Starter engaging when turning ignition off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clh850, Feb 18, 2015.
  1. Feb 18, 2015 at 8:19 PM
    clh850
    clh850 [OP] Well-Known Member
    Cody
    PCB, Florida
    '14 TRD Sport
    This happens every time I cut the ignition off. The bendix doesn't actually engage the fly wheel, the starter motor just spools up. Has anyone else dealt with this issue or heard of it happening?
  2. Feb 18, 2015 at 8:25 PM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    I think new 4runners do this too...
  3. Feb 18, 2015 at 8:30 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Your truck does not want to stop driving around. It's feelings are hurt.
    jk -
    That does not sound right. I would have that checked out.
  4. Feb 18, 2015 at 8:36 PM
    clh850
    Cody
    PCB, Florida
    '14 TRD Sport
    Haha... I'm thinking that it must be an electrical problem.
  5. Feb 18, 2015 at 8:39 PM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Are you sure what you are experiencing is not the emissions system doing it's thing? You do know that your truck will make THAT noise every time you shut it off. That might sound like the starter to you. Check out those threads, you'd be surprised by how many wonder what that sound is...
    http://www.tacomaworld.com/forum/2n...lowoff-valve-sound-engine-after-shut-off.html
    http://www.tacomaworld.com/forum/2n...se-engine-when-shutting-down-2013-tacoma.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/247541-loud-air-pump-sound.html
    etc...
  6. Feb 18, 2015 at 8:44 PM
    clh850
    Cody
    PCB, Florida
    '14 TRD Sport
    Thx I'll check that out. I previously owned a '08 taco and never noticed it.
  7. Feb 18, 2015 at 8:45 PM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    I don't think it started happening until 2012.
  8. Feb 18, 2015 at 9:33 PM
    clh850
    Cody
    PCB, Florida
    '14 TRD Sport
    After reading a few threads I can see now that this is very common. Sounds like it's the emissions pump doing its thing. Thanks for the advice!
  9. Feb 18, 2015 at 11:02 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The Denso starters used in these trucks will not spin the motor without first engaging the drive pinion with the ring gear. They do not use a bendix, but rather a mechanical lever from the solenoid to the starter drive, so if the drive does not engage, the solenoid contacts will not close the circuit to power the starter motor.
    All this to confirm that it is not the starter you are hearing.
  10. Feb 19, 2015 at 5:27 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    The air pump only runs for 10-20 seconds during cold startup, and at no other time. If this noise happens after running the truck for longer, it's not the air pump.
  11. Feb 19, 2015 at 6:22 AM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    See threads linked above. Noise is after shutting truck off.
  12. Feb 19, 2015 at 12:03 PM
    ecoterragaia
    Central Virginia
    I did. One of them mentions that the noise only happens when moving the truck in their driveway (i.e. starting engine and shutting it down a few seconds later). In that case the noise is the air pump because it was running when when the engine was shut off. The other two dont give specifics on how long the engine was run before shut down and hearing the noise. I was just trying to say that, unless you hear the noise when you're starting cold and shutting down a few seconds later, it can't be the air pump as it only runs for 10-20 seconds after a cold start and at no other time.
