Steering column fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, Apr 19, 2010.
  1. Oct 19, 2012 at 12:46 PM
    #81
    Rooster Feather
    Rooster Feather Member
    Oklahoma
    2007 V6 SR5 4x4
    I did this fix last night along with the East Coast Gear Supply Bushing and new axle. I drive a bunch of gravel roads and the washboard drives me nuts. If I slow way down it pisses me off more, so I just blast on through them. My truck handles fine but the steering wheel knocks left and right. Makes me feel like I'm driving a piece of crap! I was browsing and saw the zip-tie fix so I added that to my repair on the front end. (btw- everything up front is tight. Checked it and rechecked it. The only slop is in the steering shaft.) I grabbed a few different sized zip-ties and went to work. I had some huge industrial ties that I ended up using. It slipped in with ease, so I put another one in it. Two big ties! It didn't eliminate the knock but it helped it. It made me wonder if it was so loose because of the roads I have to drive? Wish I could find a "true" solution.
    The bushing and new axle by the way, made a world of difference in the roar at lower speeds.
  2. Oct 19, 2012 at 1:27 PM
    #82
    MTaco
    MTaco Member
    Billings, MT
    06 TRD OR
    TJM Bull Bar, Sway-Away 2.0's, Light Racing UCA's, Timbren Bump Stops, Shrockworks Sliders, TRD exhaust, Edelbrock extreme travel rear shocks, Wheelers 3 leaf pack.
    I did this a few weeks ago. Can't believe how simple a fix and what a big difference it made. Makes driving the thing enjoyable again.
  3. Oct 19, 2012 at 3:59 PM
    #83
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    gonna try this on my '12. this has been driving me crazy for the past 3 months. my '05 had no issues in the steering.
  4. Nov 27, 2012 at 6:14 PM
    #84
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    Took out in to the dealership and they said they won't. Do anything cause of my lift. They did not even look at the TSB
  5. Jan 31, 2013 at 5:19 AM
    #85
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
  6. Feb 5, 2013 at 5:40 PM
    #86
    Tatanka
    Tatanka Well-Known Member
    Pennsylvania
    2014 DCLB TRD
    Just stumbled across this, as I've been recently annoyed by my steering column rattle. I tried to think of something better to use than a zip tie....but I couldn't come up with anything! Simple, cheap, should be fairly durable. I'd estimate that it eliminated about 75% of the rattle in my truck; it definitely dampened it anyway.
    Thanks for the tip!
  7. Feb 5, 2013 at 8:01 PM
    #87
    tmreyes1
    T-Rey
    TX
    2017 TRD
    I took me to another dealership and the six it no problem. No more noise
  8. May 12, 2013 at 9:00 PM
    #88
    bighappyfish
    bighappyfish Active Member
    Austin Texas
    2009 Dbl Cab Pre Longbed
    does anyone know if this works for a 2wd prerunner sport?
  9. Jun 21, 2013 at 10:30 AM
    #89
    oh crap its him
    oh crap its him Well-Known Member
    Shannon
    OH->SLC,UT->SA,TX
    09 TRD OR
    Lift, Wheels, Lights
    It should. Give it a shot, I don't see how it could hurt anything. Does anyone know if there is a replacement bushing available that could replace the crappy one that is currently in there? The bushing that is currently used just pops right out.
  10. Jun 21, 2013 at 4:20 PM
    #90
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Does this apply to 2013's? I would assume so, but thought I'd check!
    Thanks,
    Jay
  11. Jun 21, 2013 at 5:54 PM
    #91
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Thanks for the info.
    I have had this loose steering feeling when driving on gravel roads many times. I crawled uner the truck and never could find anything loose.
    It seemed like it was in the steering wheel area.
    This is my problem, I haven't tried the fix as I'm not really bothered by it, I'm just happy to know what the issues was...
    This is a great forum.
  12. Aug 1, 2013 at 2:07 PM
    #92
    TACMANBC
    TACMANBC Member
    Coquitlam
    2013 Tacoma SR5
    OME 2" , Pro comp control arms, Rigid grill/LED , LED fog lights , Anzo headlights with HID , canopy 100XR , dominator steps, body armor rear bumper with flush SR rigid back up
    wow this is hardcore, 2013 truck dealer tell me normal characteristics, this is not over for me .... i am going to rattle Toyota on this, fixed it in 5 minutes
  13. Aug 15, 2013 at 6:24 PM
    #93
    calixto25
    calixto25 Well-Known Member
    Arizona
    TRD sport
    Hids, billet grille, headlights, fog lights, k&n intake, throttle body spacer, led taillights, led bulb conversion.
    what would happen if you i was to weld the plate to the shaft so there wouldn't be any play?
  14. Aug 15, 2013 at 10:38 PM
    #94
    Coast2Coast
    Coast2Coast Well-Known Member
    Northern Alberta
    2009 TRDOR
    Black Sand Pearl factory paint - flattened "au natural" by tree branches.
    Sometimes if I'm cornering hard on pavement and take an S-turn, when I saw the wheel from left to right, I hear and feel a pop in the steering column. I wonder if this loose bushing is the cause of that.
    I haven't had this truck long enough to take it off pavement, I have another truck for that, but I might have to check this out.
  15. Aug 16, 2013 at 10:44 AM
    #95
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    Somebody actually did that and it worked. Mine does this too but I actually couldn't get a zip tie wedged in there. It's annoying but not hurting anything.
  16. Aug 16, 2013 at 12:14 PM
    #96
    tmreyes1
    T-Rey
    TX
    2017 TRD
    I had my truck at the dealer for the third time for this complaint. The second time they replaced the intermediate shaft with an updated part. Since that was replaced it still made noise going over bumps. I took it back this last time and they said there was another updated shaft. I was not sure it would help, but might as well do it. Surprise surprise. I have not heard the noise any more and I even did some very harsh fast off road driving in Colorado.
  17. Aug 16, 2013 at 6:01 PM
    #97
    gearcruncher
    Canadain bumper technician
    Just did mine with the zip tie today .
    THIS needs to be a sticky it works great and soo easy to do !!
    I have warranty until 110,000 miles and the stealership told me to get lost . They havent covered a single issue and I have had many
  18. Aug 17, 2013 at 12:17 AM
    #98
    calixto25
    Arizona
    TRD sport
    I was able to get 2 zip ties in mine. the second one was really hard to do. I don't know why no one has made a metal plate instead of the POS rubber one that causes the issue and weld the cylinder that shakes? would that not work?
  19. Aug 17, 2013 at 7:00 AM
    #99
    gearcruncher
    Hey can anyone point me to the TSB for the updated steering shaft ?
  20. Aug 30, 2013 at 10:28 PM
    #100
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
