Standard v Automatic (Looking at a New To Me continued)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joshtree, Apr 7, 2021.
  1. Apr 7, 2021 at 4:31 AM
    joshtree
    joshtree [OP] Active Member
    Josh
    Haverhill MA
    005 TRD DC V6
    Two car seats
    Not to start an “oil thread” but I’m looking for verification.
    I love my standard! I want my next truck to be a stick. However in all of New England there seem to be about 3.
    I need to tow. Not an abusive amount but sometimes yes heavy trailers. My ‘05 standard did great with that.
    If I cave and get an automatic, when should I expect to replace the transmission?
    I’m currently near the end of my second clutch @235k. Some hard abuse on this one that I don’t anticipate repeating (but one can never know.)
  2. Apr 7, 2021 at 4:42 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    I wouldn’t worry about the 2nd gen automatic, it’s proven to be reliable and better then the manual.
    DavesTaco68 likes this.
  3. Apr 7, 2021 at 4:45 AM
    69L46Vert
    69L46Vert Well-Known Member
    Rick
    Maine
    2007 Regular Cab 4x4
    I would never be happy with an automatic. My advice is hold out and get what you already know you really want.
  4. Apr 7, 2021 at 5:47 AM
    joshtree
    Josh
    Haverhill MA
    005 TRD DC V6
    Two car seats
    That’s a pretty bold statement! good to hear though thanks. I’ll definitely test dive a few just to see how I like it. It’s the wear of towing that concerns me. Aside from the negative-cool factor
  5. Apr 7, 2021 at 2:39 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    This is true
  6. Apr 7, 2021 at 3:21 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    If you properly maintain an auto and don’t over heat it it’ll last as long as a manual. I personally have never had a clutch last 235,000 miles. I think that many miles on a clutch is more the exception than the norm. But good on you that you got that many miles on it.
    Oops, just realized you are on or about to be on your second clutch at 235,000 miles. So that means you are averaging about 115,000 miles on your clutches. I think anything over 100,000 miles on a clutch is pretty good.
    I do a lot of towing and only had a problem with one tranny. On a Tundra I had the auto tranny crashed just after warranty but with only about 50,000 miles. I complained and Toyota said they’ve never seen this before. Toyota corporation paid for a new tranny.
    Hardscrabble likes this.
  7. Apr 7, 2021 at 4:24 PM
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    Tow in 4 and not D and you should go far. But get what you will love, don't compromise for availability unless you're desperate.
  8. Apr 7, 2021 at 4:32 PM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    Anything over 100K on a clutch is good? Wut? Maybe you don’t know how to drive a manual tranny? Not trying to be rude but replacing the stock clutch at 100K miles is absurd. I have 185K miles on mine and it’s strong as ever.
    Yukon DoIt likes this.
  9. Apr 7, 2021 at 5:32 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    For towing the automatic is way better than the manual. Especially the way these trucks are geared and where the torque is generated. Back in the day when manuals ruled it was because 1st and reverse were geared in the 5:1 range. And trucks got their torque at 2000-2500 rpm. Today most trucks have 1st and reverse under 4:1 ratios and most modern engines need 3500-4500 rpm to get their torque. Getting a load moving, or maneuvering in tight quarters is a PITA with modern manual transmissions. And creates a lot of wear on them.
    None of the manufacturers who build 1/2, 3/4 and even 1 ton trucks rated to tow 18,000+ lbs even offer a manual anymore. There is a reason for that. The manuals are for guys who buy trucks to use as toys. They guys buying tools choose an automatic.
  10. Apr 7, 2021 at 7:52 PM
    Sprig
    Ken
    The number of miles you individually have on your clutch doesn’t mean anything. Read some industry literature. You’ll see that the life of a clutch is all over the map. Some last 50000, some 75000, some 100000, some 150000 and so on. Clutch’s can last from 5000 miles to 300,000 miles. Lot of factors and variables involved in clutch life. In general overall over 100000 miles and you’ve done well. As far as my prowess driving manual trannys I’ve driven manuals for over 40 years from pickups, to bobtails to bigger trucks. I’ve driven and owned sports cars and muscle cars, all manuals. I use to race sports cars. I know well how to drive a manual. Replacing a stock clutch at around 100,000 is not “absurd”.
    Also what Marshall R says above is 100% spot on.
    blu92in99, Hardscrabble and Jimmyh like this.
  11. Apr 7, 2021 at 8:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Tow in 4th. Change the fluid regularly.
    I think you will be fine, as long as you aren’t expecting it to tow over its maximum capacity.
    If so, get a bigger truck.
    Jimmyh and Sprig like this.
  12. Apr 7, 2021 at 9:11 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    TnShooter likes this.
  13. Apr 8, 2021 at 1:14 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Never say never. Wait until the knees and hips get old and arthritis starts. A reliable automatic transmission will be your dream.
    Ask me how I know.
  14. Apr 8, 2021 at 4:04 AM
    Inbred
    Inbred Well-Known Member
    Phinnius
    2nd generation euphoria
    I looked it up in a manual. It said standard transmissions are the bitching king. Them who drive ‘em are kings and them who don’t are always bitching. Get yourself that standard no matter what it takes. Don’t give in to opinions from the automatites. Follow the light of the clutch masters. There’s a special place in heaven for men (and dames) what work their own gears. Nuff said.
    joshtree[OP] likes this.
  15. Apr 8, 2021 at 10:02 AM
    TnShooter
    Deogee
    STOCK
    If you do choose the manual trans.
    You might look into doing the 4Lo mod.
    It should help tremendously when back those heavy trailers.
  16. Apr 17, 2021 at 7:03 AM
    joshtree
    Josh
    Haverhill MA
    005 TRD DC V6
    Two car seats
    Interesting. Thanks all for the enlightenment. I’ll be looking into the 4lo mod after this.
    I purchased the 6speed. I’m excited. It has a plow which is another argument/discussion I’m looking forward to.
    It seems that a manual and a plow may not be an ideal combo, so I will likely sell it, depending on how I like using it and if I can stand one more thing cluttering up my yard/driveway.
    69L46Vert likes this.
  17. Apr 17, 2021 at 7:27 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I bought a 87 Tacoma about 12 years ago used I had to put a clutch in it at 205K. I have 125+ K on my 2011 I tow a 3,000LB camper. We have owned a couple of automatics my wife said she wanted to go back to a manual, her (new) 2006 has 150K on it now. I live in Maine I plow with the Tacoma but am smart enough to only use low range and do not try to launce snow over the fence just push it out of the way. My road is about a 1/4 mile long. You can abuse and automatic just as well a clutch remember there are clutches in an automatic also. A clutch replacement in the long run is cheaper than an automatic overhaul Owning a a manual is becoming a theft deterrent also!
    69L46Vert and joshtree[OP] like this.
  18. Apr 17, 2021 at 7:43 AM
    69L46Vert
    Rick
    Maine
    The plow is much harder on the Auto imo. Nothing wrong with a manual and plow. I’m from Maine and have plowed commercially many years and know first hand that the automatics take it hard. Much prefer the manual myself.
  19. Apr 18, 2021 at 2:02 PM
    joshtree
    Josh
    Haverhill MA
    005 TRD DC V6
    Two car seats
    Cool. That’s a very inspiring reply. Thanks for the feedback.
    69L46Vert[QUOTED] likes this.
  20. Apr 18, 2021 at 2:42 PM
    TacoTuesday1
    FL
    do you want a vehicle you enjoy driving
    or one that sucks to drive
    why pick a rusty truck from NE when you can fly to a dry sun state and drive it back
    Hans_Gruber likes this.
