Steering column fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, Apr 19, 2010.
  1. Sep 1, 2017 at 6:16 PM
    #261
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    The reference I made to the air pump was my weak attempt at humor, specific to the 2012 trucks.
    ?? I still don't get this ...
  2. Sep 1, 2017 at 6:30 PM
    #262
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Man, Toyota gave me such a hard time about this when I had my 2006 Tacoma. I had the noise and play and they couldn't find the issue and wanted to charge me $2K to replace steering parts, not under warranty.
  3. Sep 1, 2017 at 6:49 PM
    #263
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    2012 model year trucks have a well-documented issue with secondary air pump failures. This issue is completely unrelated to the steering shaft issue under discussion in this thread. I made reference to the air pump issue in this context as though to point out that there is always something else to fix or modify.
  4. Sep 4, 2017 at 9:23 AM
    #264
    imageomega
    imageomega Well-Known Member
    Jarrod
    Just did this the second time. For future readers, save yourself the zip tie and use a few small metal picture hangers. Won't degrade and you can bend it around the metal to stay secure. Unbend, force through, rebend.
    Also took out much more of the play and knock.
    jaymac10, jpereira2 and DrFunker like this.
  5. Sep 9, 2017 at 5:33 AM
    #265
    Drew12
    Drew12 Well-Known Member
    Andrew
    Sisters, Oregon
    2005 4x4 TRD OR Access Cab
    Bilstein 5100's/Toytec 620 coils, rear AAL, Camburg UCA's, Pro Comp 7069, AFE stage 2 CAI, Blacked Depo Headlights
  6. Sep 9, 2017 at 5:37 AM
    #266
    Drew12
    Andrew
    Sisters, Oregon
    How many did you have to use? I didnt see your post before posting my above reply, but as I stated, I could only fit a small zip tie. Will try again with picture hangers too as I can probably tap the metal hangers in there ensuring a tight fit.
  7. Sep 10, 2017 at 4:43 PM
    #267
    PDXKid
    PDXKid Active Member
    2011 DC TRD Off Road Manual Transmission
    Stock for now
    Did this mod the other day and it helped remove some of the play, not all.
  8. Oct 4, 2017 at 12:45 AM
    #268
    toyo_yoyo
    toyo_yoyo New Member
    I believe this issue is the same to 4Runner and Tacoma. I think we really need to understand how both designs have evolved over time to finally fix this.
    My vehicle: 3rd gen 4Runner 4wd (240k miles)
    I wanted to figure out why whenever I hit a bump, my steering went ape. A smaller concern was a loose steering in the spline.
    To understand this question, I did the following - all w/o driving until I finished the work:
    Reman steering rack (I converted the roller to the solid thing) which came calibrated w/ ITR (no need to set dial or play with settings, ostensibly). I then placed OTR, LBJ, UBJ, rear ujoint/bearings/seals (thanks: "Drcoffee" @ toyota-4runner.org for not following FSM/reversing redesigned seal), replaced rad while dropping tranny and filling w/synthetic, new fuel filter, wheels balanced on the overly-hyped machine, engine gaskets/spark tubes/etc.
    Result: the same
    So I say fuck it, and I weld the spline. The next 4-5k miles were perfect. Steering was responsive with little looseness.
    Then, something changed and something didn't. When I'd go over bumps, no more oh-shit type moments. However, the looseness expanded, and much more so. I'm now tracking down this looseness, so I came across this post.
    I was wondering about how the following 2 parts compare:
    45220-04020
    vs
    45290-35040
    Why such a weird recall turn-of-events? Alongside the guide re-design. I think someone needs to run some numbers here.
    I would like to understand the difference between the two. I will find a used 4Runner #2 version on Ebay, if we all can agree to crowd-source the following:
    1) Each year's version of Japan's version of 45220-04020
    2) Each year's version of Japan's version of 4Runner when steering guide changed '01
    This is neither a steering guide issue nor a #2 assembly issue - as can be shown in the "design" of a 4JaM.Tac (-weld) truck.
    It's a design defect. Maybe they were producing the same design defects abroad, but they just didn't find it optimal to change.
    I exchanged bumpy ride/slightly loose for no bumps/extremely loose
    Toyota needs to support its owners and be proud that people's trucks are still on the road. After all, these are the only trucks with this kind of mileage that not only could, but never were expected to be on the road like this.
  9. Nov 26, 2017 at 1:46 PM
    #269
    imageomega
    Jarrod
    I fit 3 in there. Size will make all the difference, I was using pretty small picture hangers.... but damn there was a lot of play. It drives really nice now (like it should in the first place...)
  10. Nov 26, 2017 at 6:16 PM
    #270
    Drew12
    Andrew
    Sisters, Oregon
    I fit three as well but now I have even more of a noise and definite movement in the column. Now even the tiniest of bumps and imperfections in the road produces a low pitch rattle. Taking to the dealer tomorrow to test drive with a tech to diagnose
  11. Nov 27, 2017 at 4:38 AM
    #271
    bigteninch
    bigteninch Active Member
    Scott
    Greenville SC
    15 TRD Off Road
    Did the zip tie fix to our '15 Taco and it worked great. The dealer acknowledged the looseness and even clunking left to right and said it was "normal". Good lord. Where have all the decent techs gone?
  12. Nov 27, 2017 at 3:21 PM
    #272
    Drew12
    Andrew
    Sisters, Oregon
    Just got back from Toyota about this issue. They re-torqued all the steering components. They said there is a TSB to replace the intermediate shaft but it doesn’t exactly fit my truck which is weird. It’s also $600 to get done. What could be a possible cause of the rattling is the rubber bushing for a lack of a better word is starting to get worn down which is why you hear the noise. It’s wearing and the metal pieces are starting to contact each other.
  13. Jan 24, 2018 at 9:19 PM
    #273
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    How does a TSB cost you anything?
    I have 2007 4x4 and my steering rack pops when I turn the wheel far enough. Dealer tells me there is no TSB for this...
  14. Jan 24, 2018 at 10:19 PM
    #274
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    A TSB ( Technical Service Bulletin ) . is a notice to dealers on how to address a specific issue.
    It is not a recall, but is only free during the initial 3 year 36K mile warranty period. After that it is on your dime.
    Drew12 and TireFire like this.
  15. Jan 27, 2018 at 8:37 AM
    #275
    Drew12
    Andrew
    Sisters, Oregon
    Sounds more like inner tie rod ends to me.
    TireFire[QUOTED] likes this.
  16. Apr 16, 2018 at 6:26 PM
    #276
    ijonahtacoma
    ijonahtacoma Well-Known Member
    Jonah
    2005 Black Tacoma with the turtle shell
    Seriously I'm just learning how to work on this thing.
    I literally just did this at a rest stop with a paper clip. Way better. Not perfect.
    Need a proper bushing...
  17. May 3, 2018 at 8:18 PM
    #277
    Dick4x4
    Dick4x4 Well-Known Member
    Quebec
    2012 4x4 2.7 Auto
    I have a 2012 with that exact same problem. I tried the zip ties but for my case it worsen it. Unmodified it was only on bumpy gravel road that I was feeling that play. Now with 2 or 3 big zip ties between the shaft and the collar, I feel the knocking in the steering about anywhere on the street and highway. It's pretty annoying.
    I would like to only replace the green bushing but it doesn't seems to be available. And one new intermediate shaft is expensive...
    Someone found a replacement bushing for that?
    Thanks
  18. May 12, 2018 at 7:19 PM
    #278
    Dye22
    Dye22 Well-Known Member
    Squamish
    '15 TRDOR ACLB
    JBA UCAs OME 2.5 in lift w/ heavy duty dakars. 33" ko2s tc bed stiffeners firestone airbags w/ ride rites cmc/pinchweld rear flushmount leds amazon ditch lights apex sliders 0 degree w/ kickout Coastal Offroad high clearance front bumper w/ full tubing Coastal Offroad high clearance rear bumper w/ tubing and dual swingout 100 AH LiFePO4 Aux battery blue sea fuse panel for aux battery rear diff mod breather Mountain Hatch tailgate insert Smittybilt x2O 10k winch Anytime Camera Mod Front and Rear GPS locator brick BAMF Hangers w/ custom crossbrace 2lo Mod by up2nogood yakima access cab roof bars thule hyper xl cargo box amazon roof basket ARB 1250 awning WaterPort Meso Dual Color Dome Light Durobump Front Bump stops
    did this today. was like a giddy school boy driving around. feels/handles sturdier. reduced steering slop/vibrations. very happy.
    if anyone is having trouble fitting a zip tie in there i found pressing a screwdriver against the zip tie and the black cylinder and levering upwards (or downwards depending on which way your sliding the zip tie in) with a bit of pressure worked great.
  19. Jul 20, 2018 at 4:37 AM
    #279
    PagoBay
    PagoBay Active Member
    2005 Tacoma TRD Sport
    Clunk and slop on my truck was because the green bushing in the intermediate shaft broke. Did the zip tie fix and it worked perfectly! No more clunking and no more slop. Feels almost as good as new.
    I will probably change the intermediate shaft sometime down the line per the TSB. Dealer doesn't sell the bushing alone and price for new shaft is $350 and another $300+ for labor. GTFOH:rant::der::luvya: Part online is about $200 and I'd rather do the replacement myself.
    Also, if anyone is wondering, the part number for the intermediate shaft (cab interior) is 45220-04020 or 45220-04010 (I believe the 04020 is the new upgraded version that replaces the old 04010 part).:cheers:
  20. Jul 26, 2018 at 7:15 PM
    #280
    ijonahtacoma
    Jonah
    I used paper clips. It's effective. Probably not perfect, but damn if ain't cheap.
