squeaky springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kasey200, Jun 3, 2008.
  1. Jun 3, 2008 at 10:16 AM
    kasey200
    kasey200 [OP] Well-Known Member
    south dakota
    07 TRD Dboubl Cab Longbed
    3" toytec, 285 BFG AT's
    The rear leafs or bushings of my truck squeak REALLY bad. does anybody else have this issue. It makes my 07 sound like a 87. It drives me crazy. Any suggestions???:confused::confused: I was thinking about soaking them with a liquid wrench or some type of penetrating oil.
  2. Jun 3, 2008 at 11:26 AM
    Batman7593
    Batman7593 New Member
    Texas
    07 Tacoma SR5 Double Cab SB 4x4 TRD
    Factory Borla intake/exhaust system
    I'm experiencing the same issue, but can't figure out if it's the shock bushings or crap in the the leaves.
    I've had similiar issues on other trucks (especially GM :mad:) and soaking them with lube will only last a few days.
    From what I'm hearing from other owners, it may need to be a TSB. I'm thinking of just taking it in to the dealer.
  3. Jun 3, 2008 at 11:30 AM
    famousfernando
    famousfernando Well-Known Member
    oregon
    2007 tacoma trd package 6" fabtech l
    theres a little bolt that the leaf springs rub on i just sprayed some WD40 on it and it was fine hope this helps
  4. Jun 3, 2008 at 1:11 PM
    GunMetalSteak
    GunMetalSteak Active Member
    LA, CA
    07' PreRunner SR5
    Hood scoop, side steps.
    i also have this issue on my 07 DC. but its not loud and its not every time. I haven't really investigated, but it is annoying when it happens.
  5. Jun 3, 2008 at 6:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    When I have a squeek, I have three steps to attack it. Assuming all is installed propperly.
    1. WD-40-works good but wears off
    2. PB Blaster-Best lube on Earth! Works on almost ALL squeeks, and kills ants!
    3. When all else fails and the dam squeek is stil there, I hit it with some break fluid. DO NOT GET ON PAINT. Anytime I have used this, the sqeek has never returned. :cool:
  6. Jun 4, 2008 at 2:46 PM
    Batman7593
    Texas
    Just got back from the Toyota dealer. They did a search and found (2) TSBs for issues I'm experiencing with my truck. Here's the data:
    TSB-SU012-07 - Rear suspension squeak
    TSB-NV006-07 - Windshield noise at highway speeds (VIN specific)
    Check with your dealer and have them fix it!!:):):)
  7. Jun 4, 2008 at 3:00 PM
    kasey200
    south dakota
    awesome, good work and thank you!
  8. Jun 4, 2008 at 8:26 PM
    6taco
    6taco Active Member
    Florida
    06 taco 4x4 DC 2'' lift, MB Razors, 32s, tint
    lift, wheels, tires, bull bar, off road lights, tonneau cover, tint, system, interior lights
    My rear leaf springs squeak after the TSB has been completed. I tried spraying the bushings with white grease and it still squeaks. It is very annoying.:mad:
  9. Jun 4, 2008 at 8:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Another member had this happen and it turned out that the idiots at the shop installed a bolt incorrectly. Check for rubbing near your spring hangers. :)
  10. Jun 4, 2008 at 9:34 PM
    6taco
    6taco Active Member
    Florida
    Yeah I just fixed it they installed the bolts way too tight. I loosed the bolts and sprayed some white grease and now it is fixed. Thanks for the reply.:D
    Now my $30,000 truck doesn't sound like a rusted out crap box.
  11. Jun 5, 2008 at 1:33 AM
    newbie
    newbie New Member
    HI
    K&N intake, gibson exhaust
    I have the same problem on my '05 2wd when I go over speed bumps. Had the mechanics check it out, and he said everything was fine. I'll try some wd-40.
  12. Jun 5, 2008 at 3:32 AM
    ccrnr77
    ccrnr77 New Member
    TRD Offroad
    My rear leafs squeaked something terrible immediatley following the harsh ride TSB install. Upon further investigation, I found that the dealer installed one of the mounting bolts backwards. The bolt was rubbing against the frame causing the squeak. I took it back to the dealer, they apologized and fixed the problem. Not that this is the case for any of you having a squeak issue, but if you just had the TSB done, I would take a look at the bolts. :)
  13. Jun 5, 2008 at 7:42 AM
    6taco
    6taco Active Member
    Florida
    Yeah on my truck it wasnt just one side it was both sides. It sounded like someone was having sex in the bed of my truck.:bananadance:
  14. Jun 5, 2008 at 12:06 PM
    kasey200
    south dakota
    i got my hands on the tsb mentioned above and according to that, the problem is the silencer pads between the springs are dry and need to be lubed
