Stealing a Tacoma... Easy?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LS1Steve, Sep 13, 2017.
  1. Dec 17, 2018 at 1:49 PM
    #221
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I watched my AAA guy get into my truck in under 5 min after my keys were locked in the truck. Also the alarm doesn’t sound if you lock the doors manually when you get out instead of with the fob.
    The AAA guy used an inflatable air bag and a wedge to open the top of door a bit then used a wire to hook the lock switch. Pretty quick.
    boostedka[QUOTED] likes this.
  2. Dec 17, 2018 at 1:49 PM
    #222
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Didn't work in our apartment complex. Burglar got shot trying to rob a couple and we have had steady crime since. they hired a rent a cop to drive around like a walmart parking lot attendant. Dude circled the neighborhood twice and then left every night and they couldn't figure out why crime didn't drop.
    Get a good camera system out front and point it at your beloved taco and hope it catches them in the act. Aside from that, when you take the key out, crank the wheel, it locks it and you won't be even able to turn the key unless the wheel is turned while turning the key. Kill switch could be a better option though. Wire in a hidden switch and when you park in shady areas flip it. you'll lose your radio data but that's a small price to pay.
    boostedka likes this.
  3. Dec 17, 2018 at 2:13 PM
    #223
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Just unplug the ECU fuse, problem solved. Truck won’t start at all.
  4. Dec 17, 2018 at 5:34 PM
    #224
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    If there's a rear slider, it's even easier after doing it once. Hilariously easy.
    DavesTaco68[QUOTED] likes this.
  5. Dec 17, 2018 at 5:49 PM
    #225
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    We had our company truck stolen so we came up with an ingenious anti theft device. We tapped into the ignition circuit so that when the key is turned (or hot wired or ignition cylinder forced) it will turn the starter but no power is sent to the coils therefore no start. Thieves keep trying to start due to the starter turning but no start. The ignition circuit was run through the cigarette lighter. We then had a charging cord modified. Push the charging cord plug into the cigarette lighter and boom circuit completed and the truck will start.
  6. Dec 17, 2018 at 6:20 PM
    #226
    TacoCarl35
    TacoCarl35 Well-Known Member
    Karl
  7. Dec 17, 2018 at 7:16 PM
    #227
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Wheel locks are very easy to bypass.... just over tighten the non wheel lock lugs and it’ll all you to loosen the wheel locks. Don’t kid yourself that wheel locks would have made a difference.
  8. Dec 17, 2018 at 9:22 PM
    #228
    TacoCarl35
    Karl
    Well aware of that. But doing so triggers my new alarm. Gorilla locks have a spinning top which helps against that. I’d suggest multiple locks of different kinds.
    Nothing can stop a determined thief but you can make sure they waste as much time as possible. Tilt censor on my alarm as well I’m good now
  9. Dec 18, 2018 at 5:07 AM
    #229
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Say whatcha want but club on st wheel and one of those unpickable, unfreezable, unshootable, unsawable pedal locks on clutch pedal means time spent to try and defeat club and clutch pedal not depressable to floor = starter kill. Bar on rear slider, multiple tailgate locks, multiple wheel locks & oem stereo = much easier and profitable targets elsewhere. Garage is also huge deterrant at home. The clutch pedal lock also has some 50 or 75k warranty on it if defeated some unknown way. Bullets are faster than thieves too.
    Helpful hint for wheels....tighten lock(s) last and loosen first.
    Yeah, anything is possible past a certain point.........move that point farther out every way you can and improve your odds.
    boostedka and ChadsPride like this.
  10. Dec 18, 2018 at 5:13 AM
    #230
    BobnCo
    BobnCo Active Member
    Bob
    2018 INFERNO TRDOR gone
    easiest way the dirtbags are stealing vehicles now is with a stinger. Like a repo guy has. Fast and quiet and no locks, alarms, etc. are going to do you any good.
  11. Dec 18, 2018 at 5:19 AM
    #231
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Read your post. What a dismal display of help they gave you. I read another post here on TW about odometer fraud where the local PD gave the same response. Not a wonder so many crimes are occuring. Even if they did, a greaseball lawyer would probably get them out of it. SMH.
    TacoCarl35[QUOTED] likes this.
  12. Dec 18, 2018 at 4:02 PM
    #232
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    That is very creative... just hope you never need to use the cigarette socket while you are driving!
  13. Dec 18, 2018 at 4:07 PM
    #233
    Jason@RSG
    Jason@RSG Active Member
    I like the cigarette lighter "push to start" Basically, you un hook the +12v wire from your cigarette lighter then, when you push the lighter in it now has a ground coming out of the +12v wire from the lighter. You connect wire that to a relay that connects to the starter wire of our vehicle which has been disconnected from the ignition switch. Works great!
  14. Dec 18, 2018 at 4:15 PM
    #234
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    i read thieves have been using tennis balls to unlock your doors
  15. Dec 18, 2018 at 5:33 PM
    #235
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
  16. Dec 18, 2018 at 5:50 PM
    #236
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    How does that work?
    Spare Parts likes this.
  17. Feb 6, 2020 at 5:44 AM
    #237
    djgynee
    djgynee Well-Known Member
    Southern California
    2018 Magnetic Grey Metallic Tacoma DCLB TRD Sport
    Ok ok. If it’s a battle of deterrent vs determined. Determined wins every time.
  18. Feb 6, 2020 at 6:49 AM
    #238
    DG92071
    DG92071 Well-Known Member
    Theives don't hotwire vehicles anymore, ever. A "good" thief (sic) can get into a Tacoma with a special shaped flat blade screwdriver as quickly as you can get in with the key. The Clubs steel is thick but that steering wheel cuts like butter with almost any hand saw, the wheel can be cut in less than 2 minutes, and the steering wheel is bent to get The Club off. If the stock key is chipped most theives will vandalize and move on, if the stock key isn't chipped they'll typically use a filed key to start the truck and be driving away in a few seconds. Car alarms will deter most theives as there's just too many vehicles that don't have car alarms.
    If they want it they'll get it. <-period
    I saw a 911 Turbo being dragged onto a flatbed in San Francisco. The headlights were wig-wagging, the parking lights were blinking, the stock horn and air horns were honking, all 4 tires were locked, and that sucker was gone in 10-15 seconds.
    Skyway and lucky13don like this.
  19. Feb 6, 2020 at 6:56 AM
    #239
    DG92071
    The latest thing that was occurring when I stopped working in the industry is theives would break into a house while the people in it were sleeping to get the car keys. High end cars were getting stolen a lot by this method.
  20. Feb 6, 2020 at 3:06 PM
    #240
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You were a car thief?
    :eek:
    Alexely999 and CurtB like this.
