Steering stabilizer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ABNSCOUT1, Jun 24, 2012.
  1. Jun 24, 2012 at 2:48 AM
    ABNSCOUT1
    ABNSCOUT1 [OP] Member
    ROBERT
    HOPE MILLS NC
    05 Prerunner
    3in Pro Comp kit Nitto Terra Grapplers TRD Seat covers TRD Mats
    I have Nito grapplers on my Taco and I feel like the truck is all over the road. Is there a steering stabilizer for the 05 are is there another fix.
  2. Jun 24, 2012 at 4:51 AM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    Have you gotten an alignment done?
  3. Jun 24, 2012 at 4:55 AM
    Noslow100
    Noslow100 Well-Known Member
    Josh
    VA
    08 SR5 4x4
    Toytec 3 Inch lift kit with Bilstein 5100's, and more
    Alignment needs to be checked. Also look for the tire pressure and make sure it's not out of whack. Do you have a lift on it?
  4. Jun 24, 2012 at 4:57 AM
    ABNSCOUT1
    ROBERT
    HOPE MILLS NC
    05 Prerunner
    Yes an alignment has been done it just feels like the tires grip everything and pull the truck around.
  5. Jun 24, 2012 at 5:03 AM
    oothefuxdis
    oothefuxdis Well-Known Member
    nope rack and pinion steering don't use em ,must be something loose how long ago did ya get an alignment ? Was it like that before the Nitos?
  6. Jun 24, 2012 at 5:03 AM
    ABNSCOUT1
    ROBERT
    HOPE MILLS NC
    05 Prerunner
    Maybe I'm just not use to these tires
  7. Jun 24, 2012 at 5:29 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    What PSI are you running and what tire size?
  8. Jun 24, 2012 at 6:05 AM
    ABNSCOUT1
    ROBERT
    HOPE MILLS NC
    05 Prerunner
    285/60R18 35LBS
  9. Jun 24, 2012 at 6:08 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Post up your alignment numbers.
  10. Jun 24, 2012 at 6:23 AM
    ABNSCOUT1
    ROBERT
    HOPE MILLS NC
    05 Prerunner
    I can't Post up my alignment numbers I'm in Afghanistan. This is the first truck I've put these tires on. Maybe it is just a different feel then I’m use to.
  11. Jun 24, 2012 at 6:58 AM
    Davtopgun
    David
    Central Alabama
    I had the same tires, and mine didn't do what you're explaining. My first guess would be that your alignment wasn't set to the correct numbers. I would take the truck back to the shop and make them do it until it is right.
    And Thankyou for your service! Hope you're all doing well out there!
  12. Jun 24, 2012 at 7:37 AM
    ABNSCOUT1
    ROBERT
    HOPE MILLS NC
    05 Prerunner
    Thank you I'll give it a try. By the way throw back a cold one for me.
  13. Jun 24, 2012 at 7:44 AM
    Davtopgun
    David
    Central Alabama
    Good luck man, and you got it sir!
  14. Jun 24, 2012 at 8:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like your lifted, and using OEM UCA's. Wandering is one of the side effects of lifting, without adding more caster. Steering stabalizers help for steering kick back. not tracking. Also, they dont work well if at all, on Rack & Pinion systems, like the Tacoma has.
  15. Jun 24, 2012 at 8:19 AM
    ABNSCOUT1
    ROBERT
    HOPE MILLS NC
    05 Prerunner
    Thanks I'll get it checked out.
