Squeaky suspension
Discussion in 'Suspension' started by Lifted450, Sep 2, 2018.
  1. Sep 2, 2018 at 4:26 PM
    Lifted450
    Lifted450 [OP] Well-Known Member
    SirSmoksAlot
    2017 Tacoma OR 4x4 LB
    Noob question
    Took my dclb 4x4 (totally stock) off roading yesterday on some mild trails and when I got home I noticed my front driver and rear pasanger suspension were squeaking. I figure it's dust so I just sprayed it off under there. The rear squeak is coming from the front leaf spring bushing. I'm wondering if after washing it off should I hit it with some wd40 or some silicone spray??? Not really sure of the difference between the 2. And advice would be greatly appreciated
  2. Sep 3, 2018 at 1:37 AM
    jtifm
    jtifm Well-Known Member
    2017 TRDORDCSB
  3. Sep 3, 2018 at 4:23 PM
    urmaker45
    urmaker45 Well-Known Member
    Brad
    Wise, va
    2017 tacoma trd offroad
    Mine keeps popping in at a loss
  4. Sep 3, 2018 at 4:34 PM
    Lifted450
    SirSmoksAlot
    Popping on at a loss???
  5. Sep 3, 2018 at 4:36 PM
    urmaker45
    Brad
    Wise, va
    I ment I'm at a loss lol
  6. Sep 3, 2018 at 4:38 PM
    Lifted450
    SirSmoksAlot
    Ok?
  7. Sep 3, 2018 at 4:39 PM
    JaCado
    JaCado I make bad choices
    Front or back? Driver or passenger?
  8. Sep 3, 2018 at 4:41 PM
    urmaker45
    Brad
    Wise, va
    Front the rear is fine
    JaCado likes this.
  9. Sep 3, 2018 at 4:42 PM
    JaCado
    There is a tsb for the rear leaf springs.... they will add isolator pads (small flat disc) to the ends. The fronts have known have bad body mount bushings a d radiator bushings.
  10. Sep 3, 2018 at 4:43 PM
    urmaker45
    Brad
    Wise, va
    Thanks I'll check the body mounts
    JaCado likes this.
  11. Sep 3, 2018 at 4:44 PM
    JaCado
    That pop could be that the shocks are not tightened down enough and also the c clip on the lower ball joints could be coming loose when suspension unloads and reloads. Other things could be the sway bar coming in contact with the coil spring.
  12. Sep 3, 2018 at 5:08 PM
    Outdoorsy_Yota
    Outdoorsy_Yota Hella-Known Member
    duhbondo JIW Local 378
    Bay Area
    17 DCLB TRD OR LOL
    I’ve accepted the squeeking... Stock, she was pretty good... minor creaks and minimal to none on roads.
    Dakar leafs?! I sound like a U.N. War Relief truck on trails and pulling into gas stations :notsure:
    WD40 works only for a week or two...
    m603holden and Matmo215 like this.
  13. Sep 3, 2018 at 5:17 PM
    KILLINTIME
    KILLINTIME Forty Six & 2
    SOUTH CAROLINA
    06AC4wd 18T4R4wd
    Dude no shit I even replaced my bushings on my Dakar’s and they still squeak. Really pisses me off. I squirt pb blaster on them every couple months that fixes the squeak, but shouldn’t have to babysit $400 dollar springs. Won’t be buying them again.
    Outdoorsy_Yota likes this.
  14. Sep 3, 2018 at 5:19 PM
    Outdoorsy_Yota
    Bay Area
    17 DCLB TRD OR LOL
    Yeah, Its the isolator pads inbetween... I spray em and they quiet down for a couple weeks... I’m coming from a YJ... so I don’t care, I do it to keep my wife happy LOL
    KILLINTIME likes this.
  15. Sep 3, 2018 at 5:30 PM
    JoeCOVA
    JoeCOVA IG @MightyJoeFlannel
    Joe
    Colorado Springs
    2017 DCSB TRD OR
    35" Trepadors w/ OMF Beadlocks, Kings, OBA, 5.29s etc
    When I bought my Deavers i disassembled the pack and used multipurpose NGLI #2 on the pads and around the center bolt. For the bushings I used white lithium NGLI #2. No squeaks.
    WD40 is better at cleaning than lubricating.
    If you want the squeaks gone pull the pack and grease it.
    m603holden likes this.
  16. Sep 3, 2018 at 6:05 PM
    Lifted450
    SirSmoksAlot
    it's coming from the front bushing on the leaf springs not the actual leaf pack. Should I use a grease over a lube for that?
  17. Sep 3, 2018 at 6:07 PM
    JoeCOVA
    Joe
    Colorado Springs
    2017 DCSB TRD OR
    If you can get the grease in there I would. Might be able to lift the truck unload the leaf and pop the bolt out.
    Silicone lube I think will just be a temp fix
    mcharfauros likes this.
  18. Sep 4, 2018 at 12:58 AM
    jtifm
    2017 TRDORDCSB
