Squeaky suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SNThorsen, Jun 14, 2010.
  1. Jun 15, 2010 at 5:06 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    ^^ wouldnt mind seeing that at all.
  2. Jun 15, 2010 at 5:25 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    x2. No rush though.
  3. Jun 15, 2010 at 5:43 PM
    beachbumberry
    beachbumberry Well-Known Member
    andrew
    fl now, tx native
    05 sr5 4x4 access cab
    leveling kit, american racing rims, push bar, nerf bars
    dependent on my lighting situation i'll get it done after dinner. i think there are some portable spotlights somewhere in this house
  4. Jun 15, 2010 at 9:21 PM
    beachbumberry
    andrew
    fl now, tx native
  5. Jun 15, 2010 at 9:30 PM
    snowgod06
    Rob
    06 Access Cab
    dude you rock! 29 posts and already i vote that this become a sticky!! good work. I'm going to try this soon to fix my squeaks.
  6. Jun 15, 2010 at 9:41 PM
    beachbumberry
    andrew
    fl now, tx native
    thanks man i appreciate it! i'll keep posting stuff up as i do it.
  7. Nov 17, 2012 at 6:29 PM
    2011DBLcabsport
    2011DBLcabsport Active Member
    North Florida
    Toyota
    JL speakers, hose-clamp tailgate, key chime delete, Rancho RS9000xl rear shocks
    Came across this thread awhile back and forgot to post when i got mine fixed...
    I took mine to the dealership multiple times and they greased them and told me they were working on a fix. They finally found one and inserted small rubber discs in-between the leafs. No more squeak.
  8. Nov 17, 2012 at 7:05 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Sadly for some this is only a bandaid to the problem. In my case the leaf pack has nylon spacers between all the leafs but it still squeaked regardless of terrain below the rubber. The cause for the squeak for my truck was caused by incorrect clamping pressure from the U-bolts my axle shows wear due to it. All is good now but I figured I should share a little wisdom.
  9. Mar 25, 2015 at 10:44 AM
    RNGRCaldera
    RNGRCaldera Well-Known Member
    Georgia
    14 AC TRD
    off road tires,toolbox, tinted window,Allpro Apex bumper, Toytec 3" suspension lift, Cb radio and firestik, 20" light bar.
    what is the correct pressure for the u bolts?
  10. Mar 25, 2015 at 10:58 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    the guide incorrectly says 37 ft/lb but i think most say that should be reversed to 73 ft/lb.
  11. Apr 25, 2017 at 12:03 PM
    LFOSTGQ2
    LFOSTGQ2 New Member
    LARRY
    2017 TACOMA
    NONE
    I had a 1984 4x4 pickup for 8 years, no squeeks. I also had a 1992 4x4 pickup for 20 years it started squeeking near the end but I figgured it was OK because I had run it hard on logging roads lots of times and never replaced any of the suspension components. My 2017 Tacoma sport 4x4 developed a nasty squeek the first time I took it on a logging road - it only has 3000km on it. All my co-workers drive Fords and have a great laugh when they hear it. The dealership I bought the truck says Toyota hasn't issued a fix for the problem and suggested I bring it in so they can pressure wash the leaf springs which should fix the problem until I go on a dirt road again. If you only drive your truck on the road you probably won't have this problem. For me, off road driving is why I bought the truck in the first place. More people need to pressure Toyota to fix this unacceptable problem......
  12. Apr 25, 2017 at 12:06 PM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    Is Truck.
    /thread
  13. Apr 28, 2017 at 10:18 AM
    TacoTom88
    TacoTom88 Gold Member
    Corey
    Northeast Georgia
    '17 DC TRD Sport
    Bought a 2017 TRD Sport this past Saturday. The front passenger side suspension is squeeking and creeking just like a my grandfathers old farm truck. Took it by the dealership and the service manager said not to worry he would make sure it got fixed. I've had the truck 5 days and the tire shine from the original wash job hasn't even worn off, yet.o_O
  14. Mar 9, 2020 at 11:56 AM
    Utahoffroader16
    Utahoffroader16 New Member
    Rebbeca
    2016 Tacoma off-road
    Mine squeaks after we take it off-roading. I powerw the hell out of the leaf springs and it goes away.
    A trusted mechanic told me it was bushings but after we washed it the sound went away.
    Washing is only a temporary fix though.
