Stage 1 Full Battery Harness Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by somethinboutayota, Feb 15, 2014.
  1. Feb 15, 2014 at 8:41 AM
    somethinboutayota
    somethinboutayota [OP] Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    This is a write up for a complete battery wire harness replacement on a 98-04 3.4 V6 Tacoma with plenty of pictures and advice necessary for the job. This isn't a difficult task, if I were to rate it it's a 2. The battery wires I used is the stage 1 kit from Bama Toy1997 which consists of just the wires, a stage 2 kit consists of a high output alternator and a stage 3 consists of a total primary electrical system upgrade
    For more info on the different stages you can get and where to buy them here is his FS page
    http://www.tacomaworld.com/forum/ma...coming-2nd-gen-electrical-system-upgrade.html
    You will need:
    10mm socket
    12mm socket
    14mm socket
    Flat head screw driver
    Set of Alan wrenches
    Here is the stage 1 battery cables I received in the mail.
    Starting with the build you will need to disconnect your old positive and negative terminals from the battery and the ground wire from the fender
    Next you will need to slide this cover off that is located on your fuse box to disconnect the other positive wire coming from the main wire loom
    Here you can see that I have disconnected the wire from inside the fuse box
    You will need to proceed by locating your alternator on the drivers side underneath the valve cover and disconnect the two wires
    Right below that locate where your negative battery cable ends at and unscrew the 14mm bolt holding it on, it should be located beneath the oil filter as seen here
    After disconnecting those follow the wire loom down under the front of the engine
    You will see an ivory colored mounting bracket for the wires that you will need to unhook so you can get the wires out. It looks like this:
    After you disconnected it follow the battery cable up the side of the engine block and locate the holding the cable and unbolt it, next to it should be a tiny wire that is also from the loom that you need to disconnect, the bolt should be directly above the CV axle as pictured
    When all of that is completed you should be able to rip the whole mess out of the engine bay and throw it away.
    If you want to keep the wires together and clean take off all of the wrap around wire loom things and put them back on your new wires to keep them from floating around in the engine bay. It's the black plastic that wraps around the cables and makes it appear fat like in the picture above ^
    It started to get dark so I am sorry if things are not clear enough.
    Go back to your main fuse box and find the cable that is sticking out of the bottom, it should have been previously connected with your old positive battery cable and pull it inside the fuse box so you can mount it on the bolt
    Next in line is the new battery cables starting with the positive battery connection the fattest wire located on the far right (also the longest) will be the cable that goes underneath the engine to the other side. The middle cable will connect with your alternator like so
    The third wire on far left that is transparent will be going to your fuse box where we mounted the wire hanging out of the fuse box at. Run the cable up the side where existing wire used to be and place it on bolt
    As of what to do with the tiny blue wire running off of your positive cable it is a ground for the voltage meter I coiled it around the transparent cable we just mounted, ran it trough the fuse box and wrapped it around the 10mm bolt on at the stock location
    Last but not least your negative battery cable! The small transparent wire connects at the factory ground location on the fender and the other black cable bolts back up underneath the oil filter.
    Finished product
    Jknight13 likes this.
  2. Feb 15, 2014 at 8:42 AM
    BamaToy1997
    Bill
    Navarre, FL
    Whoops. None of the pictures showed up...lol
  3. Feb 15, 2014 at 8:53 AM
    somethinboutayota
    Parker
    Dodge City, Kansas
    How about now?
  4. Feb 15, 2014 at 9:34 AM
    T4coma
    T4coma Active Member
    Mass
    2003 XtraCab 4x4 v6 TRD SR5
    5100/5125 shocks, grey wire mod, deck plate
    the link doesn't work either :p
  5. Feb 15, 2014 at 9:49 AM
    somethinboutayota
    Parker
    Dodge City, Kansas
    Should be fixed now, tapatalk is being difficult
  6. Feb 15, 2014 at 10:15 AM
    BamaToy1997
    Bill
    Navarre, FL
    Looks good! I'm glad that you like the kit!
  7. Feb 15, 2014 at 10:47 AM
    somethinboutayota
    Parker
    Dodge City, Kansas
    Glad to have the kit now and out of the way so I won't have to worry later, my other ones were so terrible it was time for an upgrade anyways
  8. Feb 15, 2014 at 12:11 PM
    mmcmahan2206
    mmcmahan2206 Well-Known Member
    McCall, Idaho
    00 Tacoma SR5 TRD 3.4L
    6" FabTech suspension 3" body lift, 35x12.50R15 BFG AT T/A KO tires, Mickey Thompson Sidebiter wheels, 4:88 front and rear gears, e-locker, "grey wire mod," Hella driving lights retroed to 55w 8000K HIDs, custom grill, Downey chrome air intake w/ AEM filter, AirAid throttle body spacer, Flowmaster exhaust, Alpine audio w/ 12" RF sub, racing bucket seats, black powdercoated toolbox, smoked out black taillights, black headlamps and corners, red LED interior lights, sway bar removed, rear shock relocation, u-bolt flip mod, 01 center console, Relentless Fab front plate bumper, LED fog lights.
  9. Feb 15, 2014 at 12:45 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  10. Feb 15, 2014 at 5:52 PM
    BamaToy1997
    Bill
    Navarre, FL
    OK, I finally have a 2nd gen in the shop so I will be measuring everything out and getting the 2nd gen Stage 1, 2, and 3 designed and ready for sale hopefully within a week.
  11. Feb 15, 2014 at 9:35 PM
    somethinboutayota
    Parker
    Dodge City, Kansas
    Awesome to hear, have you had anyone get in line for the second gen set yet?
  12. Feb 16, 2014 at 1:26 PM
    Yoda the Taco
    Yoda the Taco Well-Known Member
    Chase
    Kingsport
    Majestic White Stallion
    00 front end swap 3 inch spacer/block 01 dash swap Flux capacitor 04 center console tach cluster swap avatar-10 hyperdrive 02 door panels powerlocks/keyless entry electric fan swap 4runner seats
    Sub'd! Nice write up :D
  13. Feb 16, 2014 at 1:29 PM
    BamaToy1997
    Bill
    Navarre, FL
    Not yet, because I haven't been able to see what the costs will be. Once I know the cost, then I can set a fair price. I hope that I can keep it close, if not the same, as the 1st gen kits.
  14. Feb 16, 2014 at 2:16 PM
    somethinboutayota
    Parker
    Dodge City, Kansas
    Thanks!
  15. Feb 16, 2014 at 2:17 PM
    somethinboutayota
    Parker
    Dodge City, Kansas
    I think I have my friend sold on a set of 2nd gen when he gets his
  16. Feb 17, 2014 at 8:05 AM
    BamaToy1997
    Bill
    Navarre, FL
    ok. Well I am still working on it. Thanks!
  17. Feb 28, 2014 at 7:06 PM
    T4coma
    Mass
    Does the volt meter stay on continuously when the blue ground wire is connected?
  18. Feb 28, 2014 at 7:35 PM
    somethinboutayota
    Parker
    Dodge City, Kansas
  19. Feb 28, 2014 at 8:19 PM
    T4coma
    Mass
    won't that kill your battery?
  20. Feb 28, 2014 at 8:28 PM
    BamaToy1997
    Bill
    Navarre, FL
    The draw is so minimal that it would take a month to drain the battery down. It draws about as much power as the radio memory does.
