Stashing a spare key on the outside of the truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Apr 9, 2012.
  1. Apr 9, 2012 at 10:45 AM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    Need some ideas...
    I go 4 wheel often in nice weather so I am weary of the magnetic boxes. I would like to hear what else others are doing out there.
  2. Apr 9, 2012 at 10:46 AM
    ninja_taco
    ninja_taco Well-Known Member
    Nick
    Louisiana
    '10 Prerunner
    Vanillarama Pinetree Scent
    keep a spare in your wallet
  3. Apr 9, 2012 at 10:46 AM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    Keep a window down or cracked enough to get your arm in so you dont lock your keys in..it cant be that common for the same person to do that over and over....I always roll my window down if Im going to leave and close the door
  4. Apr 9, 2012 at 10:47 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    '18 T4R & '06 F250
    6" lift 40s
    mount a small pelican box? they are durable and waterproof...
    I like to stash a key in the wallet on trips, dont like the keys on the truck...
  5. Apr 9, 2012 at 10:47 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I use a piece of steel wire and lash it to the frame in a certain spot where it is out the way and can not be seen unless you know where it is or are looking really hard.
  6. Apr 9, 2012 at 10:48 AM
    Warhorseforever
    Will
    Sand Lapper
    Da fuq is a zip tit? :rofl:
  7. Apr 9, 2012 at 10:49 AM
    Madjik_Man
    I like small wallets and there's no way a key will fit in mine.
    I'd have to have the window rolled all the way down in order for my guns to fit through :p
    Seriously though, it's more of a back up in case I lose my keys or something as well.
    And just a heads up, if someone reaches in and grabs your registration, they can easily steal your identity. That's what the savvy asshole crooks are doing these days
  8. Apr 9, 2012 at 10:51 AM
    ninja_taco
    Nick
    Louisiana
    '10 Prerunner
    i was just thinking with your '98 you could get a flat key (no rubber non-sense) but i may be wrong
  9. Apr 9, 2012 at 10:51 AM
    Madjik_Man
    I like this idea.
    As well as exploring what a zip tit is :eek:
  10. Apr 9, 2012 at 10:52 AM
    Madjik_Man
    That's what I had.
    Unfortunately I just had to have a new lock cylinder put in my ignition and the blank keys the dealer have these days have that rubber nonsense BS.
  11. Apr 9, 2012 at 10:53 AM
    Warhorseforever
    Will
    Sand Lapper
    On my dad's silverado we have a bolt welded to the frame and a key with a hole big enough to go over the bolt with a nylock wing nut holding it down.
  12. Apr 9, 2012 at 10:53 AM
    ninja_taco
    Nick
    Louisiana
    '10 Prerunner
    thats no good. i agree the zip tie is a great idea if u keep something on u to break it off
  13. Apr 9, 2012 at 10:55 AM
    Madjik_Man
    Yeah, I'd just keep a pair of cheap dikes in the storage box
  14. Apr 9, 2012 at 10:55 AM
    ninja_taco
    Nick
    Louisiana
    '10 Prerunner
    ah, problem el solved'o
  15. Apr 9, 2012 at 10:59 AM
    Madjik_Man
    Cool idea... but I don't have a hitch.
    And I know they thought of this, if I am, but if it takes seconds to install/uninstall without tools, what's preventing someone from removing the whole assembly from the hitch?
    I don't understand the "two bolts capture but (whatever) inside the hitch" concept
  16. Apr 9, 2012 at 11:02 AM
    ninja_taco
    Nick
    Louisiana
    '10 Prerunner
    yes, big burly women that make u look like a girly man
  17. Apr 9, 2012 at 11:04 AM
    Madjik_Man
    Yeah.
    They don't mind the zip tits
  18. Apr 9, 2012 at 11:07 AM
    ninja_taco
    Nick
    Louisiana
    '10 Prerunner
    i literally just :facepalm:and then :rofl:
  19. Apr 9, 2012 at 11:09 AM
    Madjik_Man
    :D
  20. Apr 9, 2012 at 11:15 AM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    Inside your rear bumber is a good spot, I have had my truck for two years and just found one there when i changed bumpers...
