Staking lifts??? whaaa? help please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy25056, Sep 7, 2011.
  1. Sep 7, 2011 at 10:38 AM
    jeremy25056
    jeremy25056 [OP] Well-Known Member
    Los Angeles
    11 TRD OFF-RD AccessCab 6Spd
    Ok,
    I have 5100's at the highest perch. Want to add another inch or so up front leaving the rear. Please just tell me if this would work. if not why and what would work.
    Bilstein 5100 set at 2.5
    Add a differential drop and a 1-2 spacer on the top of the coil.
    Its an 2011 TRD Off RD Access Cab
    Thanks much,
    Jeremy:crapstorm:
  2. Sep 7, 2011 at 10:41 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    4x4 or Prerunner?
  3. Sep 7, 2011 at 10:42 AM
    jeremy25056
    Los Angeles
    Shit sorry 4x4
  4. Sep 7, 2011 at 10:44 AM
    JLee
    Jerry
    Benicia, CA
    Your CV angles will be BAD! if you stack lifts if you want to go higher you need to do a drop bracket lift or a body lift. You could do a 1" body lift but I wouldn't go any higher then that but that's really not going to level you out.
    SpeySquatch likes this.
  5. Sep 7, 2011 at 10:47 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Stacking lifts isn't a great idea. If you need a taller lift, get a taller lift but I wouldn't add a top plate spacer on top of compressing the coils for more lift.
  6. Sep 7, 2011 at 10:49 AM
    jeremy25056
    Los Angeles
    Gotcha, thanks for your input.
    Ok so if i just do a pro comp or fabtech 3" lift on the front what else will i need to go with that to make sure things are stressed too much.
  7. Sep 7, 2011 at 10:51 AM
    JLee
    Jerry
    Benicia, CA
    You can put the 1/4" top plate spacer on the 5100's to get a full 3's of lift you don't need to buy a Pro crap 3" lift.
  8. Sep 7, 2011 at 11:53 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    awww man.. why all the hate on pro comp? Haha. I have the pro comp full 3" kit and I love It. no bro lean for me (I hate it as well) new shocks all around, add a leaf, and new coils. Sits nice. Performs great. Just need to throw on my top plate for the taco lean.
  9. Sep 7, 2011 at 11:56 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Why the fuck would you want procomp shocks? I threw mine away when I got all my fox resi's on.
  10. Sep 7, 2011 at 11:58 AM
    PLC721
    Patrick
    Chandler, Az
    Don't the Valving and build quality blows on them.
  11. Sep 7, 2011 at 12:00 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Your a son of a bitch Patrick. Lol.
  12. Sep 7, 2011 at 12:02 PM
    PLC721
    Patrick
    Chandler, Az
    Haha I was talking about the 6" lift shocks and coilovers
  13. Sep 7, 2011 at 12:09 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Your a bastard too Whippersnapper. Lol
  14. Sep 7, 2011 at 12:12 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Stacking? :notsure::confused:
  15. Sep 7, 2011 at 12:16 PM
    Manwithoutaplan
    ID
    IF you want to go higher just get 38 inch tires.
  16. Sep 7, 2011 at 12:17 PM
    Manwithoutaplan
    ID
    wow that looks healthy :D.
  17. Sep 7, 2011 at 12:18 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Now your even more of a bastard.. lol. Damn that looks good. Back on topic. Haha.. don't stack the lifts, unless Its just a top plate spaccer.
  18. Sep 7, 2011 at 12:18 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Have at. My money is on the undead lift though.
  19. Sep 7, 2011 at 12:21 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Let's say (hypothetically) that his truck was a PreRunner..... :D The answer would be different, yes? (Sorry for the thread jack...... :eek:) I understand you have to worry about ball joint angles and down travel and such..... but no CVs = ok to stack lifts? What's the highest you could go with it still being a functional suspension?
  20. Sep 7, 2011 at 12:22 PM
    Slodgetto
    Silas
