Startup Squeal, new belts, only when cold.
Discussion in 'Technical Chat' started by krlang, Mar 16, 2009.
  1. Mar 16, 2009 at 2:21 PM
    krlang
    krlang [OP] NewEnglander
    Commonwealth of Massachusetts
    03 2WD 2.4L Tacoma Reg Cab
    Chrome Bumpers F&R, Grille & Corner Lights, Wheel Skins, Red/Clear LED taillights, Remote start, PDL, Cruise, K&N, All Kenwood, DNX-5120 6.1" NAV/TRAFFIC/DTV/DVD/XM/BLUETOOTH/USB/IPOD/SUB/rear cam, Tint, Air Band radio, Class 3 Hitch with 4/7 pin harness, Transmission Cooler, Red Top Battery, "Deck Plate" mod.
    Hey,
    I have a squeal that has been awful. OOPS! here we go.
    When I start my truck, usually when its cold it happens.
    It lets out this horrible belt squeal, I tightened them once.
    It seems like an alternator thing, possibly water pump.
    Next weekend I guess I will try to take a belt off and let it cool off.
    Try it and if thats not the one, I will move to the next belt and try again.
    Any Suggestions?
  2. Mar 16, 2009 at 2:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sounds to me like a bearing/pulley issue instead of a belt issue...especially since you have new belts on now. may be as simple as a tensioner pulley bearing.
  3. Mar 16, 2009 at 3:43 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    before u do all that try using some chalk on the belt/s.just regular old chalk,its an ancient chinese secret.i really does work.oh do it while its running.if u cant get your hand down in there(be very careful)just tape it to a stick/3/8 extension what ever.good luck.had the same on my 05 and its all gone.later
  4. Mar 16, 2009 at 4:31 PM
    krlang
    I thought of that, but they felt fine when I had them off 6k ago.
    I removed the pulleys, cleaned off the dirt and debris from under the covers.
    Spun them in my fingers and the bearings felt smooth.
    It seems as if something is not spinning as it should at startup.
    We will see.
    Thanks, K.L.
  5. Mar 16, 2009 at 8:22 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are the belts tight enough?
    Have you tried tightening them a bit more? Or perhaps they're too tight.
    How old are the belts?
    Also - check your A/C idler pulley (if you have one). Those (bearings) are notorious for going bad in the 1st gen trucks. It might be on the verge of going bad and just starting to squeek.
