sr5 to tow like a trd what do i need to do??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doons, May 30, 2011.
  1. May 30, 2011 at 4:46 PM
    doons
    doons [OP] Active Member
    KANADIA
    2011 V6 4X4
    i was just wondering what i would need to do to get my sr5(3500) to tow like a trd(6500) tranny coooler beefed up leaf's and rear shocks?
  2. May 30, 2011 at 4:49 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    It has nothing to do with Trd/non-trd, it's just whether you have the towing package or not.
    I don't completely recall what the towing package has on it, I know class iii hitch and tranny cooler.....I'm sure there is more
  3. May 30, 2011 at 4:50 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    heavy duty alternator
  4. May 30, 2011 at 4:51 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I believe the differences are just cooling. Trans cooler, engine oil cooler, possibly fan clutch. TRD has different shocks I think, but pretty sure the springs are the same (weak).
    I would think that you'd be okay without the engine oil cooler if you run synthetic oil, but I am no expert. Definitely check and see if the fan clutch is different, and make sure you have an aux trans cooler if you have the automatic.
    Sounds like most guys here end up getting the TSB leaves installed to tow with.
  5. May 30, 2011 at 6:11 PM
    doons
    KANADIA
    2011 V6 4X4
    can i get some more info...get the trans cooler? and maybe new leafs? thanks for the imput guys
  6. May 30, 2011 at 6:13 PM
    TACODACKS
    TACODACKS Forging Elite Fitness
    The Streets of America
    From the Toyota website...
    V6 Tow Package: Class 4 Hitch, Transmission and Supplemental Oil Coolers (Transmission Cooler not available on Manual Transmission models), 130A Alternator, Heavy-Duty Battery, 7-Pin Connector with Converter
    Guess everyone pretty much nailed it.
  7. May 30, 2011 at 6:14 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Do you have the dealer tow package? The sr5 and Trd have the same rear leaf springs so that won't help you
  8. May 30, 2011 at 7:40 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Well, that's true but TSB leafs will help with towing.
    I just recently added a tow hitch to my truck. I did not add additional coolers but I won't be towing anything over the 3500lbs anyway so I'm not concerned with it. But yeah, the trans cooler is the biggest difference (aside from the hitch itself, of course).
    Check out the Towing Bible: http://www.tacomaworld.com/forum/towing/4031-tacoma-towing-bible.html
  9. May 31, 2011 at 10:04 PM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    Not possible to reach 6500# unless you can get the factory class IV hitch which requires the bed to be removed to install. All aftermarket hitches for the Tacoma are Class III with at 5000# rating.
  10. Jun 1, 2011 at 5:51 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    my towing package hitch was removed w/o taking the bed off, so why would you need to remove the bed to install one?
  11. Jun 1, 2011 at 5:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It's not possible to reach 6,500# because, regardless of what you add on, the GVWR sticker isn't going to change. If it's only rated to tow 5,000 lbs, that's all you can legally tow. Even if you beef it up so it's physically able to tow 10,000 lbs, legally you're overweight.
  12. Jun 1, 2011 at 7:01 AM
    Pugga
    Massachusetts
    Exactly... Just a different number on the sticker but there's nothing you can do to a base model to get a new sticker with a higher weight on it.
  13. Jun 1, 2011 at 7:24 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    You can change the sticker...
  14. Jun 1, 2011 at 7:29 AM
    Pugga
    Massachusetts
    Legally?? :eek:
    I'm listening...
  15. Jun 1, 2011 at 7:29 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    You really just said that a Class III hitch is as strong as a Class IV hitch?
  16. Jun 1, 2011 at 7:30 AM
    Pugga
    Massachusetts
    What, you mean you didn't know that? :rolleyes:
  17. Jun 1, 2011 at 7:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Do you believe the things you post?
  18. Jun 1, 2011 at 7:41 AM
    Pugga
    Massachusetts
    Just a sticker and all the testing that goes behind it... A class 3 MAY be overbuilt but that design is only tested to a certain limitation. That sticker that comes on a class 4 means it HAS to be built to a certain standard. I would not bank on all Class 3 hitches being overbuilt to be as strong as a Class 4.
  19. Jun 1, 2011 at 7:44 AM
    mjp2
    NJ
    You spew dangerously inaccurate information.
  20. Jun 1, 2011 at 7:46 AM
    macgyver
    Brad
    Canton, GA
    Who said anything about laws here? :D
    You guys are a bunch of sissies! Go big or go home! Take some risks
    Lol but seriously. If you plan on towing 6,000+ lbs often then you might wanna get another tow vehicle. A class III hitch should suffice. I have an aftermarket Valley hitch and added a 7pin plug. More than enough for what I tow (a 16ft boat on the weekends, my landscape trailer during the week, and an occassional car on my buddy's trailer.) If you're an auto, I would invest in the tranny cooler for sure. I'm a MT so I don't really need to worry about the Tranny cooler.
