Starting the build! over $5,500 going into the stereo! Follow me..
Discussion in 'New Members' started by IgotThis87, Sep 13, 2013.
  1. Apr 24, 2015 at 8:47 PM
    #261
    HWYCAT
    HWYCAT Member
    ANDY
    CALIFORNIA
    TACOMA-LONG BED
    LOTS
    DID YOU SAY SOMETHING? I CANT HEAR YOU!!! WHATTTTTTTTTTTTT......
    IgotThis87[OP] likes this.
  2. Apr 24, 2015 at 8:52 PM
    #262
    Raincity
    Raincity Half man, half amazing.
    Lowermainland, B.C.
    '13 Mica Spruce DC.
    '12 DC TRD-RIP
    Wicked install, the detail and extra features is over the top. Nice job!
  3. Apr 24, 2015 at 9:02 PM
    #263
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    5k hey? Is this the stereo from "The Italian Job" that blows the clothes of girls?? :D
    IgotThis87[OP] and 95 taco like this.
  4. Apr 24, 2015 at 9:41 PM
    #264
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Oh and damn your garage is clean!!!
  5. Apr 24, 2015 at 9:42 PM
    #265
    FixedGearMike
    FixedGearMike Well-Known Member
    Hotlanta
    13 TRD Taco OME 3 inch lift
    Leer camper
    Awesome build, both times!! Thanks for putting forth the time and effort to document for us
  6. Apr 24, 2015 at 9:56 PM
    #266
    tacozord
    tacozord Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    Awesome work!!!
    Can you explain what exactly is going on here in detail? I've seen you use this fabrication process here and very early on when fabricating your center console and bed access panel. What are the materials used and what is the process? Any more information you can provide would be helpful. Any links to external sites with tutorials or anything?
    Thanks!
  7. Apr 25, 2015 at 7:01 AM
    #267
    IgotThis87
    IgotThis87 [OP] MECP certified member
    Dustin
    08 Tacoma
    Electronics, stereo, remote start, security, dash mods
    Awesome work!!!
    Thanks![/QUOTE]
    Sure and thank you! In these pictures I am building the amp rack out of the old storage compartment that comes factory under the back seats. I just needed the top of it to help form and match the contours of the floor. Starting at the top I cut the lid off of the compartment and attached 3 pieces of 1/4" MDF where I was going to mount the 2 plexi windows and the Front Row processor. Then I stretched the green material (any stretchy absorbent material would do when fiberglassing small projects) then I covered the material in fiberglass resin to harden its shape. I strengthened the green material where the wood isn't covering with fiberglass mat on the back side so it wasn't so thin and brittle. Next I applied bondo to even out the top and form the smooth corners and slopes. A lot of sanding involved!!! Once I cut out the squares for the components to fit I carpeted the finished piece with the same box carpet I used on the subwoofer enclosure for a good match.
    BamZipPow likes this.
  8. Apr 25, 2015 at 8:35 AM
    #268
    HWYCAT
    HWYCAT Member
    ANDY
    CALIFORNIA
    TACOMA-LONG BED
    LOTS
    Wow!!!! Very Nice Job! How many miles of wire did you add? : ) 2 thumbs up!!
  9. Apr 25, 2015 at 11:12 AM
    #269
    tacozord
    2015 DCLB 4wd SR5
    Thank you for the info. I have a few more questions.
    1. Is the green material a fabric like polyester or fleece?
    2. After applying the resin, did you apply layers of fiberglass?
    3. Did you add the MDF specifically to have a mounting surface?
  10. Apr 25, 2015 at 10:57 PM
    #270
    DoccoM85
    DoccoM85 Well-Known Member
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    What the crap........ Nicely done man, glad i watched the video, i knew once i saw the Amp Rack thing you made this thing was going to be sweet. But i cant say i expected that kind of install =D
  11. Apr 28, 2015 at 3:30 PM
    #271
    IgotThis87
    Dustin
    08 Tacoma
    Thanks guys! I really appreciate the comments and views! I'm excited for it to warm up so I can take it to the lake and drop the tailgate :)
  12. Apr 28, 2015 at 3:40 PM
    #272
    IgotThis87
    Dustin
    08 Tacoma
    The green material is a stretchy fabric idk where it came from it was just in a closet. Anything absorbant and stretchy will work. Being stretchy helps to form to the curves and absorbant to let the fiberglass resin soak in. You could even use an old t-shirt like I used for the radio housing behind the shifter.
    I did apply layers of the fiberglass mat on the back side while it was wet but only to the parts that were thin and needed thickness for strength.
    I used MDF to have something to mount to and pressure the plexiglass into. Also for make the top flat because the stetched material probably would have sagged without it, even stretched tight
  13. Mar 3, 2016 at 8:47 PM
    #273
    jhpisces
    jhpisces Well-Known Member
    Jeremy
    North Dakota
    08 SR5 w/ 6" ProComp lift
    6 inch pro comp suspension lift, Headlight and tail lights changed out, AFE Cold Air Intake, thin lip satoshi, blue sea fuse block with 100 wt amp, 10" pioneer ground pounder, Pioneer 2500BT head unit, rear diff breather mod, big three upgrade, rearview camera,
    great job. looks sick!
  14. Sep 13, 2018 at 8:15 AM
    #274
    IgotThis87
    Dustin
    08 Tacoma
    Well guys, I went to a Tundra since you've heard from me last. Actually this is my 2nd Tundra since then. But I miss my Taco and will more than likely go back to one. BUT this is what I've been up to this summer (click the YouTube link for my video) and wanted to share with you guys! Hope everyone's doing good! And FYI so far my stereo is 100% stock in the Tundra lol
    https://youtu.be/ae-gwRb1tc4
  15. Sep 13, 2018 at 8:26 AM
    #275
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Im thinking its the camera angle but man i cringed at 0:47
  16. Sep 13, 2018 at 8:30 AM
    #276
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    Only thing worse than jet skis are jet ski boats. RIP to that butter
  17. Sep 13, 2018 at 9:08 AM
    #277
    tbr3345
    tbr3345 Well-Known Member
    Tom
    Sacramento, CA
    2010 TRD Sport DBL Cab Silver Streak Mica
    Sorry officer I did't hear the fire truck or ambulance, can they be repaired?
  18. Sep 13, 2018 at 9:09 AM
    #278
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Yes, there will probably be several.
  19. Sep 13, 2018 at 9:39 AM
    #279
    IgotThis87
    Dustin
    08 Tacoma
    Haha definitely the angle I've been backing trailers my whole life, it went smoothly lol thanks for checking it out!
  20. Sep 13, 2018 at 2:03 PM
    #280
    Page10
    Page10 Well-Known Member
    Kaleb
    2018 Cement TRD Sport DblCab
    What drone did you use? Cool shots in the video
