might be time for plan B. Not sure I want to put the time and effort into this leaf pack.
  12. Feb 27, 2017 at 9:07 PM
    #1852
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nice bushings haha wow.
    And what's plan b?
  13. Feb 27, 2017 at 9:27 PM
    #1853
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    So ideally a 9" travel shock would be perfect more or less? Cycling makes much more sense after the explanation from Monte a while back and these pictures. Thanks Brett. Looking forward to what you are going to do!
  14. Feb 27, 2017 at 9:33 PM
    #1854
    Squeaky Penguin
    Brett
    Haven't got there yet. Disappointed with those travel numbers though. Wish there was more info on what some other SOA packs cycled.
    Given my main spring, 9" is probably pretty close to absolute max usable travel. Therefore, a 10" shock, if setup perfectly, would give just a bit of wiggle room on either side. Key is matching the shock placement to the travel of the spring.
  15. Feb 27, 2017 at 9:34 PM
    #1855
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea, i've never cycled mine. Was hoping to this summer for fun. But my leafs are shorter...so...can't be any better even with the longer shackle.
    SUA doesn't seem bad now..but..also..not ideal.
    why im leaning towards links i think.
  16. Feb 27, 2017 at 9:43 PM
    #1856
    TacoVio
    Kolton
    CO/WY
    Gotcha. Yeah shock placement is where im a bit weary with my truck, escpecially with my dakars. Ill have to tear it apart this spring and start measuring
  17. Feb 28, 2017 at 5:35 AM
    #1857
    Moosedog
    Moosedog Well-Known Member
    Bryan
    Harrisburg, Or
    99 tacoma SR5 TRD v6
    kings, dakars, relentless front bumper, NWTI rear bumper
    Hey there Mr squeaky, I noticed in your last pic at full droop, your locker actuator harness is banjo tight. I only noticed this because I just cycled my new dakar pack. I removed the bracket on the gas tank and used a wire loom clamp instead. It lowered it enough to gain some slack in the wire.
  18. Feb 28, 2017 at 7:37 AM
    #1858
    cynicalrider
    cynicalrider #NFG
    Jersey
    Question about the usable travel. If you got a slightly longer shackle you could potentially net more travel right? But then shackle angle is compromised at ride height correct?
  19. Feb 28, 2017 at 8:01 AM
    #1859
    Squeaky Penguin
    Brett
    Wish there was a SUA lite like the TC kit for 2nd gens. Don't need that much travel with shocks through the bed, but would like more than these are giving me.
    Thank's for heads up! :thumbsup: I'll dig up a wire loom clamp and change that out.
    What did the Dakars cycle?
    Don't think so. At full droop the axle would be lower by the additional length of the shackle, but it the springs would also go negative sooner. It doesn't appear that the stock shackles are hindering the leafs.
  20. Feb 28, 2017 at 8:18 AM
    #1860
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea be nice for sure.
    Could always try doing a setup like that with some custom leafs and shocks. You'd want custom leafs anyways to take the weight.
