SR5 does it have LSD?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by countryboy22, Aug 1, 2009.
  1. Aug 1, 2009 at 9:14 PM
    countryboy22
    countryboy22 [OP] Well-Known Member
    Arizona Mountains
    05 SR5 4x4
    TRD cold air intake, Bilstein 5100's @ 2.5, Toytec 1.5" aal w/rear bilsteins. MBRP tip, Flowmaster Delta Flow 50 series, Toytec axle shims and carrier bearing drop.
    Hey I just bought a 2005 SR5 Tacoma and I was wondering if it has limited slip differential? Or what indication will let me know if i have it.
  2. Aug 1, 2009 at 9:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    It shouls have a sticker on the rear diff saying "LS Diff fluid only", or the like.
  3. Aug 1, 2009 at 9:24 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    Unless I am mistaken...... I think that it should have a button on the dash (left side of steering wheel) that says DIFF LOCK (or something like that) if it has the LSD.
  4. Aug 1, 2009 at 9:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats for the locker on the TRD Off Road.
  5. Aug 1, 2009 at 9:27 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Mine has the sticker on the diff that reads: "LSD OIL ONLY"
  6. Aug 1, 2009 at 9:56 PM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
    Some do, some do not. My SR5 does not. Just like chris4x4 said, if you have a LSD, it will have a sticker on the back end of the pumpkin that reads "LSD oil only"
  7. Aug 1, 2009 at 10:03 PM
    countryboy22
    Arizona Mountains
    05 SR5 4x4
    ok thanks guys i will check it out.
  8. Aug 1, 2009 at 11:05 PM
    awoit
    awoit Well-Known Member
    CA
    08 TRD, SR5
    is it better to have LSD or not?
  9. Aug 1, 2009 at 11:10 PM
    aces2
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    I am probably a rare-breed when I say I would prefer not to have it. Just seems to be more of a hassle when changing fluids. Some guys get grinding noises if not adding enough supplemental additives/lubes in with the oil. I can still do a u-turn without it. I rarely go off-road, and have 4wd for the once-every-10yr-instance that I get stuck in some mud or can't climb a hill. The LSD might sound nicer to me if I hadn't heard of so many having issues at service intervals...
  10. Aug 1, 2009 at 11:56 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    It's better than just an open diff. If you have a locker than you are more geared towards off-roading. If you have an LSD it's geared more to on road traction. This being because LSD is automatic and the rear wheels will still turn independently unlike a locker.
  11. Dec 7, 2021 at 10:03 AM
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    4-wheel drives …turns only one front tire, and one back tire,,this can rotate back and forth, once a tire gets in the air? All the power is transfer to the spinning wheel, there maybe more this?
    Open diffs is the above, one LSD , usually rear, is better than open diffs, two LSD ( front &rear) is a bit better, one locker will out perform two LSD anytime, the ultimate system is two lockers…
    Please do your own research, study how four wheel drive works…
    I seen 2-wheel truck with one locker out perform 4x4 with open diffs… but it is better to have 4-wheel dr…
    Where the one front tire is pulling and one back tire pushing…LSDs and lockers will limit the spinning wheel..
    Study this further….
    Aloha
