Steering wheel Shake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mxmaniac, Jun 25, 2010.
  1. Jun 25, 2010 at 2:36 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    if you are talking to me... yes they have.
  2. Jun 26, 2010 at 1:24 AM
    mxmaniac
    mxmaniac [OP] Member
    Tyler
    chino hills
    05 PreRunner
    Donahoe coil overs (set at 1") ,Camberg spindles, Camberg UCA, OME Dakar leaf pack, Bilstein 5100.
    So does anyone know a good shop to take my truck to so someone can look at?
  3. Jun 27, 2010 at 2:58 AM
    rudy1201
    rudy1201 Member
    smyrna, DE
    2010 Trd sport 4/4
    Had the same problem after purchasing new tires. Had them rebalanced 4 times and still had a shake and vibration problem. I called the dealer and talked to them and found out that Toyota rims dont fit on a cone type balancer properly without the use of a tool called the heweka adapter kit. It centers the wheel using the lug holes. Without this tool the rim does not fit on the cone properly causing inaccurate balancing. Had the dealer balance the the wheels and everything was fine after that.
  4. Jun 27, 2010 at 4:33 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I've read of the heweka adapter kit probably on TW B 4. Did a search and this is the only thread that come up so maybe some one who knows how should but this in for in a sticky for the shakes.[​IMG][​IMG]
  5. Jun 28, 2010 at 3:11 AM
    Wadester19
    Wadester19 Active Member
    Taylor
    Frederick, MD
    06 TRD Sport 4x4
    I'm having the same problem and it sucks. So is the only way to fix it to force balance them or take it to the dealer? And does the dealer charge a lot more for it?
  6. Jun 28, 2010 at 5:28 AM
    rudy1201
    rudy1201 Member
    smyrna, DE
    2010 Trd sport 4/4
    If you are having the same steering wheel shake and vibration after having tires replaced on factory wheels then chances are your wheels are not balanced properly. The shop may not have used the heweka adapter on thier machine. The dealer I used after explaining that I had my wheels balanced, 3 times. roadforeced once and still had a shake told me about the adapter that needs to be used on Toyota rims to properly mount them on the balancer machine. I had the dealer balance them for $60.00 using the adapter and the problem was fixed. I guess most tire shops dont know that they have to use the adapter on toyota wheels.
  7. Jun 28, 2010 at 7:21 AM
    george3
    New Jersey
    Is the heweka adapter kit necessary for all Toyota's, or all Tacoma's, or just 4.0 Tacoma's ? They reason I ask is I've bought tires from BJ's because they give lifetime rotation free, free lifetime balance and free leak fix. I doubt they have or use heweka adapter kit but I never had a problem.
  8. Jun 28, 2010 at 8:55 AM
    rudy1201
    rudy1201 Member
    smyrna, DE
    2010 Trd sport 4/4
    I believe it should be used on all 5 and 6 lug Toyota alloy wheels.
  9. Jun 28, 2010 at 9:48 AM
    george3
    New Jersey
    Guess I just been lucky.[​IMG]
  10. Jun 29, 2010 at 5:41 PM
    rmarqu2
    rmarqu2 YES... i am a murse....
    Roger
    Baton Rouge
    09 Black 4x4
    FOX 2.5 coilovers, FOX 14" rears, AP expos, AP front plate bumper and skid, lightforce 240 blitz, warn m8000, 3/8 amsteel, BAMF sliders, cheap Chinese rock lights, ARB lockers all around
    I recently got my tired rotated at the dealer and he must have knocked off one my weights because it started shaking like crazy. My truck drove PERFECTLY beforehand. I took it to a Tire Kingdom and they convinced me to put equal in the tires. It was worse after that! I got a refund and began calling some of my buddies that I wheel with and they recommended another place. They put the sticky weights back on and it's pretty much fixed now. It's still not back to 100% but I need to take it back to them when I get time.
    sr5402010 likes this.
  11. Jun 30, 2010 at 6:34 PM
    Ronin
    Ronin iTaco
    Al
    Rockwall, Texas
    2008 Tacoma Sport 4x4
    low range leveling kit
    Note:
    Bought new tires...drove fine.
    Had the tires balanced and rotated.....shake.
    Read this post.
    Spoke to Firestone.... "Oh, we have the adapter, but it is missing pieces."
    Took it to the dealership and had them balance the tires....NO shake!
    The adapter has dowels on it that balance it properly.
    This is my understanding.
    Hope this helps.
    -Al
    PS. I have read several post about this tire rides rough and/or shakes. I have to believe not being properly balanced could be the cause of a lot of people's disappointment.
  12. Jun 30, 2010 at 6:44 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    ok here is the deal, i have plenty of experience with shitty tires and horrible balancing. so there many factors here. make sure that they arent being stupid and ONLY putting weights on the inside of the rim and not on the lips. I went to discount many times and many different locations until i found one that does it right, takes their time and lets me watch them. also they have had to a number of times take me wheel off the rim and rotate it. my tires come to find out have heavy spots on them meaning they can add and remove weights all day long and never ever get them balanced. while the wheel is on their balancing machine make sure they are using the right adaptor on the machine. when i was at one place the stupid fuck did not use the correct adaptor, they came up to me and said i need a new wheel because the rim was bent. then after i went back there and watched them run the tire again another kid working there walked up and said make sure your using the right adaptor...so there is another culprit to a bad balancing job. there are little things like this that goes into properly balancing tires correctly, hope you figure out your problem and goo luck!
    oh also as stupid as this sounds make sure there isnt any dirt/mud compiled on the inside on the rim otherwise that could also cause an vib due to being imbalanced
  13. Jul 1, 2010 at 1:42 AM
    Johnny M50
    Johnny M50 Well-Known Member
    N NJ
    09 Tacoma, V6 Sport 4x4,debadged, Super White
    K&N "warm" air intake
    Have you tried these?
    http://www.counteractbalancing.com/
    I use them in my motorcycle, and gotta say THEY WORK for me. When I need new rubber for the cage, they will go in there.
    It's nice not having wheel weights, or paying extra for the balancing act.
  14. Jul 6, 2010 at 1:42 PM
    Seener84
    Seener84 Well-Known Member
    Sean
    Denver, CO
    10 DCLB SR5 4x4
    Leer 100R
    Would a set of aftermarket wheels need the adaptor also? I just traded my stock wheels with 245 75/16 for a set of American Outlaw wheels with 265 75/16 Hankook DynaPro Atms and it shakes between 55-65. I took it to Walmart right away to make sure the guy didnt give me a bent rim, and they said it looked good and rebalanced them. I don't have much confidence in Walmart though. I will put on a set of stock wheels and tires again if this shake doesnt go away. Take them to a Toyota dealership to balance? Don't want to invest much money in this either.
  15. Jul 7, 2010 at 5:06 AM
    #35
    clankey
    clankey Well-Known Member
    St. John's, NL
    2010 Double Cab TRD Sport
    Roof Rack, Soft Tonneau, Running Boards, DDM HID's, Skid Plate, 3" lift, 275/70R17 BFG AT TA's
    I have 1/4' spacers on the front and have the same thing. If you are running spacers that is a good possibility. I have new wheels ordered with the proper offset to get rid of the spacers.
  16. Jul 7, 2010 at 7:27 AM
    #36
    Seener84
    Sean
    Denver, CO
    10 DCLB SR5 4x4
    Leer 100R
    Mine shake with no spacer, aftermarket wheels with offset. Do most places do a "Road Force Balance?" I've never heard of this.
  17. Jul 8, 2010 at 10:09 AM
    #37
    clankey
    St. John's, NL
    OK little update for you. I removed my 1/4' spacers last night and it is now smooth as silk!
  18. Jul 10, 2010 at 1:01 PM
    #38
    dugus46
    dugus46 Member
    Doug
    virginia
    05 DC SR5 prerunner 4x2 LB
    I had the same problem when the truck was new. balanced the tires to get the shake to an acceptable level.... 90,000 miles later I put new rims on with spacers... dramatically increased shake... removed rims and spacers... put stock aluminum rims on with same (new)tires.... problem solved... Am going to try again with a different rim... My offroad shop is working with me very well because they know Tacoma's are very sensitive to rim/tire balance. I have found a rim that I like (16x8 Eagle Alloy 186 series) that will clear the caliper with no spacer required.... Praying that the shake will not return, If it does I will have them road forced balanced at my toyota dealer... they usually have a road force balancer. Tacoma's are sensitive, if your tire or rim is even slightly out of round it's gonna shake. Remeber, you can sping balance and EGG; but its still an EGG. Find out which wheels appear out of round when they balance them... and replace them.
    Good luck with yours.... I know your pain... love the truck... the shake frusterates the hell out of ya... good thing though, if it's small enough it doesn't seem to wear out ball joints prematurely... I have 91,000 miles now and they still ride like new.
    I will also be replacing the shocks with Bilstein 5100's when the new rims come in to further smooth out the ride and level the truck... should be sweet.
    dpq512 likes this.
  19. Jul 12, 2010 at 6:25 PM
    #39
    tacomaowner85
    tacomaowner85 Well-Known Member
    angel
    N.M.
    07 TRD SPORT 4X4
    K&N AIR FILTER Leveling Kit( 3" in the front 1"in the back) "Super Truck" tube side steps 5% window tint in the front Limo window tint in the back
  20. Jul 14, 2010 at 6:44 PM
    #40
    7A7ER
    7A7ER FLYNN LIVES!
    AL
    '05 Radiant Red Tacoma XCab PreRunner TRD
    Removed Step Bars, Hood Visor, OEM Bed Mat, Window Tint, Fog Lights Anytime, BFG All-Terrain KO2s, Removed Mud Flaps, Add A Leaf Recall, Color-Matched Grill and Bumper& Plasti-Dipped Badges!
    I like the way you break it down into short steps...simple, concise and proves a point. I can't wait to have the dealer balance my wheels. The audacity of many garage's to knowingly balance our wheels without the proper adapter is despicable, but, unfortunately, completely believable.
    Thanks guys!
