Starter relay kill switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Carlifter, Jan 30, 2019.
  1. Jan 30, 2019 at 2:31 PM
    Carlifter
    Carlifter [OP] Member
    13 single cab 2.7 5 lug
    Few led lights. Bullet muffler right after the cat
    Hello all, I could use some help finding the ground to the starter relay. I’m going off this thread https://www.tacomaworld.com/threads/kill-switch-mod-write-up.88252/ but I don’t want to use a power wire and risk a short.
    Does anyone know where the ground wire is? I’m hoping that it’s inside the cab like the green and black wire in the thread I posted and not in the engine bay. Thanks in advance.
  2. Jan 31, 2019 at 5:28 AM
    caribe makaira
    Caribbean, Puerto Rico
    It's not...it's in the engine fuse box
    Jimmyh likes this.
  3. Jan 31, 2019 at 6:24 AM
    Carlifter
    Just my luck. Thanks so much caribe.
    Where did you get your schematic if you don’t mind me asking?
  4. Jan 31, 2019 at 8:57 AM
    whttaco2whl
    whttaco2whl Well-Known Member
    KC
    North of LA
    2009 Tacoma base model, 2Whl 5Lug
    None
    Yes, please. I have the OEM factory electric manual, and it's not real user friendly. I don't know if it's a culture thing but the layout is not intuitive. I guess it works well for factory guys, and Toyota certified mechanics...? Working on private jets 45 years this month, and it's a POS in my opinion.
    I would like to find the source you used for the reply if available.
  5. Jan 31, 2019 at 9:31 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  6. Jan 31, 2019 at 12:36 PM
    caribe makaira
    Just two pages all mashed up and simplified...using PAINT...
    The source is online on many places...I don't have a link to it right now...
  7. Jan 31, 2019 at 12:41 PM
    Muddinfun
    Muddinfun Well-Known Member
  8. Jan 31, 2019 at 5:10 PM
    caribe makaira
    OP, you could get a one slot male & female connector, remove the ground terminal from 2A and mate them, then run the other side of the (male) terminal into the cab, hiding this wire in the OEM loom...
  9. Feb 1, 2019 at 10:44 AM
    Carlifter
    That’s sort of my plan I’m more of a cut and solder/splice type of guy.
    The part I’m going to struggle in is getting the wire through the loom into the cab.
  10. Feb 1, 2019 at 12:20 PM
    caribe makaira
    Hide it with black tape...there's a "nipple" under the firewall harness seal, most can't even look for it and wedge wires between the seal and the metal even in 3rd Gen. You could also share the hood opening cable exit.
