Steering Rack Bushings Worn Out?
Discussion in '1st Gen. Tacomas (1995-2004)' started by garrettnb, Dec 17, 2011.
  1. Dec 17, 2011 at 5:11 PM
    garrettnb
    garrettnb [OP] Canadian Ambassador
    Garrett
    Vancouver
    00 TRD w/33s on a 4" lift
    So today I went out for a little light wheeling and while doing a 3 point turn I lost all power steering. A little inspection after the fact revealed that the play in the steering rack was enough that it crunched the lines on the drivers side into whatever is infront of it. This also caused the hose to get jammed into the U-Joint and tear that to shreds as well. So obviously these need replacing, but is it also time to replace the bushings on the steering rack? I don't want to be replacing em without fixing the route cause.
    Additionally, how do I even get the lines off the rack? The angle is ridiculous!
    --gb
  2. Dec 17, 2011 at 8:26 PM
    MTgirl
    Weesa
    Bob's secret mod lair
  3. Dec 18, 2011 at 2:33 AM
    garrettnb
    Garrett
    Vancouver
    Thanks, this will come in handy for when I make the swap. But this doesn't really answer my questions.
  4. Dec 18, 2011 at 4:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Worn rack bushings shouldn't cause all that damage. If a rack bushing is GONE completely, then yeah.....it'll give you enough play - HOWEVER - you should've been able to notice this prior to you going offroad.
    Sounds like you have something else wrong......
    Change the bushings so it'll help you troubleshoot the root of the problem.
    (Thanks MT!)
    If you visit this site, you'll see Toyota Factory Service manuals.
    Scroll down to get what you need.
  5. Dec 18, 2011 at 7:06 AM
    MTgirl
    Weesa
    Oh well...I tried. Maybe if you posted some pics of the damages we could get a better idea of what you're dealing with?
    :D I've referred back to your site for a couple of things myself and I've found the writeups to be handy.
  6. Dec 18, 2011 at 3:56 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    So you crunched the hardlines?
    Really I think a picture would be very helpful to help out. I went out and looked at my truck and I don't see anything that could possibly crush any of my hard lines.
    Replace the bushings reguardless anyways. Wheelers has them for $20.
    As for removing the lines, you'll need a SST if you want to remove the lines with the rack still attached to the truck. Actually you'll just need it for the pressure line. The return line has a hose clamp that keeps the hose onto the fitting that goes into the rack.
  7. Dec 18, 2011 at 11:16 PM
    garrettnb
    Garrett
    Vancouver
    Thanks for the input guys, gonna start with changing the bushing and see where that leaves me. Will take some photos in the morning when I check it out.
    Janster: I'm pretty certain that the bushings are what caused the problem. They steering rack has enough play that the rack not only slides but also rotates front to back.
    jberry813: Yes I crunched the hardlines and one of the soft links got pushed into the U joint and got pretty shredded. What's an SST?
  8. Dec 19, 2011 at 8:06 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    SST = Special Service Tool aka fancy tool for the task at hand.
  9. Dec 19, 2011 at 2:29 PM
    garrettnb
    Garrett
    Vancouver
    Currently under my truck. Are the hard lines attached to the rack on the drivers side meant to have any play in them?
  10. Dec 19, 2011 at 2:47 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    IIRC there should be a bracket that bolts to the frame to keep the hard lines from moving (and no, there should be no play).
    I don't have my truck right now. At work without my truck or I'd go look to make sure.
  11. Dec 19, 2011 at 3:09 PM
    pigger
    pigger Well-Known Member
    Greg
    Rio Rathole
    04 tacoma 4x4 reg cab
    Detroit True-Track rear limited slip, steering rack bushings, shell, SAF decals, Wheelers 5-leaf & Bilstein 5100's, some nice LED lights from Chris, big-ass bumpers, older-than-dirt owner
    That was the first thing I had to replace on my '04. I was experiencing front end wander & steering slop; replaced them with aftermarket bushings: fixed. I do get a little more rattle now from the steering column, though. I think mine failed due to the pounding I give my truck on forest roads & off-road.
  12. Dec 19, 2011 at 5:57 PM
    garrettnb
    Garrett
    Vancouver
    This day just went ridiculous... It took me way longer to get the steering rack clear to replace the bushings. The spot to remove the bolts from the hardlines is just too cramped to gegt any leverage on, and when I was using a vice clamp I almost rounded the bolt. Figured I'd put in the new bushings and take it to my mechanic, go to the parts store and they don't carry the bushings. So I can't get aftermarket bushings here, gonna have to pick em up from Toyota and then go to my mechanic. Free tow from my BCAA.
    Thanks for all the help guys.
  13. Dec 19, 2011 at 6:07 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Bushing kit:
    Toyota doesn't carry the bushings, only the whole rack.
  14. Dec 19, 2011 at 8:19 PM
    garrettnb
    Garrett
    Vancouver
    OF COURSE. It makes perfect sense that Toyota wouldn't sell a part that wears out. :mad: I'll pickup the kit from wheelers if I can't find it locally. I really want to use my truck :(
  15. Dec 20, 2011 at 12:35 AM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Total chaos makes the bushing kit too. Only $25
  16. Dec 20, 2011 at 1:02 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    IIRC, advanced auto sells energy suspension stuff...should be able to order the bushings for you and have them in a day or two.
  17. Dec 20, 2011 at 6:52 AM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
  18. Dec 22, 2011 at 2:28 PM
    garrettnb
    Garrett
    Vancouver
    Figured I'd drop an update here:
    So I managed to get the bushings and replace them. WHAT A DIFFERENCE, even without power steering in the 2 minutes I drove it I was blown away. I had only owned the truck for a couple weeks and this was the first time I've driven one with a lift and big tires. Figured that was just how it handled. Anyways, Based on where the broken power steering lines were I couldn't get to them. So I drove the truck to my mechanic a few miles away. He tells me that nobody sells just the part that's broken and Toyota sells the whole set of lines for $670. FUCKING OUTRAGED, he says he is going to call a bunch of wreckers before he lets Toyota bend me over. He does end up finding the part for $50. But it turns out what I have that's broken is just a little extension from the steering rack to the power steering line that apparently came from the lift kit. And is therefore not a standard part, so now he's trying to track that down and could potentially have to get it made. Because does Procomp sell it? Not a chance.
    Truck owned for 14 days, out of service for 6 days and counting...
  19. Dec 22, 2011 at 2:35 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I've highlighted the problem.
  20. Dec 22, 2011 at 2:37 PM
    09taco4x4
    09taco4x4 Well-Known Member
    Louisiana
    09 DCLB TRD Sport 4x4
    Valant cold air intake kit Borla catback exhaust 6" Pro Comp Stage 1 Walker Evans 2.5's w/ TSB spring and add-a-leaf Light racing upper a-arms 285/70/R17 Dynapro ATM tires 17x9 XD wheels
    Go to a place that makes hydraulic lines and get them to make one for you.
    Much cheaper and easier than trying to hunt down those parts.
    Aftermarket hydraulic lines for tractors and big rigs are far superior to what comes on a Toyota
