Steering rack needs to be replaced after 50K miles - 2019 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FranklinsDad, Dec 19, 2023.
  1. Apr 27, 2025 at 6:41 PM
    mjillson
    mjillson Well-Known Member
    im going to give this a go! I was quotes 2700 to replace. Only have 59k miles on it.
  2. Apr 28, 2025 at 4:26 AM
    likxrokx
    likxrokx Member
    Yup. 71k mis. Have to replace 1 side. $1600.00 plus alignment.
    No off-road, no hard turns, no aggressive driving.
    This comes after engine blew up. Just installed a used one with 61k mis on it.
    Shortly after, TPMS went out, rack and pinion went out, AC went out. I will never own another Toyota product.
    $16,000.00 and counting..
    Good luck.
    auskip07 and CrashZone like this.
  3. Apr 28, 2025 at 7:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Killer!
    That is great to hear.
    skidooboy and TartanEagle like this.
  4. Apr 28, 2025 at 1:24 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    This is all thanks you your sharing with the group. I have the Mazda fluid, and in a few days, I will be swapping the stock Toyota steering fluid in my 2019 Sport (50k), and changing the oil, filter, adding the summer wheels, and doing the ECGS bushing update. The forum and some of it's brothers are awesome, you being one of them. Ski
    The Mink and tonered[QUOTED] like this.
  5. Apr 28, 2025 at 2:07 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome! :cheers:
    Happy to help!
    The Mink likes this.
  6. Apr 28, 2025 at 2:40 PM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Do you just remove and replace the fluid in the PS reservoir? Or is it more involved? Mine has been a little below the low mark, so I ordered the Mazda fluid.
    I also ordered the new serpentine belt from the TSB info you posted to hopefully get rid of an intermittent belt noise. I just hit 40k miles, which seems to be when the old belt part number starts to have issues.
    (https://www.tacomaworld.com/threads/new-accessory-belt-tsb.697144/)
    baboltin and tonered[QUOTED] like this.
  7. Apr 28, 2025 at 3:04 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I used a turkey baster to suck up everything that was in the reservoir, then I refilled it, ran it through a few turns to mix up the fluid, then sucked up the fluid again with turkey baster. I kept doing this until the fluid was the same color as what was coming out of the bottle new.
  8. Apr 28, 2025 at 3:08 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    When I first found the mildly moist rack boots, my level was just down a little bit. A fuzz below the low mark when cold. Topping up from there solved the issue. It was not much fluid at all, which was part of my surprise.
    I just had to add a bit more at 110k, but the boots are still dry. I have not cycled out the fluid, and thankfully that is not called out in the manual. We have had a few cars that did require it.
    I replaced the belt not too long ago, but cannot find the part number that I used. I forgot about that thread. Haha! I'm after that VIN range which seems strange considering you have a 2019.
    dilbert[QUOTED] likes this.
  9. Apr 28, 2025 at 3:18 PM
    dilbert
    dilbert AI Member
    PNW
    I'm 3TMDZ5BN#KM060444, which I believe is before the production cut in if I'm reading it correctly.
    tonered[QUOTED] likes this.
  10. Apr 28, 2025 at 3:28 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I believe you are, and I was wrong. I am before at HX.
    Long week already. :facepalm:
  11. May 4, 2025 at 4:45 PM
    dilbert
    dilbert AI Member
    PNW
    My rack boots are dry, but I was just below the cold low. I sucked out the contents of the reservoir and filled it up to halfway between the cold low and cold high. I'll check it again next oil change. Maybe it's always been a little low?
  12. May 4, 2025 at 5:20 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Always good to have dry boots. Hahaha!
    Hopefully you are set and thr level is stable.
  13. May 4, 2025 at 6:08 PM
    mjillson
    After a few weeks I didn’t see mine drop any. I did end trading my truck in for a gen 4 a few days ago though. The trade in value on the gen three is through the roof.
  14. May 5, 2025 at 1:42 PM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    I noticed my PS fluid was low early on and topped it off by 15k-ish miles. I regularly check the fluid and now at 43k have not lost anything. Crawling under the truck the last few times I noticed the bottom half of the boots have darkened. I'm guessing this happened a long time ago and they will just stay that way. Since I haven't lost any fluid in 30k miles I don't think anything is getting worse.
  15. May 5, 2025 at 2:01 PM
    #35
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, but my boots dried out.
  16. May 5, 2025 at 2:13 PM
    #36
    AZPhys13
    Well, shoot. I guess I'll keep up on my regular checks
  17. May 5, 2025 at 2:19 PM
    #37
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    At least it is not a critical worry.
    AZPhys13[QUOTED] likes this.
  18. May 5, 2025 at 4:34 PM
    #38
    Mater96
    Mater96 Well-Known Member
    AZ
    2019 Tacoma Offroad 4x4
    Amber DRL retrofit Fox 2.0 coilovers and reservoir shocks
    Man my 2019 with 53K has the same thing, seaping fluid from the drivers side boot. My dads 2018 also. His has 98k on it tho but still weird yet common problem on these 3rd gens it seems.
  19. May 8, 2025 at 12:13 PM
    #39
    Tanmann
    Tanmann Well-Known Member
    Richmond, VA
    2017 OR Access Cab
    Cardboard spoiler and skateboard wheelz
    I had mine go out on my 2017 within a few months of buying it new off the lot. Luckily it was under warranty, so no out of pocket expense.
    I have almost 160k miles on it now and no problems since then.
    I did have to replace it on my old ‘99 when it was around the 200k mark.
    Canadian Caber likes this.
  20. May 23, 2025 at 7:56 PM
    #40
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I trade that truck you got a lemon.
    doublethebass likes this.
