Steering Column Clunk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jayg220, Jan 1, 2021.
  1. Jan 1, 2021 at 6:18 PM
    jayg220
    jayg220 [OP] Well-Known Member
    James
    2006 Tacoma TRD 6-speed
    2.5" lift (front) 1.5" AAL, Clutchmasters Throwout bearing, ECGS bushing
    Hi guys, I noticed today on my 2006 that when I turn when I'm stopped or very slowly rolling, I get a popping sound then followed by a clunk. Definitely sounds like it's coming from the steering wheel/under the pedals area. The truck was in for an alignment just two weeks ago so all the tie rods and suspension were checked and I was told all was good. It has a 2" suspension lift. The sound is more prominent when turning right then left. The wheel does not turn hard it just sounds like a popping. Also, sometimes the lights on my steering wheel buttons will not light up, then I will turn the wheel and they will come back on. Think it has something to do with the clock spring? Intermediate shaft? I did do some digging before this and not much I could find for a common issue. If it helps I do live in a cold and currently snowy climate.
    Thanks!
  2. Jan 1, 2021 at 6:21 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  3. Jan 1, 2021 at 6:39 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Check all the work that was done for proper torque,sounds like something iwas not tightened properly.
