Squeaky windshield
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dwr80, May 20, 2011.
  1. May 20, 2011 at 2:02 PM
    dwr80
    dwr80 [OP] Well-Known Member
    Have an 09 double cab w/ approx. 40k miles and the front windshield has a bad squeak. From the inside driver spot you can put a little pressure at the top to really make it squeak but driving it has begun to squeak like crazy. Any thoughts?
  2. May 20, 2011 at 4:10 PM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    Turn your wipers off..............................sorry.
  3. May 20, 2011 at 4:28 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    This happens to many people with a variety of different vehicles.
    It is the rubber trim around the windshield most likely.
    You can replace the windshield? Pretty drastic.
    You can try a urethane foam that you can pack in behind the rubber trim. Can work in some cases.
    Or you can live with it... unless it leaks?
