Steering wheel removal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by t.i., Jun 26, 2017.
  1. Jun 26, 2017 at 7:37 PM
    t.i.
    t.i. [OP] Active Member
    Does anyone know how to remove the steering wheel? May be removal guide?
    Thanks
  2. Jun 26, 2017 at 7:39 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  3. Jun 26, 2017 at 7:40 PM
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    this is not helpful but I gotta ask. Why do you need to remove the steering wheel?
  4. Jun 26, 2017 at 7:42 PM
    Brokinarrow
    Brokinarrow Well-Known Member
    Brian
    Garner, NC
    2017 Tacoma TRD Offroad
    Thangs and stuff
    i was wondering the same thing
  5. Jun 26, 2017 at 7:56 PM
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    Aftermarket steering wheel and/or some sort of OEM wheel he found that fits/works?
  6. Jun 26, 2017 at 8:00 PM
    su.b.rat
    su.b.rat broken truck
    time for an upgrade!
    BlakeM and blackrifle76 like this.
  7. Jun 26, 2017 at 8:02 PM
    daohaus
    daohaus Well-Known Member
    Duan
    33.960892 -117.575824
    18 TRD Off Road Premium 4runner
    Rotiform SIX OR Toyo Open Country RT
    I'm hoping he got a hold of a 3 spoke Camry wheel and swapping it out
  8. Jun 26, 2017 at 8:03 PM
    Bishop84
    Bishop84 Well-Known Member
    You have a spiral cable and steering angle sensor, I would suggest not removing it.
  9. Jun 26, 2017 at 9:03 PM
    t.i.
    I am replacing the SR headlight stalk with Sr5 stalk that has a fog light switch.
  10. Jun 26, 2017 at 9:04 PM
    c4lvinnn
    Meh, I was on the right track haha
  11. Jun 26, 2017 at 9:05 PM
    t.i.
    Close...
    c4lvinnn[QUOTED] likes this.
  12. Jun 26, 2017 at 9:13 PM
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
    would it not just be a lot simpler to add the switch to the dash somewhere?
    I.am.broccoli likes this.
  13. Jun 26, 2017 at 9:15 PM
    t.i.
    I don't know... However
    1) I want to keep the factory look
    2) I would have to run wire from the switch the lights
    c4lvinnn likes this.
  14. Jun 26, 2017 at 9:15 PM
    c4lvinnn
    Removing a steering wheel is just as complicated as taking apart dash pieces and wiring a switch.
    t.i.[OP] likes this.
  15. Jun 26, 2017 at 9:17 PM
    t.i.
    That's what I am trying to determine how complicated this process would be to replace the stalk. If its too complicated, I might just bite the bullet and pay stealership to do the swap
  16. Jun 26, 2017 at 9:21 PM
    c4lvinnn
    If it's anything like other cars that I've done, it would be similar if not the same as the 2nd gen posted up there.
    Basic steps are:
    Disconnect battery and let residual power drain
    Remove air bag (screws, clips etc) to detach from wheel and its harness
    Disconnect horn and other stalks like cruise etc
    30mm ish socket to remove center nut
    Remove wheel
    BE CAREFUL of the clockspring (the wound metal flat wiring) that sets steering angle sensor and trac control. This cannot be turned or unwound. Keep it at same position as it was before. Should be located between wheel and steering column.
    Install new stalk
    Repeat in reverse
    t.i.[QUOTED][OP] likes this.
  17. Jun 26, 2017 at 9:23 PM
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
    ok I get it. Have you checked in the SR thread? I know when I was considering one I saw a lot of info on mods in there.
  18. Jun 26, 2017 at 9:26 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Are you sure the steering wheel needs to be removed to replace the headlight switch? Just take off the clamshell and see if you can access the screws/clips
  19. Jun 26, 2017 at 9:27 PM
    t.i.
    Ok thanks
  20. Jun 26, 2017 at 9:28 PM
    t.i.
    I did but not much information available for the uninitiated
