SR5 vs. Off-road 2020
Discussion in '3rd Gen. Tacomas (2016+)' started by weekender21, Jul 9, 2020.
  1. Jul 9, 2020 at 6:51 AM
    weekender21
    weekender21 [OP] Member
    I read another thread discussing this topic but have a few more questions.
    The quotes I have from my local dealer separate the SR5 and off-road by only $1500. Am I right to assume the lockers and upgraded bolt-on suspension are worth that?
    I can’t see using the crawl mode personally but the lockers and better suspension are appealing. What’s the cost to add those features later on?
  2. Jul 9, 2020 at 6:56 AM
    opeesha
    opeesha Well-Known Member
    C
    2018 SR5 4x4 DCSB
    I’d say do it. I just got a quote to add a locker and it was 1900$. So if that’s something you value it sounds worth it
    weekender21 [OP] likes this.
  3. Jul 9, 2020 at 7:01 AM
    JohnMurphyNC
    JohnMurphyNC Well-Known Member
    Oklahoma
    2015 DCSB Superwhite 4x4 TRD Sport
    Absolutely worth it. I really regret not going with an OR.
  4. Jul 9, 2020 at 7:02 AM
    Shellshock
    Iowa
    2017 DCSB TRD OR MT QUICKSAND
    Plus you get the 8.75” diff in the OR
    I’d definitely get the OR over the SR5 for that little amount of money
  5. Jul 9, 2020 at 7:31 AM
    weekender21
    Thanks for the quick replies, seemed like a no brainer for the extra $1500 but wanted a second opinion.
    shakerhood likes this.
  6. Jul 9, 2020 at 7:32 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    You are overlooking that the OR has ATRAC. There is no reason to not have that enabled at all times while in 4lo. I have yet to find any situation that the rear locker improved traction more than ATRAC, but I suspect I will find one. Also note that the OR does not have a front locker, so even when you are using the rear locker, you might as well have ATRAC enabled to get a simulated locker in the front.
  7. Jul 9, 2020 at 7:35 AM
    Shellshock
    Iowa
    ATRAC is only on the MT
    The AT has MTS / Crawl Control
    But yes, MTS / ATRAC is definitely worth it.
    shakerhood, taco abbo and BlkTaco47 like this.
  8. Jul 9, 2020 at 7:37 AM
    gudujarlson
    Minnesota
    No doubt. A locker will run you at least that much. And you will never be able to retrofit ATRAC. This this a big reason why I bought the OR. The other reason was the manual transmission.
    Other small goodies include the front recovery hook, air dam delete, and various aesthetic upgrades.
  9. Jul 9, 2020 at 7:41 AM
    gudujarlson
    Minnesota
    I believe ATRAC is called multi-terrain select on a AT with the additional ability to adjust the aggressiveness of the ABS brakes but I never owned a OR auto. Crawl control is different in that it controls the throttle unlike mt select and ATRAC, yes? Crawl control one might not use all the time, but there is little reason to not use mt select / ATRAC
  10. Jul 9, 2020 at 7:44 AM
    Shellshock
    Iowa
    Correct. MTS is basically ATRAC where you have sensitivity adjustments
    Crawl control will control gas and brake, essentially 4lo cruise control
    The OR also has the brake booster included as part of these systems.
  11. Jul 9, 2020 at 7:45 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    I don't think anyone asked. Are you going to off-road it??
    G.
    TacoBuffet and thors10 like this.
  12. Jul 9, 2020 at 7:49 AM
    gudujarlson
    Minnesota
    Ya the OR ABS brakes are much quieter than on the SR5. I thought read that they are electric rather than using engine vacuum, thus they can be used for longer periods of time. In any case, I’m fairly sure the ORs traction control system includes more than just upgraded electronics, as you said. People tend to overlook the system as just a gimmick.
    44-16 Taco and Malvolio like this.
  13. Jul 9, 2020 at 7:50 AM
    Shellshock
    Iowa
    Isn’t that a requirement for joining TW?
    G8R_Taco and Malvolio like this.
  14. Jul 9, 2020 at 7:54 AM
    ChuckTownRC51
    ChuckTownRC51 Well-Known Member
    Mark
    2016 TRD Off Road 4x4 Double Cab
    None, yet
    If there's only $1500 difference there's something going on there.
    Boghog1, BSFord and TacoBuffet like this.
  15. Jul 9, 2020 at 7:55 AM
    Hatfieco05
    Hatfieco05 Well-Known Member
    Portland, OR
    2020 DCLB TRD Off-Road Premium
    Offroads all have the extra trans cooler and tow package as well. Not to mention resale value for a trd optioned offroad has always been a huge selling point.
    weekender21 [OP] and Shellshock like this.
  16. Jul 9, 2020 at 7:58 AM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4; 2005 TRD sport PreRunner DCLB
    Bilstein 5100
    Simple answer. Yes.
  17. Jul 9, 2020 at 8:00 AM
    TacoBuffet
    TacoBuffet Well-Known Member
    IL
    Taco #12, 2020 OR DCSB 4WD LED, Tech and Prem
    Tint, Bedmat, LEDs, WeatherTechs
    This ^, I'm willing to be 90% of OR owners will never need or use their locker, CC or MTS.
  18. Jul 9, 2020 at 8:01 AM
    muskratX22
    muskratX22 Well-Known Member
    Dave
    Illinois
    Not talking Toyotas but I had a friend ( long since passed on) who preferred an open rear diff to a locker or limited slip. And this gentleman USED his 4 wheel drives. That being said I have never owned a locker but I like limited slip.
  19. Jul 9, 2020 at 8:01 AM
    Garyji
    Gary
    Yeah, you're right. No "Super Bro-Cool Mall Crawlers" here!
    G. :D
    weekender21 [OP] and TacoBuffet like this.
  20. Jul 9, 2020 at 8:04 AM
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    I had the same dilemma last year and opted for the OR (though the difference in price was greater). The extra functionality of the OR seems to be a better value when considering potential use and resale. The OR was also optioned out better than the SR5. I know the SR5 now has a larger infotainment, carplay, and power seat, so the gap has closed. Too lazy to look, but does the SR5 still have a key ignition or did it go push button for 2020?
    Shellshock likes this.
