Steel vs Alloy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pridgway, Dec 13, 2017.
  1. Dec 13, 2017 at 3:31 PM
    pridgway
    pridgway [OP] Well-Known Member
    2014 TRD Off Road
    Looking at the possibility of replacing my stock 16" OR rims (primarily for looks) with either a new set of allows or steel. Steel is enticing being you can get good looking one for much cheaper. Is the weight that big of an issue? Will a daily driver with manjority highway miles notice it?
    Trying to see if i can get what i want with steel or should i really just fork out the cash for some SCS or OEM alloys? If alloy is much better, than I might as well stick with the stock ones, and can put that money to other mods.
    Thanks,
  2. Dec 13, 2017 at 3:32 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    The lighter you can make it the better
  3. Dec 13, 2017 at 3:33 PM
    pridgway
    2014 TRD Off Road
    is the biggest reason just for MPG's? How much will it change overall do you think?
  4. Dec 13, 2017 at 3:34 PM
    R242
    R242 I have a tortoise
    Rick
    Indianapolis, IN
    2024 SR 4x4 6 spd
    Well oem steelies weighs the most, at roughly 31 lbs(17" steelies). That's what I'm running right now, and I notice the difference in mileage with a 2.7. Oem alloys aren't much lighter, avg 28lbs at 17".
    I married my tacoma likes this.
  5. Dec 13, 2017 at 3:35 PM
    R242
    Rick
    Indianapolis, IN
    2024 SR 4x4 6 spd
    Not much different on a 4.0, but the wheels are the best thing you can lighten up.
  6. Dec 13, 2017 at 3:36 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    If you switch between steel and alloy, you will need different sensors. They do not interchange.
  7. Dec 13, 2017 at 3:37 PM
    R242
    Rick
    Indianapolis, IN
    2024 SR 4x4 6 spd
    That's true too...I forgot my oems were also steelie, just the 5star version
  8. Dec 13, 2017 at 3:40 PM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    If you go with steel let me know. I have 4 sensors I’ll sale you for $50. They came off my OEM.
  9. Dec 13, 2017 at 3:42 PM
    pridgway
    2014 TRD Off Road
    So if I do switch over over from alloy to steel for cost purposes, it will cost more to switch sensors as well. Makes the switch less enticing..
  10. Dec 13, 2017 at 3:49 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I weighed the 16x7 steelies and they weigh about 28 lbs. The 16" 3rd Gen OR wheels are between 24-25lbs. The lighter the wheels/tires, the better overall.
    Also steelies tpms will fit alloys.
  11. Dec 13, 2017 at 4:00 PM
    Hopesfall
    Hopesfall Active Member
    Travis
    Keizer, OR
    2011 DCSB PreRunner
    Beware there are different alloys. If you plan on doing any kind of offroading, or heavy load carrying, do not buy cast alloys. The material ends up weaker than forged, and you will end up spending a ton of money repairing and replacing them. Cast is fine for light trail driving and normal around town use, forged is ok for medium off roading. If you plan on doing some pretty rough stuff, bite the bullet on weight and get steel.
  12. Dec 13, 2017 at 4:13 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    3rd Gen OR wheels are a lot better looking than 2nd Gen ones. If you want to keep cost down, get those. I do believe the 2nd Gen OR wheels are lighter by a couple of pounds though. There's a few OEM alloys that are nice looking. Only reason manufacturers use steel wheels are to keep cost down that's why you only see them at the low end models.
  13. Dec 13, 2017 at 4:18 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I have aftermarket 16" steelies and will be switching to a 19lb SCS rim sometime soon. I can't wait to see how much the weight difference will feel and perform.
  14. Dec 13, 2017 at 4:19 PM
    pridgway
    2014 TRD Off Road
    Yeah Ive seen some second gens with third gen OR wheels. Look pretty nice, probably can find a nice set for cheap when new 3rd gen owners go after market.
    I like the 4Runner TRD Pro wheels, if that which OEM alloys youre thinking of
  15. Dec 13, 2017 at 4:21 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  16. Dec 13, 2017 at 4:26 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Basically pretty much all the 6 lug wheels off FJ, 4Runner, Tundra, and Sequoia (tacoma and pick ups included) will fit and some of them are actually nice and can be had for cheap. I've seen 3rd Gen wheels and tires go for as cheap as $500.
    I personally like below and can be had for $200 or less a set.
  17. Dec 13, 2017 at 4:27 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I keep hearing this, but the sensors that came out of my alloys and steelie are identical :notsure:
  18. Dec 13, 2017 at 4:44 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    If they work then that's cool, but I know the part numbers are different and I thought they mounted at a slightly different angle, but I could be wrong about that.
  19. Dec 13, 2017 at 6:21 PM
    pridgway
    2014 TRD Off Road
    I already have 6 lug toyota alloy set. I would like an upgrade either in performance or looks.
  20. Dec 13, 2017 at 6:26 PM
    Snotrocket
    Snotrocket Well-Known Member
    Maine
    2022 TRD OR DCLB
    Alloys from a 4runner will bolt right on as well. I bought a set of 4 for $400ish off a 2016 that had never been mounted.
