Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Feb 28, 2017 at 7:05 PM
    #1881
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Depends on the angle of the shackle. If perfectly at 45°, it's a 2:1 ratio of increased shackle length to lift height.
  2. Feb 28, 2017 at 7:05 PM
    #1882
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    My longer shackles have worked amazing....different leafs completely but still..
    Smart choice I think. Keeps the rig very versitle.
  3. Feb 28, 2017 at 7:14 PM
    #1883
    Squeaky Penguin
    Brett
    Just need to find, or make, 1" longer shackles. 2" longer (1" lift) gave more droop yet, but had quite a bit more negative arch. Probably still work though, just would need to raise the bumps. Might be detrimental to shackle angles too.
  4. Feb 28, 2017 at 9:45 PM
    #1884
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh right. Hard to find that length. Yea could just make some.
  5. Mar 4, 2017 at 5:45 PM
    #1885
    Squeaky Penguin
    Brett
    One side down. Ran out of gas about 3/4 of the way through the 2nd side.
    [​IMG]IMAG0194 by brettbjorgum, on Flickr
  6. Mar 4, 2017 at 7:25 PM
    #1886
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    How do you like that pack with the two added leafs?
    Looking like I'm going to go that route
  7. Mar 4, 2017 at 7:29 PM
    #1887
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Looking good, Brett! I'm gonna copy you at some point.
  8. Mar 4, 2017 at 7:55 PM
    #1888
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Is it plausible to mount a shock up in the bedside? I'm guessing longer axle would be necessary and maybe cut into the bed a smidge. They would likely end up like \ /. Just throwing it out there without looking at the truck.
  9. Mar 4, 2017 at 7:56 PM
    #1889
    Blackdawg
    Monte
    Wyoming/St. Louis
    jesus, where did you learn to weld :luvya:
    alee891 likes this.
  10. Mar 4, 2017 at 8:00 PM
    #1890
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Brett's center for kids who can't weld good and want to learn how to do other stuff good too.
  11. Mar 4, 2017 at 8:20 PM
    #1891
    Squeaky Penguin
    Brett
    Probably overkill to have the plates and boxed, but can't hurt either.
    Not quite sure I understand what you're thinking, going inside the frame but angled them out? Think you would have to cut quite a bit of the bed, and the lower mounts would have to be pretty far inboard to clear the frame. Wouldn't be an effective solution for shock performance.
    :brianr: I'm learning.
    There was a few tricky spots that make it look messier than it is, but overall I was happy with how it welded up. Not the easiest thing to weld. Regardless, those plates aren't going anywhere.
    jubei[QUOTED] likes this.
  12. Mar 4, 2017 at 8:28 PM
    #1892
    Reh5108
    Idaho
    Outside of the frame. Tire would probably be in the way unless you have some crazy backspace
  13. Mar 4, 2017 at 8:35 PM
    #1893
    Reh5108
    Idaho
    I'm sure someone would have done it by now if it was reasonable
  14. Mar 4, 2017 at 9:11 PM
    #1894
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I attended there :anonymous:
  15. Mar 4, 2017 at 9:18 PM
    #1895
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    What kind of gas are you using? Just wondering.
  16. Mar 4, 2017 at 9:26 PM
    #1896
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    What exactly gives you the impression that he has learned to weld?
  17. Mar 4, 2017 at 9:31 PM
    #1897
    jubei
    NoCo
    Stuff. Also things.
    Overkill, you say?
    I'm all about overkill!
  18. Mar 5, 2017 at 9:26 AM
    #1898
    Squeaky Penguin
    Brett
    Yeah, don't see that working without a wider axle, and even then, not sure why you would want them angled.
    75/25
    :brianr: At least I didn't burn any holes in the frame like some other individuals who have welded on my truck. :p
  19. Mar 5, 2017 at 12:07 PM
    #1899
    Blackdawg
    Monte
    Wyoming/St. Louis
    so you're not at a 1:1 lever ratio. Much easier to tune a shock if the shock shaft speeds aren't exactly the same as the axle.
  20. Mar 5, 2017 at 8:42 PM
    #1900
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Can't tell what I am looking at here, is it boxed now?
