starter about to go bad?
Discussion in 'Technical Chat' started by achirdo, Feb 24, 2011.
  1. Feb 25, 2011 at 9:01 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    i concur, wiggle around the battery terminals and see if this the problem. look for corrosion or battery acid that has spilled out of the little covers. i had this problem and i fixed it by changing out my terminals. bad starter would either sound like the motor is turning over but slower than usual, or the bendix shoots out and doesn't engage the flywheel and spins inside the starter, or it hits the flywheel and makes that grinding noise. you can always pull it off and test it at autozone, but me thinks its going to be something else:)
  2. Feb 25, 2011 at 9:10 AM
    tarheelfan_08
    tarheelfan_08 Carolina Alliance
    Justin
    North Carolina
    2010 White 4x4 Double Cab Tacoma Short Bed
    Chrome Grill, Chrome accessories(door handles and mirror covers), LEER Super White Cover, Mirrors with Turn Signals, Window Vent Visors, Step Rails, WeatherTech Digital Floor Mats, Mini Maglight Holder, Chrome Bull Bar
    Mine did this to me the other day but has not done it since. I am thinking maybe a piece of trash in engine or something...idk. Let me know how it goes though and what you do to fix it just in case my problem worsens.
  3. Feb 25, 2011 at 9:43 AM
    achirdo
    achirdo [OP] I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Not sure what I am going to fix it. I guess I'll take to autozone when I get the time and check for codes and the starter. If neither of those I'm bringing to Toyota. But my problem is going to be recreating the problem infront of them b/c it doesn't do it everytime.
  4. Feb 25, 2011 at 6:46 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    YEa. I would check all your wires. I don't mean on the battery, I assume you know to do that. I mean the other end. Good ground, good wire going to/from alternator to starter. Any of those corroded inside or out or loose will occasionally not make contact.. Pass bad voltage. Then get hot or vibrate and work.
  5. Feb 25, 2011 at 7:00 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The TSB is for an engine ECM flash, right? Take the truck in for the gas pedal mod / brake override recall, and you automatically get the latest ECM flash.
    I always turn the key to "on", wait for a few seconds for the brake pump wurr to finish, then start the engine.
