Squeaky pulley?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boxxed, Oct 18, 2022.
  1. Oct 18, 2022 at 12:23 PM
    boxxed
    boxxed [OP] Well-Known Member
    Denver, CO
    09 Off Road
    Is there an easy way to tell which one it is?
  2. Oct 18, 2022 at 12:42 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    When one of mine started squeaking I could tell which one it was, But I changed all of them out. I figured if one was starting the others probably weren't far behind. While I was in there I also did my water pump since I already had that much pulled apart it made it easy to get to. I have the 4.0 motor.
    steveo27 and ryfox0276 like this.
  3. Oct 18, 2022 at 12:44 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Long rod like a dowel or broom handle, stick to each pulley and listen on the other end.
    Or take the belt off and turn them each by hand.
    MARSHBUSTER and boxxed[OP] like this.
  4. Oct 18, 2022 at 12:48 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Use a dowel rod or long screwdriver as a stethoscope and listen to each one.
    my advice, if it’s a tensioner squeaking, it’s probably time to replace em all.
  5. Oct 18, 2022 at 12:49 PM
    boxxed
    Denver, CO
    09 Off Road
    Ok, I replaced the water pump once already. I can get all of them and replace them I suppose.
    Thanks.
  6. Oct 18, 2022 at 12:54 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    I had done the water pump also about 75,000 miles ago. But I thought why not do it since I was in there and it was exposed. I also did the serpentine belt while I was doing everything else at the same time on the front end.
  7. Oct 18, 2022 at 12:56 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    While not always 100% accurate.
    Pulling the belt and spinning each by hand has given me over a 90% success rate.
    MARSHBUSTER likes this.
  8. Oct 18, 2022 at 12:57 PM
    boxxed
    Denver, CO
    09 Off Road
    I am about right there with you. I have not replaced a water pump it in a long time and i was on a differen car. Not how I was planing on spending my weekend. UGH!!
    MARSHBUSTER[QUOTED] likes this.
  9. Oct 18, 2022 at 1:01 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Yep, if the pulley bearings have 100K or close to it, replace them all as preventive maintenance. You may find the tensioner pulley only comes as a whole unit. The bearing itself can be replaced with a quality bearing. Febest offers a Chinese-made pulley/bearing. See rodavictoriausa for bearing replacements, for idler and tensioner bearings. The Febest is on Amazon.
    My DIY link for replacing the bearings if your pulleys are in good shape and you have the tools.
    https://www.tacomaworld.com/threads...arings-in-the-idler-tensioner-pulleys.480961/
    TnShooter likes this.
  10. Oct 18, 2022 at 1:04 PM
    boxxed
    Denver, CO
    09 Off Road
    Thanks for that info.. I am going to buy OEM parts. I should have all the tools. Is there anything specific you need to replace them?
    This site gives me all the numbers. http://japan-parts.eu/toyota/us/200...4_416W/tool-engine-fuel/1601_water-pump#16604
  11. Oct 18, 2022 at 1:07 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    You can drive with a noisy bearing for a looooong time.
  12. Oct 18, 2022 at 1:08 PM
    boxxed
    Denver, CO
    09 Off Road
    Ya.. It just started.
  13. Oct 18, 2022 at 1:08 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    boxxed[QUOTED][OP] likes this.
  14. Oct 18, 2022 at 1:12 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    Mine started to make noise on a Monday afternoon, I did the work on a Sunday. The one pulley that was the worst was probably close to locking up. Now I don't have very good hearing so it might have been squeaking for awhile and I just didn't hear until it got worse?
    boxxed[OP] likes this.
  15. Oct 18, 2022 at 1:38 PM
    Chuy
    Lakeside, CA
    Silver Taco
    If you are getting oem, they only sell the pulley/bearing combination, thus no special tools needed. However, Toyota does not sell it for the tensioner, but they will happily sell you the tensioner assembly. Some folks have bought it then swapped pulleys. The other options are buying just the bearing, or the Febest pulley/bearing.
  16. Oct 18, 2022 at 2:33 PM
    boxxed
    Denver, CO
    09 Off Road
  17. Oct 18, 2022 at 2:38 PM
    TnShooter
    Deogee
    STOCK
    Can I ask how many miles are on your truck?
    And why are you replacing the water pump?
    I Personally don’t consider the pump on these truck a preventative maintenance item.
    I’m sure others will disagree, but I’m waiting until I have a real reason to replace mine.
    burrito782 likes this.
  18. Oct 18, 2022 at 2:46 PM
    boxxed
    Denver, CO
    09 Off Road
    Its an 09 with about 180ish miles.. Its in great shape, the frame was replaced would 2 years ago, cab mounts, engine mounts. Also the break lines and several other things. I am the original and the truck runs great. But I have always stayed on top of stuff like this.. I dont have to replace the water pump.. Its been done once alread but that was about 7 years ago now that I am thinking about it.
    I look at it more once I get home, I noticed the pulleys making noise on my way back from lunch..
    Thank you..
    I think I need this one: https://parts.stevinsontoyotawest.com/p/62999468/16604-0P011.html
    Not 2 of the other one.
    TnShooter[QUOTED] likes this.
  19. Oct 18, 2022 at 2:49 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    use a piece of tubing and listen to each one with it
  20. Oct 18, 2022 at 2:51 PM
    boxxed
    Denver, CO
    09 Off Road
    I will do that.. I wasnt looking forward to spending more money and time right now..
    Thanks
