sr5 locking differential?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by t-com09, Jan 8, 2012.
  1. Jan 9, 2012 at 3:58 AM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    My 2006 sr5 also has an LSD
  2. Jan 9, 2012 at 4:43 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    a dealer should be able to tell you if you dont believe the entire internet:popcorn:
  3. Jan 9, 2012 at 5:57 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    x2 Probably the best system I had ever own. And I have e-lockers, had truetrac, lockright and regular Limited slipp.
    Too bad Toyota dont sell them anymore in US.
  4. Jan 9, 2012 at 6:55 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Go with a ARB locker, its the best DD option as many have mentioned. With the SR5 having a larger rear end, you will end up with be a stronger, locked rear then the factory e locker, and you will also have on board air. :D
  5. Jan 9, 2012 at 7:11 AM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Yeah Toyota moving to an electronic "autoLSD" was a fail. It doesn't work in 4lo. Totally open diffs. Complete bull.
  6. Jan 9, 2012 at 8:04 AM
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
  7. Jan 9, 2012 at 8:13 AM
    The_Hodge
    SC
    no one has mentioned the "A" word....so ssshhhhh!!!!
  8. Jan 9, 2012 at 8:16 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    Not sure how it works in 4WD, but it works and it is not a fail. I have found it almost feels like your in 4W low when I have used it... :rolleyes:
  9. Jan 9, 2012 at 8:20 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    ATRAC
    paging David K
  10. Jan 9, 2012 at 8:20 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    BAN!
  11. Jan 9, 2012 at 8:22 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    If it's only for a day I might say it.. A-****
    derp too late..
    BTW I also want to put in an ARB Air locker and use the 100% duty cycle compressor!
  12. Jan 9, 2012 at 8:24 AM
    BlueT
    NorthEast
    You can mod that electronic junk to have some extra traction but, on the end, iTraction Is not made for snow/ice.
  13. Jan 9, 2012 at 9:20 AM
    The_Hodge
    SC
    dammit, monkeypooh!!!!
  14. Jan 9, 2012 at 9:23 AM
    MonkeyProof
    SoCal- SGV
    ATRAC/TRAC/LSD/eLockers:D
  15. Jan 9, 2012 at 9:30 AM
    #35
    Pugga
    Massachusetts
    That's like throwing up the Bat signal for David K...
  16. Jan 9, 2012 at 10:15 AM
    #36
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    beat me to it!
  17. Jan 9, 2012 at 3:15 PM
    #37
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    IMO it is head and shoulders above the electronic system that 09+ tacomas use, (not that toyota's system is bad it actually works pretty good). The TruTrac is a true mechanical limited slip and kicks in very quickly without having to hammer the gas. There are no clutches to wear out. I used it in mud, snow and over rocks and definately worked better than the electronic system. If the op is really in need of a locking diff then as far as I'm concerned the only system to go with is ARB due to the fact that you activate it only off road in sections that you abosolutely need it.
  18. Jan 9, 2012 at 10:34 PM
    #38
    MountainEarth
    Bryan
    CO
    2010 TRD OR Access
    You mean the yellow wire mod? That's for adding TRAC to 4lo. If that's what you did, why would you do that if you have a TRD OR?
    With a 4wd, it works just fine in 2wd and 4hi. But in 4lo, autoLSD and TRAC turn off entirely. In the most critical 4lo conditions, Toyota hobbled their non-locked / non-ATRAC'd trucks. Think about it - 2005-2008s have mechanical LSDs that aid in every setting. Why would Toyota take a step back?
    Like most things, I'm sure it was all about the money. As of 2012, all vehicles sold in America are required to have traction control (TRAC in all models of Tacoma). And the autoLSD essentially uses the same components. For the beancounters, it probably made perfect sense. But it hobbles the truck compared to it's predecessors. That is unless you're willing to snip wires to get TRAC (but not the autoLSD .. unless there's another mod I've never heard of) in 4lo.
  19. Jan 9, 2012 at 10:44 PM
    #39
    MountainEarth
    Bryan
    CO
    2010 TRD OR Access
    AFAP lol. Yeah it is true that TRAC is all 4 wheels. But TRAC also saps engine power which the autoLSD doesn't .. though in the V6 there's plenty to spare. I'm also thinking Toyota might have done this to move more TRD Off Roads. Because an SR5 with the mechanical LSD was a kickass truck for 95% of all uses .. no need to spend thousands more. Personally I think a mechanical LSD is a much better choice in the snow too.
  20. Jan 9, 2012 at 10:56 PM
    #40
    MonkeyProof
    SoCal- SGV
    :clicking heels three times: "There's no place like ATRAC" "There's no place like ATRAC" "There's no place like ATRAC"
    paging DAVID K
