Steering wheel Shake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mxmaniac, Jun 25, 2010.
  1. Jun 17, 2013 at 8:04 PM
    #581
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Definitely check the hub bore on the wheels.. the toyota hub is 106mm.. anything larger than that will be lug centric.. and could cause vibes. I know I just switched to different wheels and have vibrations. Since this issue came about i have been doing alot of research. my previous wheels had a bore size of 106.25mm and I never had an issue. Fast forward to now with my new set up.. that have a bore size of 108mm.. and I have vibes. Ill be picking up some Gorilla hub centric rings.. 108mm - 106.1mm to match them better. Can be ordered from Amazon for about 16 bucks.
    http://www.amazon.com/gp/aw/d/B0032HQJ7G/ref=ox_sc_act_image_1?ie=UTF8&m=ATVPDKIKX0DER
  2. Aug 4, 2013 at 8:13 AM
    #582
    ClarKent423
    ClarKent423 New Member
    Yasha
    Saint Paul, MN
    SR5
    I replaced my tires with BF Goodrich Rugged Trail tires and the shake between 65-72 MPH has disappeared!
  3. Aug 5, 2013 at 2:20 PM
    #583
    jage
    jage Well-Known Member
    Franktown CO
    '010 Silver Double Offroad Leather/Sunroof
    what did you replace?
    I have Toyo AT passenger and the shake comes back after a week no matter how careful they balance. The previous tires (Goodyear MT something or other) were practically undrivable so I've just learned to live with it- unlike the squeek from the cabin vent fan :mad:
  4. Aug 14, 2013 at 11:54 AM
    #584
    beeesmitty
    beeesmitty Well-Known Member
    NC
    11' SR5 DC BSP 4X4
    265/75/16 Cooper ATP, TRD FJ Trails, 5100's @ 2.75, ReadyLift 2" Blocks
    Same shit here with my 2011. I have run BFG AT 265/75/16 and then added MB wheels and then changed tires to Duratracs. All the same shake in the steering wheel. Discount has balanced my tires more than 10 times trying to fix.
  5. Aug 14, 2013 at 3:24 PM
    #585
    dbs1
    dbs1 2015 Dbl cab TRD Pro 4x4
    Dan
    2015 Dbl Cab TRD Pro 4x4
    SC w/urd pulley, afe cai, URD LT's, TRD cat back. 375hp. Custom logos, tonneau cover, westin bar with piaa lights, aero force gauges, custom front air dam, Westin step bars.
    Using new Michelin on current 2010. Put new nitto crossteks on the 06 a month ago. Like both sets of tires. HATE the frikken wheel shake 60-72 on both of them. It's PISSIN ME OFF!!!!
  6. Aug 15, 2013 at 3:59 PM
    #586
    golferdawg17
    golferdawg17 Taco seconds-Spruce Dawg
    Columbus, GA/Dadeville, AL
    '14 Spruce Mica 4x4 Double Cab V6 TRD
    WeatherTech DigiFit Mats, Dee Zee Bed Mat, Clazzio Custom Leather seat covers (gray outer/black insert) ordered from Tyler at Clazzio (DO NOT ORDER FROM clazzioseatcovers.com)
    My steering wheel shake has been going on since i drove it off the lot (will know better next time...), and I've been bringing my truck in to troubleshoot. Well, i now have 17K miles on the Dunlops (over 8 months), have brought my truck in at least 4 times to get the tires road force balanced, and the dealership is convinced it's the tires. They pulled some Bridgestone Dueler HT's off another truck, and the shake was much less (not completely gone). Then they try to sell me the tires for $931; i say no, of course, and asked for an option B. i had to file a report with Toyota Consumer Affairs and after about a week and a half, Toyota CA offered to split the cost of new tires 3 ways with the dealership. So, my estimated cost is $380 installed.
    My question is, is this as much as i can expect? Should i take that deal? I asked if there was an expiration on the offer, and Toyota CA said no. I'm tempted to put up with the vibration for another year, and then redeem the offer. My only reservations with this is that my warranty will be expired by then. (So, if it's not really the tire, I'll be SOL)
  7. Aug 15, 2013 at 4:08 PM
    #587
    Cactusone
    Cactusone Active Member
    Sonoran Desert
    05 PreRunner Off Road
    BHLM, Sport hood and grill, Deezee side steps painted super white, 5100 w/OME884 and AAL
    I had steering wheel shake. Balanced/rotated twice no better. The third time I got a smart guy at discount tire who rotated side to side instead of front to back. Smooth! BFG 285/75-16's.
  8. Aug 16, 2013 at 10:18 AM
    #588
    panthro
    panthro Well-Known Member
    Austin
    2012 TRD Sport Prerunner
    2017 TRD Off Road 4x4
    @ golferdawg17
    I'd go with the Bridgestone dueler ht's. The Dunlops are just junk. I've had two cars off the dealer lot with the Dunlop tires and replaced them after 10k miles. I have the dueler ht this time and they are much better. So far mine have about 18k miles on them. I would think thay can give you a better deal than that because 931 bucks seems like an inflated price. They can be purchased from discount tire for 628.00. Also did they try switching out the wheels/rims one at a time too? Try one at a time with the tires? It might just be one in the front which I would think they can replace only one for free since it's a new car.
  9. Aug 17, 2013 at 7:56 AM
    #589
    malbanese
    malbanese Active Member
    Houston Tx
    2013 Tacoma dclb spruce
    Hood struts, weathertech 5100's all around allpro skid dif vent mod undercover
    If the trucks still under warranty then I'd insist on them fixing it on thier own dime. Your truck has a history with them of this ongoing problem.But if you can put up with the shake for year then it's either not that bad or your have a high tolerance for defects.
  10. Aug 18, 2013 at 10:15 AM
    #590
    jage
    Franktown CO
    And I'm sure when you call up in a year, they'll understand how you have nothing but a memory to prove it.
    Get the tires, and hope the shake stays away or is minimized enough you can live with it.
  11. Aug 19, 2013 at 8:12 AM
    #591
    DansToy
    DansToy New Member
    San Jose,Ca
    Toyota pro
    Don't pay for anything. I went through a lot of BS. In the end they put new tires on on their dime. It is a lot better but still not correct. Don't know what to do at this point but something is not right with this truck. They need to figure it out. We can't all be wrong.
  12. Aug 19, 2013 at 11:10 AM
    #592
    81shark
    81shark Well-Known Member
    don't forget to check u joints. a bad one can cause a nasty vibration that can be felt thru out the truck.
  13. Sep 4, 2013 at 7:01 AM
    #593
    Budman13
    Budman13 Member
    Sean
    Lower Alabama
    13 Tacoma prerunner 4banger
    Tinted windows, aws vent visors, undercover bed cover
    I have a 2013 DCSB prerunner 4 cy that has the same problem. It is completely stock steel wheels. Shakes like hell 40 to 70 about 65 is the worse speed. Been to shop 4 times now, in the shop currently Toyota is replacing a motor mount. Hope this is the fix. I really like my truck but think it should ride Down the road with out causing my drink to go flat.
  14. Sep 4, 2013 at 7:17 AM
    #594
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    finally got my hub ring in. Lost one somewhere. Got it on to hopefully fix my vibes. And it didn't. Still shakes like crazy between 50-70mph. I did air up the passenger front tire to compensate for the pull I had.. so maybe that might be contributing. Doubtful tho.
    Only other options I can think of are:
    U-joints
    Carrier bearing
    Wheel bearings
    Motor mounts
    Tires were just rebalanced thursday and checked out good. Any ideas? Im goin crazy here.
  15. Sep 6, 2013 at 9:43 AM
    #595
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    Moose.. I took this advise from Bamtoy who is a taco mechanic in this forum.. Always look at the tires frist.. is roadforced balance? this will solved 90% of the time with the shakes. That was causing mine problem. the 3d party didnt have the right equipment to do it. had it done at toytoa dealership.
    If not,, then look into tie rod issue, then bearings or alinement issue.
    good luck..
  16. Sep 6, 2013 at 10:29 AM
    #596
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thanks man.
    After another alignment at discount with brand new 3 month old machines... the vibs are gone. Smooth ay all speeds.
    Only issue now is i have vibes when braking. Its not in the pedals tho. Its in the steering wheel and seat. The rotors are less than a year old. New pads as well. My alignment is a tad off still.. seems to have positive camber. It alright pulls to the right a little. Not sure what causing the vibes when braking. Any thoughts?
  17. Sep 6, 2013 at 10:35 AM
    #597
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Well theres your problem....Mexicans dont do Toyotas, believe me, i'm Mexican..i take it to an asian mechanic, mine knows his stuff.
  18. Sep 6, 2013 at 10:55 AM
    #598
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Wut? Lol
    Its a legit Discount Tire. My buddy (a member here) works there as well.
  19. Sep 6, 2013 at 11:18 AM
    #599
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    subd......................
  20. Sep 6, 2013 at 12:09 PM
    #600
    User Name01
    Bolbi Stroganovsky
    As a Mexican, I am only allowed to work on "Fors" and "Chebys" lol......my mechanic is a GENIUS when it comes to Asian automobiles
