Steering column fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, Apr 19, 2010.
  1. Aug 31, 2013 at 9:23 AM
    #101
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Just got done with this. About ten minutes to make an aluminum shim and install. World of difference. This was kind of a trial run, gonna mill out a more professional couple of shims tomorrow and reinstall. Damn what a nice change on gravel. Thanks OP.
  2. Aug 31, 2013 at 12:16 PM
    #102
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Milled shims? More info on selling some? Might be cool instead of zip ties... lol I have lots of zip ties though..
  3. Aug 31, 2013 at 12:38 PM
    #103
    Boone
    Boone, NC
    Airbags deployed
    Probably not for sale. The cost of milling and aluminum stock would most likely outweigh the invaluable worth of zip ties and duct tape.
  4. Aug 31, 2013 at 1:14 PM
    #104
    nfs257
    DFW
    She gone
    Lol I figured. Oh to have the tools and equipment that you have.
  5. Aug 31, 2013 at 4:37 PM
    #105
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    +1
  6. Aug 31, 2013 at 4:38 PM
    #106
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Would be interested to know if there is an updated TSB for the new shaft??
  7. Nov 5, 2013 at 2:09 PM
    #107
    blysccr
    blysccr Active Member
  8. Dec 5, 2013 at 4:53 PM
    #108
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    Tsb yet? My zip tie is holding strong since 2009
  9. Jan 3, 2014 at 10:35 PM
    #109
    Passion4Outdoors
    Passion4Outdoors Active Member
    Anthony
    Colorado
    2014 Tacoma Adventure Rig
    Leer 180 Topper Baja Rack Body Armor Trail Steps All-Pro Off Road Skids Toyota Bed Mat Thule T2 916XTR Rack Salex Console Organizer Add A Leaf Husky Mud Flaps TrailSeal Tailgate Gasket WeatherGuard Floor Mats TSB Steering Shaft Rag Joint Adjustment Mod Tow Wiring Relocate Mod Tailgate Screw Mod
  10. Jan 15, 2014 at 4:37 PM
    #110
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
  11. Feb 13, 2014 at 7:13 AM
    #111
    CrossBonz
    CrossBonz Active Member
    Nova Scotia
    2025 TRD Off Road Premium
    Just called my dealer here in Canada and they are going to cover it no problem (I'm just under the warranty period luckily) The TSB covers 2005-2012.
    Update: had the truck in to get the steering shaft replaced and it is sooooooooo much better now.....no slop in the wheel at all. I am very happy!
  12. Feb 13, 2014 at 12:08 PM
    #112
    Nonfatwater7
    Nonfatwater7 Well-Known Member
    Missoula, MT
    06 DC LB 4x4 Indigo
    Map Light mod, 265/70/17 BFG AT's, 5100's front set at .85, Eibach coils, Hi-lift bed rail mount, CB radio, Sway bar removed, 886 reverse light mod, LED tail lights and blinkers, Wickedflows exhaust, $4 aux/ipod input mod
    BEST. THREAD. EVER.
    So doing this when I get home!!!
  13. Feb 13, 2014 at 8:53 PM
    #113
    Taco'09
    Taco'09 Well-Known Member
    Is there now a second revised TSB part as has been suggested in this thread?
    T-SB-0119-10 was issued May 3, 2010 and introduced the first TSB part upgrade for the steering intermediate shaft (the upper one). The shaft for this TSB is Part No. 45220-04020 and the one I put in my truck.
    So does anyone know?
  14. Mar 30, 2014 at 7:25 AM
    #114
    devkurf
    devkurf Member at Large
    midwest
  15. May 1, 2014 at 6:34 PM
    #115
    Shawster
    Shawster Member
    I had a little slop in the wheel and since I just bought new tires, I knew that wasn't the problem. I looked underneath and sure enough found a the slop in the joint. I didn't have much and in fact had to sand down the zip tie to get it started. Took it out for a test drive. Night and day!
    Thanks for the great tip. This is by far one of the best yet. :D
  16. May 2, 2014 at 8:25 PM
    #116
    Passion4Outdoors
    Anthony
    Colorado
    So, I got my 2014 back in November and immediately noticed a steering clunk on rough roads. I tried the zip tie mod in less than a month, and it took most of the play out of the shaft. I recently was able to get a second small tie in 90 degrees from the first. The shaft has no movement--not there or under the hood where I used to be able to move it and feel it clunk. I am still getting a loose feeling off road. On the road it is solid--especially after I moved the tilt/telescoping adjustment on the wheel 1/8 to 1/4" away from the extreme positions against the stops. I think what I am feeling now is feedback through the column because everything is so tight. I can't tell if it is worse than it originally felt because I don't want to take the zip ties out. I seem to remember the original movement was more of an alarming clunk. This just feels like vibration. Anybody else getting the same sensation--even after the mod?
  17. May 2, 2014 at 10:19 PM
    #117
    Taco'09
    Passion4Outdoors, try jacking your truck so the front wheels are just off the ground. With the engine off wiggle the steering wheel a bit to check for free play in the wheel. If there is some slop look at the bottom of the lower intermediate shaft where it enters the steering rack while an assistant wiggles the steering wheel. If there is back and forth movement there without moving the tie rods, there is your answer. Mine was about 50% there and 50% in the upper intermediate shaft where everyone is putting the zip ties.
    Rant: the intermediate shaft TSB has been out since 2010. Will someone please tell me why Toyota is still putting the non-TSB part in 201` `1trucks?
  18. May 3, 2014 at 6:37 AM
    #118
    TOYOTA 09
    Maine
    wow...it's been 3 1/2 years since i made this thread. glad to see it's helping so many members.....bottom line: TOYOTA SHOULD BE ASHAMED THEY HAVE NOT FIXED THIS YET...!!
  19. May 3, 2014 at 10:36 AM
    #119
    Passion4Outdoors
    Anthony
    Colorado
    I'm not sure if my shaft is the non-TSB part. Does anyone have photos comparing the two shafts? I am pretty sure that trucks past the TSB year range have the new parts--no matter what the TSB is.
    So, I didn't jack the truck up, but I did have someone move the steering wheel while I was down on the ground holding the shaft. I can feel a slight clicking there and also when I feel the tie rods, too (while there is resistance against the stationary tires moving with the engine off). I went down to the dealership and talked to the Service Manager about it. He could feel it, too, but new trucks on the lot did the same thing when we checked. I'm not sure if that slight click is the origin of the problem. I am just wondering if 2011-2014 Tacoma owners are getting a steering vibration on rough surfaces? These would be trucks newer than the May 3, 2010 TSB.
  20. May 3, 2014 at 11:38 AM
    #120
    InLuvWithMyTaco
    InLuvWithMyTaco Well-Known Member
    Milliken, CO
    2016 Inferno TRD OR
    2014 DoubleCab TRD here. Didn't have the loose steering feel until I took it in the rocks at about 1400 miles. Now it does and made me think the tie rod ends did not seat properly after I put the lift in it. Checked them and all was well. Just stumbled across this thread, checked into this joint and sure enough the slop was there. Ran a couple small tie wraps through and the fix is in. I like $0 fixes that's for sure! I agree that a small bushing, perhaps bronze or stainless, would be a more permanent fix, but this will do for now. I will give it a good test this weekend as I head back to the mountains for a little R and R.
    Thanks for this quick, easy, cheap fix to a piss-poor design!
    NorCalTacoma likes this.
