Steering wheel Shake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mxmaniac, Jun 25, 2010.
  1. Dec 29, 2012 at 5:15 PM
    #521
    seric007
    seric007 Well-Known Member
    no argument there... my point was it didn't make a lick of difference in the driveshaft vibration and at 22 i have that "harmonic" you can feel in the wheel... or whatever it is.
    its a nice upgrade to the feel and i was quite pleased at the amount of bump-steer it helped with...
    but more importantly.... it does not fit the "older" steering wheel*.
    *without modification
    *edit
    and for reference, below is the old steering wheel (or at least, the same as mine)
  2. Dec 30, 2012 at 11:42 AM
    #522
    josh256
    josh256 Apprentice Modder
    Josh
    Tacoma TRD Sport
    TRD exhaust TRD short throw shifter T-Rex Grille Rhino Wheels PL5300 latch Muth Mirrors Pioneer HU, amps and subs Image Dynamics in the doors Dynamat (everywhere) Dynaliner (selectively) 3M DiNoc wrap de-badge/rebadge (black)
    What modification was required to fit the old wheel? Going to proceed with the steering damper install myself on my '11 as I find the steering far too loose to begin with.
    PS: I get the shake at higher speeds.. Anyone w/ shake around 60-70mph that gets a dealer to perform the TSB fix please post results!
  3. Dec 30, 2012 at 3:08 PM
    #523
    seric007
    Step 1. Re-drill the 2 pilot holes
    Step 2. Re-drill the 2 mounting holes
    Step 3. Grind down the front top of the weight so the air bag assembly will clear (when you press the horn)
    Step 4 (optional) add the weight back you ground off. I choose to add it back with lead based solder
    Tools utilized: Drill press, Various size drill bits, Bench Grinder, Various files, Vice, hammer, Tin Snips, Soldering Iron, Lead based Solder.
  4. Dec 30, 2012 at 5:13 PM
    #524
    seric007
    wanted to post a little update after running it for a bit now.... so i have a 55mph shimmy that I've not been able to get rid of, well this had a dramatic effect on the shimmy. its no longer a shimmy.. but a less annoying... vibration.
    i really am impressed how much this has changed the characteristics of the steering.
  5. Dec 30, 2012 at 7:48 PM
    #525
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    whats the weight on this damper?
    wondering if I could just clamp something on temporarily to see if it
    would do anything about the wheel shakes at 50-70 :der:
  6. Dec 30, 2012 at 9:00 PM
    #526
    seric007
    well the "weight" and the "Bracket" have a rubber between them so it can move on its own... but it cant weigh much... at most... 1/2 lb? someone on the lexus forums said their version (similar) was 230g
    mine really made a difference in the 55mph wobble.. and its not just in my head.. its still there just no where near as annoying.
  7. Jan 2, 2013 at 2:38 AM
    #527
    josh256
    Josh
    Tacoma TRD Sport
    I'm going to give it a go with significantly less ideal tools than Seric (high speed vs. press, angle vs. bench, no vice). Worse case I buy a second damper.. Will take pics and report back in a few days.
  8. Jan 2, 2013 at 3:52 PM
    #528
    seric007
    just take your time, you can do it with a drill, various small-medium bits and a small file and a bench grinder. its just file, test, grind test, rinse... repeat... about a billion times :D
  9. Jan 2, 2013 at 4:40 PM
    #529
    Tacoma Mike
    Southern Maine
    i already posted in the other thread.
    My vibe is gone with the mount change.
    Same part number and look.
    I also have the harsh ride springs.
    I might just play with the center bearing a little if i have time to see what it does.
  10. Jan 2, 2013 at 5:22 PM
    #530
    seric007
    i assuming 4wd? im a prerunner and mine looks nothing like that... same part # i think right?
  11. Jan 2, 2013 at 5:27 PM
    #531
    Tacoma Mike
    Southern Maine
    you have a different # compared to a 4wd however it comes up with the same part number installed in your truck already
  12. Jan 3, 2013 at 5:28 PM
    #532
    tacoidaho
    tacoidaho Well-Known Member
    Idaho
    09 TRD Sport Access Cab
    Stopped by the dealership to see what the ETA is on part(s).
    Found out even tho I just had the harsh ride TSB done it is superseded by this driveline TSB and the 4 leaf springs are different part numbers.
    Everything is supposed to be in on the 9th. Will update when its done.
  13. Jan 3, 2013 at 5:40 PM
    #533
    Tacoma Mike
    Southern Maine
    Yea until I get more info on the springs I'm not doing anything else. The mount height is slightly lower than previous even though it is the same number.
  14. Jan 4, 2013 at 4:33 PM
    #534
    silvrsvt
    silvrsvt Member
    Jack
    AZ
    09 Tacoma 4X4 SR5 TRD
    3" Lift, 17" Chrome wheels, Bridgestone's
    just installed new nitto terra grappler 265-70-17 and shake is gone!
  15. Jan 10, 2013 at 10:40 AM
    #535
    josh256
    Josh
    Tacoma TRD Sport
    Still waiting on my damper. Apparently they're backordered, shipping directly from Japan to the dealer and showing up ideally next week.
  16. Jan 14, 2013 at 8:53 PM
    #536
    Bodete
    Bodete Well-Known Member
    Missouri
    2018 Tacoma TRD Off Road
    I found a steering wheel damper that fits the 2005-2011 steering wheels. It fits and does not need any modification. Part # 45713-35030 steering damper and part number 90159-50199 screws quantity 2. This steering wheel damper is from the 4runner and highlander. I put it on a week ago. It did not eliminate my steering vibration but it did reduce it. Why did toyota put a steering damper on the 4runner and the highlander that have the same steering wheel but not put it on the tacoma?
  17. Jan 15, 2013 at 4:50 AM
    #537
    tacoidaho
    Idaho
    Parts are all in.
    Taco goes in tomorrow for the repair, will post when done. Wahoo!
  18. Jan 15, 2013 at 11:51 AM
    #538
    josh256
    Josh
    Tacoma TRD Sport
    Hey Seric,
    Any idea how many mm you grinded of the damper (or weight)?
    EDIT:
    Nevermind, I was able to install it without grinding the damper - instead I grinded down the plastic horn/cover mounts (which were pinching the damper's top edge I believe).
    2012 Damper installed into 2011 wheel:
    Horn cover, upper mounts grind point:
    Took the taco for a drive and *wow* what a difference. Steering is significantly more stable/confident. Drives like it should have off the lot IMO.. will report back on shake in a month or so.
    Thx,
    Josh
  19. Jan 18, 2013 at 4:27 AM
    #539
    tacoidaho
    Idaho
    ***Update
    Notified by dealer that (2) of the (3) steps have been performed and the technician confirms the vibration is still present.
    While attempting the third step (steering damper) they encountered the mismatch fitting of parts.
    I informed them of the parts and mods you guys have done to make the damper fit, and as a result Toyota asked for link to this forum and thread. They are monitoring this issue here.
    Should find out soon if further development is coming to fully address all concerns related to this TSB.
    Hats off again to my dealer, who is doing their best to support me. I haven't used their loaner car while mine sits waiting for parts, but they have really made efforts while this all gets sorted out.
    Not sure what to do if all (3) steps are completed and vibe isn't gone?
  20. Jan 24, 2013 at 5:25 PM
    #540
    Lagunito
    Lagunito Deceased
    South Florida
    Pre Runner
    Say what you want, don't cry when you get bitch slapped in real life, these forums are moderated by your make believe friends of your alter (troll) ego.
    I finally rebuilt the right front caliper and replaced the flex hose as well as
    the hard line that had been over tightened and flared the fitting affectively stripping the flex lines threads.
    I replaced the rotors with a freshly turned set and,
    washed the ceramic EBC yellow brake pads in SLX denatured alcohol
    When I had the tires rebalanced the tire store placed the wheels with
    equal weighed planes on the same side of my truck,
    not on the ends or same axel
    I corrected this by swapping the right rear with the left front wheel.
    I also replaced the differential fluid and used a GL5 75w80 castrol non synthetic gear oil.
    I regularly commute on a 3 mile winding mountain road with 10% grades
    down hill braking was torcherous and
    required down shifting the 5 speed auto (under 20mph) into 2nd at times.
    After the service I now have no issues but it is only 200 miles,
    after another 700 or so I'll post back.
    It feels so nice for the time being to have the shakes gone.
