Squeeks from the Front and Back!
Discussion in '1st Gen. Tacomas (1995-2004)' started by rubend1, May 6, 2009.
  1. May 6, 2009 at 1:27 PM
    rubend1
    rubend1 [OP] New Member
    '97 Tacoma
    Hoopty Truck A to B Service
    Hey all, New member and Initial Posting! Hope you can help a brother out...:)
    Problem #1: I turn on my Truck and I hear a squeel / screeching noise coming from what I believe might be the belt(s)? If I place the truck in Neutral, the noise goes away. Once I begin to drive the noise goes away. The noises only occur while at a stop.
    Problem #2: While driving over small bumps or pot holes I hear some squeeling coming from my rear (drivers side) wheel area. It does not occur while driving on smooth surfaces. I replaced the shocks (front and back) two months ago. The suspension feels good. Just that horrible squeeky noise...
    Any thoughts :confused:
  2. May 6, 2009 at 1:54 PM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    Sounds like a drive belt and possibly a tensioner on your intial squeak on start up. try a belt dressing first but don't get too over zealous with it, sometimes moisture will cause an intial squeak, hence why it goes away after you start to drive. Check your belt for cracks. Lube your sway bar bushings that should get rid of the suspension sound based on the info you have given. Should you get a squeak in a tight turn you are just hitting the steering stops, putting some grease on them will help for awhile, but usually have to reapply every so often.
  3. May 6, 2009 at 1:56 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    could it also be a propeller shaft problem or a grease zerk problem?
  4. May 6, 2009 at 1:57 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    ps. and the squeeky noise could possibly be your bed. just a thought
  5. May 6, 2009 at 4:30 PM
    rubend1
    '97 Tacoma
    Thanks for the reply's. I will look into all a bit further. If anyone has any other suggestions I am all ears!
