Starting issue. Fuel pump?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mrjack, Nov 23, 2019.
  1. Nov 25, 2019 at 7:07 PM
    mrjack
    mrjack [OP] Active Member
    2017 Tacoma TRD Pro
    Thanks for the info guys. I stopped by auto shop after work and had them test the battery. It tested fine but they did have trouble getting a connection on the tester at first, probably due to a little bit of corrosion. I cleaned up the posts so we’ll see what happens tomorrow. I hope it really is that simple!
  2. Nov 25, 2019 at 7:19 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Didn’t read all posts but my wife’s xterra was doing the exact same thing and I though it was fuel pump too. After it died and left her stranded it ended up being the cam position sensor that was going out. Got it replaced and no problems since. Worth a try?
    jetfishn likes this.
  3. Nov 26, 2019 at 8:37 PM
    mrjack
    2017 Tacoma TRD Pro
    After cleaning the battery posts, no starting issues today. I’m going to give it a couple more days before I call it definitively but it’s looking like maybe it was just a bad battery connection after all.
    The hammer, GreyBaldTaco and hiPSI like this.
  4. Nov 26, 2019 at 8:41 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    There are some pretty smart people here. And a lot of dumbassery too.
    SR-71A, mjp2, LSUfan1975 and 4 others like this.
  5. Nov 26, 2019 at 8:49 PM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    Sounds about right, loose/dirty connections can cause the starter to draw more amperage so even if your battery is good it will be hard to start
    Chew likes this.
  6. Nov 27, 2019 at 3:50 PM
    mrjack
    2017 Tacoma TRD Pro
    Well the problem just reared it’s head again. :mad:
    I may go ahead and replace the battery before doing anything else.
    shakerhood and GreyBaldTaco like this.
  7. Nov 27, 2019 at 4:05 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    My buddy just had his 2007 Dodge Cummins not want to turn over after parking at a lumber yard. Truck was fine up till then. No click or any electrical response whatsoever.
    We tested the battery, and it was good. We disconnected the battery terminals and thoroughly cleaned and reattached them. No dice!
    Then noticed that the key fob wasn't locking/unlocking either.
    After some Googlefoo, we found a fix that worked. Just completely isolate the batteries from the truck so the ECU gets a fresh reset.
    Bingo!
    Truck turns over properly and starts, and key fob was back in business.
    When we clean the terminals earlier, we did one at a time so he always had 12v applied as he has two batteries.
    Not saying this is the answer to a Gen 3 Tacoma, but you never know with these vehical computers nowadays.
  8. Nov 27, 2019 at 4:13 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    When you turn the vehicle to the on position, you ought to be able to hear the pump run for a sec or two.
    Have someone turn the vehicle to "on" but without starting, while you listen by the filler tube to a sort of buzz sound.
  9. Nov 27, 2019 at 6:34 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    2017 might be time. i took the tools to replace to costco went inside made sure they had the battery then removed it in the parking lot wheeled it in and got the new one and core discount in one trip. installed in the parking lot and away i went.
  10. Dec 2, 2019 at 3:29 PM
    mrjack
    2017 Tacoma TRD Pro
    I finally got around to picking up a new battery today. Will report back in a few days with results.
    outlawtacoma and shakerhood like this.
  11. Dec 3, 2019 at 7:02 AM
    mrjack
    2017 Tacoma TRD Pro
    Well already I think there's still an issue. It hasn't done the flat out no start issue but when I started it this morning the starter made a weird noise as if it didn't disengage immediately after the engine started. I don't know what that means but it just doesn't seem right.
  12. Dec 3, 2019 at 7:15 AM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    dealers and fitness experts love dealing in bro science
    ryan760 and GreyBaldTaco[QUOTED] like this.
  13. Dec 3, 2019 at 7:25 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    That may be "normal". Mine does it when it's really cold (say below 14F).
  14. Dec 3, 2019 at 8:21 AM
    mrjack
    2017 Tacoma TRD Pro
    I'll keep an eye on it. It was parked in the garage so temp was around 50 this morning.
    Inconsistent problems like this drive me crazy because I become hyper aware of every little thing it all feels like a potential problem!
    SR-71A likes this.
  15. Dec 3, 2019 at 8:29 AM
    #35
    topdawgi
    topdawgi Well-Known Member
    Brian
    Pembroke Pines, FL
    2019 Silver Sky Tacoma SR5 4x4 DCSB
    Ditto
  16. Dec 5, 2019 at 5:58 PM
    #36
    mrjack
    2017 Tacoma TRD Pro
    Well, after 3 days with the new battery it's happened again and I caught it on video.
    It only has one little bobble in this video but it happened again just a few minutes ago and turned over 7 or 8 times before it fired.
    Does this give us any clue as to what's going on?
  17. Dec 5, 2019 at 6:30 PM
    #37
    fiftyxp
    Starter fuel pump alternator next check
  18. Dec 5, 2019 at 6:35 PM
    #38
    mrjack
    2017 Tacoma TRD Pro
    I just found this thread and this guy's truck sounds exactly like what mine is doing intermittently.
