Steering column fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, Apr 19, 2010.
  1. Apr 10, 2015 at 9:28 AM
    #161
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Hmmm, interesting. Looks like I might give this a try over the weekend depending on how time consuming it is. I certainly feel as though my steering should be tighter.
    mgw24 likes this.
  2. Apr 10, 2015 at 1:03 PM
    #162
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
  3. Apr 10, 2015 at 1:18 PM
    #163
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    Sub'd
  4. Apr 11, 2015 at 3:44 AM
    #164
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    the zip tie fix worked great, but the green bushing got pulled down alittle , zip tie was tight fitting, couple days later bushing fell all the way down, making it real loose and clucking when turning wheel,, dealer replaced upper intermediate shaft with new one,, NO PLAY AT ALL NOW,, are replacement parts better than original parts,, truck was new and had all that play, now with replacement part no play,, dont understand how this can happen,, are they using older parts to build new trucks,,
  5. Apr 11, 2015 at 5:02 AM
    #165
    Canufixit
    New England
    I believe there is a TSB out to fix this issue - They replace the intermediate shaft with an upgraded model. Also - per the info I linked to a couple posts ago from this thread - I believe the installation adjustment may play a role in the final correction. I had mine done (2012) in approx. 2013 and it helped much 99% but I'm always thinking to slide that shaft as instructed ion this thread to get it to 100%
  6. Apr 11, 2015 at 5:16 AM
    #166
    bludweiaer
    pa
    i know there is a tsb out,, my point is, why does the new shaft have almost zero play, and the old one had alot of play.. truck is a 2015, with a few thousand miles on it.. hummm
  7. Apr 11, 2015 at 8:20 AM
    #167
    Canufixit
    New England
    What I was getting at - Although they did some kind of mod to the shaft - the actual use on new production I do not know. Also the factory / tech may not have adjusted it to the optimal setting.
  8. May 8, 2015 at 10:53 PM
    #168
    SnowB0und
    SnowB0und Well-Known Member
    4cyl 4x4
    Stig likes this.
  9. May 23, 2015 at 9:57 PM
    #169
    APG
    APG Member
    2015 Tacoma AC
    The zip tie totally tightened up the steering on my 2015.
    Great thread.
    Thanks OP.
  10. Aug 6, 2015 at 9:34 AM
    #170
    oly kenji
    oly kenji Well-Known Member
    Seattle, WA
    2014 DCSB OME, Soon to be 35's Group Buy Builder
  11. Aug 6, 2015 at 8:21 PM
    #171
    chevybass
    chevybass Well-Known Member
    NC
    2009 Tacoma TRD Sport - Pyrite Mica
    Thanks so much for sharing your AWESOME idea!!! :bowdown:
    I recently purchased my "new to me" 09 Taco and could not understand what was wrong with the steering.....I searched google and discovered this thread and fixed my steering using the zip tie method tonight....so easy to do!!
    Thanks again!!
  12. Sep 28, 2015 at 4:41 PM
    #172
    sdh1019
    sdh1019 New Member
    Just tried this in my 2013 Taco. Will try out this weekend at the deer camp. Thanks to the OP for this idea!!
  13. Oct 23, 2015 at 9:33 PM
    #173
    Vanhuette
    Vanhuette Well-Known Member
    Winnipeg, Manitoba
    2006 double cab TRD sport
    I did this a few month ago and it definitely does help with tightening up the steering, but it seemed to tighten it too much on mine. All the minor road vibrations were coming straight into the steering wheel so i finally took it out two days ago and the drive is way better. Still get the occasional clunk and loose feeling on big bumps but ill take the smooth ride on normal roads
  14. Nov 2, 2015 at 5:33 PM
    #174
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
  15. Dec 11, 2015 at 6:42 PM
    #175
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    I noticed this clunking today driving off road over rocks. As usual, it's nice to come to TW and find an explanation, complete with photos and an option for a cheap fix! :thumbsup:
  16. Dec 17, 2015 at 12:56 AM
    #176
    LarrysWorld
    LarrysWorld 05 Taquito
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    2in front lift HIDs 15" Steelies
    Any pictures on this Zip-Tie fix?
  17. Dec 17, 2015 at 3:10 AM
    #177
    bludweiaer
    pa
    try reading this thread from the beginning and you will find the answer you seek,, or google , tacoma zip tie fix.. lazy people.. search..
  18. Dec 27, 2015 at 6:39 PM
    #178
    BKilburn
    BKilburn Member
    Cape Coral, FL
    2015 SR5 4x4
    Lifted,
    I cannot believe that all my steering issues are fixed with a zip tie!! WTF Toyota?? Kudos to the OP! You just eliminated the urge to trade my 2015 Tacoma in for a RAM. Thank you:cheers:
    Arailt likes this.
  19. Feb 8, 2016 at 8:58 AM
    #179
    05tacomabro
    05tacomabro will work for truck parts...
    Alex
    Tucson
    05 dcsb trd OR, 06 xrunner, 73 fj 40
    Icon ex. Travel co's, spc uca's, bamf lca skids, 1" body, all pro heavy duty sliders, expo springs, BAMF shackle hangers, 14" bilstein 7100, rear frame box, custom rear frame crossmember, ifs skid, transmission skid, t-case skid(modified by @jeepandrew for exhaust reroute and more beef), custom k&n intake, flowmaster, diff breather mod, stereo with nav/speakers/subs, coverking tactical ballistic seat covers, Baja utility rack, lots of bed liner, anytime fog mod and steel braided brake lines, energy suspension rad support bushings, abs kill switch, cali raised ditch lights, fsr rtt. Lots of plans, little money....
    Thread revival, just did this fix. All I could fit was one black zip tie in there but what a difference! I wish I would have seen this 7 years ago. My biggest Bitch about this truck from day one was the loose feeling in the steering. The roads around me and in Tucson in general are some of the worst roads I've ever been on and from day one my taco's steering wheel would shake like crazy. This five minute fix just cured 75% or more of the problem. Thank you OP! I highly recommend this quick fix and Damn you Toyota for making me feel like this was normal.
    dborrer and badmotorfinger like this.
  20. Feb 8, 2016 at 5:08 PM
    #180
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    @Passion4Outdoors any update on your mod? Has anyone else done his mod?
