stange sound
Discussion in '1st Gen. Tacomas (1995-2004)' started by dparoskie, Aug 1, 2008.
  1. Aug 1, 2008 at 9:02 AM
    dparoskie
    dparoskie [OP] Member
    va
    01 tacoma
    When driving in reverse the truck is making squeaky sounds especially when you turn the wheel. Anybody know what is wrong or how to fix? Thanks
  2. Aug 1, 2008 at 9:07 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Hey buddy:) more details please-front or rear? chirpy high or grindy low?
  3. Aug 1, 2008 at 9:17 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep....more info please!!! :) could be a number of things.....wheel bearings, shocks/struts, leaf springs....etc.
  4. Aug 1, 2008 at 9:20 AM
    dparoskie
    va
    01 tacoma
    Sounds like a high squeak and i think its coming from the front end. It started a few weeks ago and it only happens when backing up.
  5. Aug 1, 2008 at 9:25 AM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Is it a "chirp chirp chirp" or a steady "squeeeeeel"? How are your front brakes? are they close to needing replacement? your warning sensors may be just starting to contact the rotors.
  6. Aug 1, 2008 at 9:29 AM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Also, if you have 4x4 it could be a dry axle in front
  7. Aug 1, 2008 at 9:37 AM
    dparoskie
    va
    01 tacoma
    Its more of a chirp sound. The brakes are at about 50% so I don't think its that. I will take a look at the axle.
    Thanks
  8. Aug 1, 2008 at 10:58 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Check CV joins. Brake pads both sides. 50% means nothing. You need to check for crack and make sure the sliders are not frozen.
    Also check the rear brakes and axle.
    Cleaning your brakes is not a bad Idea. and adjusting them.
  9. Aug 1, 2008 at 11:07 AM
    dparoskie
    va
    01 tacoma
    thank you
  10. Aug 1, 2008 at 2:32 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Is it 4wd? Worn CV joints up front can cause the chirping noise, especcially when the wheel is turned to its max.
