Steering loose after aftermarket wheels??
Discussion in '3rd Gen. Tacomas (2016+)' started by SmokeyTacoAZ, Dec 30, 2019.
  1. Feb 11, 2020 at 7:17 PM
    #41
    honestabe25
    honestabe25 Member
    2010 prerunner tacoma
    Tires rims. Flow master exh K&n cold air intake
    This looks like it will work.
  2. Feb 11, 2020 at 7:19 PM
    #42
    Joe23
    Joe23 Canuckistikian
    Joe
    The Great White North
    2017 TRD Off-road DCSB
    Check build thread
    This
    It's pretty likely it's just your offset
  3. Feb 11, 2020 at 8:02 PM
    #43
    Gp_moto
    Gp_moto Well-Known Member
    3" lift, 33" wheels
    Maybe the wheels or rims are lighter and it just gives it a different feel. I have went from 17" e rated to 16" c rated tire and the steering just feels lighter. I'm no pro but just guessing.
  4. Feb 11, 2020 at 8:08 PM
    #44
    Gp_moto
    3" lift, 33" wheels
    The scs f5 16" weights 18pounds 13oz. I think the stock weights over 20pounds +. That might be why the steering feels lighter.
  5. Feb 14, 2020 at 6:09 PM
    #45
    SmokeyTacoAZ
    SmokeyTacoAZ [OP] Well-Known Member
    2018 DCSB TRD 4x4 OR
    This thread might win a most boring award, but in the event it helps anyone else...
    I definitely notice that as the days have gotten warmer I feel the issue more frequently on the highway. When my tires hit about 41 psi or higher after work and warmed up at highway speeds it gets bad. With the 35 degree temperature swings were having from morning to afternoon 36-37 psi cold in the morning turns to 40 later in the day. Thinking about going down to 35 psi cold or even lower then checking the chalk test. I know 37 is what the load rating says to run but the steering is kind of crap once it warms up.
    This probably had more to do with scrub radius than anything else but I'm just trying to make it more tolerable.
  6. Feb 14, 2020 at 8:18 PM
    #46
    splitbolt
    splitbolt Well-Known Member
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    And that just based off a recommend pressure. Experiment.
    10% heat rule...
    As long as you don't excede 4 psi when going from a cold to warmed up tire, you should be gtg.
    Say you start off in the morning at 35 psi. After about 10 minutes at highway speed, it shouldn't exceed 39 psi.
    SmokeyTacoAZ [OP] likes this.
  7. Feb 15, 2020 at 6:27 AM
    #47
    SmokeyTacoAZ
    Thanks for the tips. I'll keep the 4 psi in mind. Definitely experimenting.
