Steering wheel Shake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mxmaniac, Jun 25, 2010.
  1. Mar 3, 2012 at 4:57 PM
    #301
    tacobert
    tacobert Active Member
    Vancouver, BC
    06 DCSB TRD Offroad
    Mine vibed at 55-65 mph after I got my countersteers put on with spline drive lug nuts. Took it back to the tire shop an thu rebalanced them and now no more vibes.
  2. Mar 6, 2012 at 3:34 PM
    #302
    parkp81
    parkp81 Well-Known Member
    Fil
    Southern California
    I purchased lifetime roadforce balancing and rotation at Americas Tire Center.
    1st time - shop said they got a new cone adapter that eliminates the need for the Haweka adapter, but that did not work. I still got the shakes.
    2nd time - went back and said to rebalance using the Haweka adapter/fingers (surprised the tech as the balance was way off), that helped somewhat, but still shaking.
    3rd time - I said what the heck, lets try another Americas Tire Center and this time I told them to use the sticky weights instead of the clip-ons and now no more shakes!
    My wheels are a little scared up from the clip on weights, but from now on, no more using those to prevent from getting more damage.
  3. Mar 8, 2012 at 11:37 PM
    #303
    jv.garcia
    jv.garcia Active Member
    JV
    CA
    09 TRD Sport 4x4
    Magna Flow Exhaust, 3"/2" Level ready lift.
    My truck shakes dangerously when I press on the breaks, had my rotors resurfaced and new breaks installed a few months ago. Any ideas of what it could be? :confused: :help:
  4. Mar 10, 2012 at 7:01 PM
    #304
    parkp81
    Fil
    Southern California
    Damn shake has returned, don't understand how it is fine for some time then it goes back out of balance.:mad:
  5. Mar 10, 2012 at 8:23 PM
    #305
    nucktaco
    nucktaco Well-Known Member
    Scott
    south surrey, bc
    08 Double Cab TRD Sport
    satoshi mod, sliders, tinted tails/3rd brake, 3" lift,
    i had the same problem. it was unevenly worn tires. might be your problem too?
  6. Mar 10, 2012 at 9:36 PM
    #306
    watchdog
    watchdog Well-Known Member
    jim
    nanuet n.y.
    09 tacoma
    Rims and tires , exhaust , stereo , Bhlm ,Changed carpet to black from grey. toytec ultimate lift kit. Allpro front bumper and light bar. In process of blacking out interior. Otrattw switches, black vinyl armrest mod, clazzio leather seat covers with heaters, flowmaster dual exhaust, hornblasters train horns,
    You may want to play around with tire pressure also. My 09 had a shake at about 45 mph and up. Adjusted pressure and it went away. I'm running 20s on mine with 265/50/20 and nitto terra grapplers
  7. Mar 11, 2012 at 3:06 PM
    #307
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Get new rotor's
  8. Mar 11, 2012 at 5:30 PM
    #308
    rjreynolds
    rjreynolds Active Member
    2wd 2.7l
    I have an 08, 2wd, 4 cyl. I bought mine used from a dealer with 32k miles on it. When I test drove it before purchase I did not notice any steering wheel shake. However, within a few days I noticed that there was a slight shake of the steering wheel. I called my dealer and they said that the tires had been balanced and that it could not be them. Never really pursued it beyond that. Just lived with the problem. As tires wore further, the problem got worse, at 35 mph, and 70 mph. Finally when time came to replace tires, I purchased a set of Yokohamas. Steering wheel shake gone and 22k miles later has not returned. I rotate and balance every 5k miles.
  9. Mar 12, 2012 at 11:45 AM
    #309
    parkp81
    Fil
    Southern California
    Update. Went to my 3rd different Americas Tire center and I had thought they all had roadforce balancers, but this one did not. The guys were very helpful and said they would try to balance them using the regular Hunter balancer. The Haweka adapter they had which was 6lug 5.5 for some reason the fingers would slide through the holes on the rim, and he said that should not happen. I'm not sure myself, as the other 2 previous Americas Tires, had used the Haweka adapter (maybe they used it incorrectly)? But he did use some other adapter that had wheel studs and used my original lugnuts to screw that adapter to the wheel then mount it onto the balancer. He said they were off, and did the best that he could.
    Hop on the freeway and dammit the wheel still shakes! So I head down to the Americas Tire that I first went to and told them my situation and this is my 5th time balancing! The manager said he was sorry and would have them look at it again. Waiting then he tells me that the 1 roadforce balancer they have the wheel that comes down took a shit, and they have a tech coming out to fix it today.
    I will be going back tomorrow. I am so sick of this damn problem, on a truck that only has 4k miles! If its not fixed tomorrow, I'm going to have to see how I can get those tires replaced.
  10. Mar 13, 2012 at 9:44 PM
    #310
    LadTacoma
    LadTacoma Well-Known Member
    Ray
    NJ
    Prime Mover
    my steering wheel shook before I lowered the air pressure to 29 psi (factory setting) for my truck. It stopped shaking and now drives smoothly.
    hope you find something that works for ya
  11. Mar 14, 2012 at 3:02 PM
    #311
    Deathbeard
    Deathbeard Well-Known Member
    Yorba Linda, CA
    Prerunner Regular cab
    Camburg Spindles, Camburg 1.25" UCA, All pro expedition rear 3" leaf, 5100 all around, 17x9 raceleline renegade 6, 33's
    people overtightening the lug nuts will make rotors warp
  12. Mar 14, 2012 at 3:04 PM
    #312
    Deathbeard
    Yorba Linda, CA
    Lugcentric wheels suck, 99% of all tire places I went to had no idea how to do it, also the roadforce balancer will not work on most 33" mudterrains and certainly not on 35's..Make your life easier and by hubcentric wheels, i.e MB wheels from discount tire
  13. Mar 18, 2012 at 11:05 AM
    #313
    jv.garcia
    JV
    CA
    09 TRD Sport 4x4
    just got new tires, I think my rotors are warped
  14. Mar 18, 2012 at 11:12 AM
    #314
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    i had a bad steering wheel shake on my old Xterra and rebalancing didnt work for them etc... then one day i got new tires and BAM no more shake. i had some cooper discoverer tires on there but replaced them with non-aggressive tires and it stopped. now i know theres always some vibes when you put on aggressive tires but that vibe just continually got worse. so yea good luck man i doubt this helped ya much but figured id throw it out there
  15. Mar 18, 2012 at 1:17 PM
    #315
    parkp81
    Fil
    Southern California
    Update: I went back to Americas Tires this past week and had them use the proper cone instead of the Haweka adapter, and it got somewhat better, but I still had the shake. Today I decided that I am going to have Toyota look into this, and what do you know they fixed it. Wheels were out of balance. So far so good, I hope it stays this way.
  16. Mar 18, 2012 at 1:29 PM
    #316
    Hunter423
    Hunter423 Hunter423
    hunter
    TN
    2008 Tacoma TRD off road
    brush guard, piaa foggs, tinted tail light, tinted windows, rain guards, pure white with blue tinted bulbd all over, white bulbs for licencess plate lighting, blacked out head lights
  17. Mar 18, 2012 at 6:42 PM
    #317
    mxdude91
    mxdude91 Member
    Richmond,VA
    2008 Base SR5 4.0L 4x4
    Debadged,Shorten up the front mudflaps 4in,Plastidiped the front emblem,Weathertech Mats/Seatcovers,Tinted front windows
    Could it be a siezed slide pin?
  18. Mar 18, 2012 at 6:47 PM
    #318
    mxdude91
    mxdude91 Member
    Richmond,VA
    My steering wheel started shaking at highway speeds,i noticed my right front tire is feathering on the outer edge,ima try a roadforce balance and using the toyota balancer attachment,then get a fresh alignment that should do the trick:)
  19. Mar 20, 2012 at 6:37 AM
    #319
    resq330
    resq330 El' Capi-Tan
    Josh
    VA
    13 MGM DCSB TRD-Sport
    K&N Drop-In, Dick Cepek 'Torque' Wheels, Wet Okole Seat Covers, LED Interior
    I tried this yesterday evening...No much difference this morning except my TPM light is on now... :facepalm:
    Pre toma likes this.
  20. Mar 21, 2012 at 6:52 PM
    #320
    parkp81
    Fil
    Southern California
    After a few days my steering shake has returned. I have now sent a message off to the service manager at the Toyota dealership in regards to this, issue. I'm getting tired of going to the dealership. Thinking of just selling these damn tires or both wheels/tires and getting aftermarket tires and wheels in hopes of ending this issue.
