Stage 3 icon 650lb coils
Discussion in '3rd Gen Tacoma Parts Marketplace (2016+)' started by TWTaco, Jan 28, 2018.
  1. Jan 28, 2018 at 12:41 PM
    TWTaco
    TWTaco [OP] Well-Known Member
    Dave
    Upgraded to 700lb icon coils . Set of 650lb icons 175.00 OBO. Orange county Cal area. Will ship but buyer pay's all cost.coils.jpg
  2. Jan 28, 2018 at 2:03 PM
    Mack411
    Mack411 Well-Known Member
    2017 Quicksand Tacoma Trd-OR
    Pm sent
  3. Jan 28, 2018 at 3:15 PM
    TWTaco
    Dave
    if you want the coils with the rear i will do 700.00 for all
  4. Jan 29, 2018 at 6:04 AM
    Ayeele
    Ayeele Well-Known Member
    Houston, Tx
    18 TRD Pro, 01 DCSB TRD OR 4x4
    Dumb question but would they fit kings?
  5. Jan 29, 2018 at 8:53 AM
    TWTaco
    Dave
    I dont have any idea if they would.
  6. Jan 31, 2018 at 5:11 PM
    TWTaco
    Dave
    bump!
  7. Jan 31, 2018 at 7:32 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2019 TRD Pro
    If the kings are 2.5s they will.
    Ayeele and TWTaco [OP] like this.
  8. Feb 14, 2018 at 8:01 AM
    Murphystaco
    Murphystaco Well-Known Member
    2017 white Tacoma OR
    Sent you a PM
  9. Feb 14, 2018 at 11:05 AM
    hx989
    hx989 Superunknown Member
    Olympic Peninsula
    No, King (and everyone else except for Icon) uses 14" coils and these are 13" so technically you can put them on but have to crank the shit out of them for the same ride height and you're not gonna be happy with how that behaves
  10. Feb 14, 2018 at 11:46 AM
    Sub_Par
    Buffalo NY
    2019 TRD Pro
    I thought fox uses 600lb 13" springs. I know Icon does (but 650lbs). There is no reason to not use these coils on Kings, the length should be fine because the preload would be the same on a 13" or 14" coil.
  11. Feb 14, 2018 at 11:46 AM
    hx989
    Olympic Peninsula
    No, it wouldn't. Not if you want th same ride height. Because physics
  12. Feb 14, 2018 at 11:48 AM
    Sub_Par
    Buffalo NY
    2019 TRD Pro
    You'll have the same preload on a 14 or 13" spring if the spring rate doesn't change at the same ride height. Yes you'll have more threads showing but the threads showing does not equal preload. Preload is measured by the free length of the spring minus the compressed length, so 2" of threads does not mean the coil is compress 2".
  13. Feb 14, 2018 at 11:52 AM
    hx989
    Olympic Peninsula
    Okay, you're right about that. However that means that you lose the ability to lift from 0-3.5" as Kings are designed.
    It's technically possible to put this cool on there but still the results will suck
    Sub_Par likes this.
  14. Feb 14, 2018 at 12:26 PM
    Sub_Par
    Buffalo NY
    2019 TRD Pro
    Possible coil bind as well, so good point about cranking them. Short answer yes they "can" work but may not be the best option.
    hx989 likes this.
  15. Feb 14, 2018 at 12:54 PM
    hx989
    Olympic Peninsula
    :cheers:
